Old 10-21-2014, 12:59 AM   #1
Pegasus
Drives: 2014 Whiteout Monogram FR-S M/T
Exclamation Acceleration/Excessive Wear Discussion
I have two questions concerning acceleration and the wear it has on my FR-S.
#1 I was a light today, random guy in a F-150 gives me "The Look" so I stab at my gas pedal twice to let him know ( I'm 18, I can do stupid Sh*t like this). So the light turns green and I bog it, bad. He has an auto no doubt and a lot more low end torque so this dem F-150 is pulling on me quite a bit. Then I reach 5K, hit the power band, chirp in second and blow his doors off.
So the question is, without burning my clutch out or dumping my clutch ( It's a freaking pickup truck at a red light, I'm not gunna dump the dem clutch) is there anyway not to bog it?
Do auto FR-S's pull on manuals with out a revving them out and dumping the clutch?
#2 How bad is chirping in second for my car? I know it's just a tire squeak and shifting into 3rd without letting the rpm drop is the same thing. But should I be holding my clutch in untill the rpm and trannys sync and then shift? Or is just jumping gear to gear as fast as I can not TOO bad for it? ( I shift pretty dang fast ) I don't wanna mess my car up, thanks.
Pegasus is offline   Reply With Quote
Old 10-21-2014, 01:16 AM   #2
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
oh god
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Jond63 (10-21-2014), Sideways&Smiling (10-21-2014)
Old 10-21-2014, 01:19 AM   #3
FR-BLESS
Drives: Asphalt 2014 Asphalt Scion FR-S
Well to answer your first question we mu-
oh.
FR-BLESS is offline   Reply With Quote
The Following 16 Users Say Thank You to FR-BLESS For This Useful Post:
AznKirby (10-21-2014), Bigbadvoodooguru (10-21-2014), brandonblt2 (10-21-2014), DieselDog (10-21-2014), Djratrap (10-22-2014), EAGLE5 (10-21-2014), El Guapo (10-22-2014), FRSBRZGT86FAN (10-21-2014), Rampage (10-21-2014), raul (10-21-2014), RaveSaint5 (10-21-2014), Rota (10-21-2014), Sideways&Smiling (10-21-2014), Texas BRZ (10-21-2014), TJ3000 (10-21-2014), tobin (10-22-2014)
Old 10-21-2014, 01:39 AM   #4
DeeezNuuuts83
Drives: 2006 Evo IX SE
Sounds like you should have gotten an automatic Genesis Coupe instead
DeeezNuuuts83 is offline   Reply With Quote
Old 10-21-2014, 01:49 AM   #5
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Better check your manifold. Sounds like it might be in danger.
Also maybe check the screws on your floor panel.
Wise is offline   Reply With Quote
The Following 20 Users Say Thank You to Wise For This Useful Post:
ApolloSki (10-21-2014), brandonblt2 (10-21-2014), Dake (10-21-2014), DieselDog (10-21-2014), Djratrap (10-22-2014), El Guapo (10-22-2014), ericmpena (10-22-2014), FRSBRZGT86FAN (10-21-2014), gzpermadi (10-21-2014), JB86'd (10-23-2014), MaddBaggins (10-21-2014), Muaddib (10-21-2014), navanodd (10-21-2014), ntron1 (10-21-2014), number1Tango (10-21-2014), Pkush (10-23-2014), Rapiddan45 (10-21-2014), Reaper (10-21-2014), STV3 (10-21-2014), tobin (10-22-2014)
Old 10-21-2014, 01:50 AM   #6
WesleyG
Drives: 2014 Satin White Pearl GTS auto
rev it to 6000 and then promptly drop the clutch no bogging, slight wheelspin and it shoots you forward in a very mild sense of the term.
2002 MR2 Spyder 2zz-GE Apexi PFC PPE Race header 8500 RPM of FUN
2014 37J 86 Auto
WesleyG is offline   Reply With Quote
Old 10-21-2014, 01:52 AM   #7
WesleyG
yes because manifold danger warning on the PC display causes nuts and bolts to fall from behind the dash and then you lose your floor panel.
then the mad scientist will have to rip apart the block and replace the piston rings you fried
2014 37J 86 Auto
The Following 7 Users Say Thank You to WesleyG For This Useful Post:
brandonblt2 (10-21-2014), FRSBRZGT86FAN (10-21-2014), JB86'd (10-23-2014), JohnJuan (10-21-2014), leoh007 (10-21-2014), number1Tango (10-21-2014), stevethuro (10-21-2014)
Old 10-21-2014, 01:53 AM   #8
LXXXV1
LXXXV1's Avatar
Drives: 2014 FR-S Monogram, Whiteout 6MT
2007 Honda CBR600RR-Pearl White/Silver - Totaled
2014 Scion FR-S Monogram-Whiteout - #LXXXV1 (build)
φφκα
LXXXV1 is offline   Reply With Quote
The Following User Says Thank You to LXXXV1 For This Useful Post:
CokeSlap (10-22-2014)
Old 10-21-2014, 01:53 AM   #9
Wise
Circle Work Clerk
You'll blow yourself to pieces!
Old 10-21-2014, 01:58 AM   #10
dizzario
Drives: FRS
hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahahahahahahahahahahahahahahahahahahahahaha hahahahahaahahahafuck this shit I give uphahahahahahahahahahahahahahahahahahahahahahahaha hahahahah*blows own brains out*--
dizzario is offline   Reply With Quote
Old 10-21-2014, 02:07 AM   #11
sillierabbit
Drives: 2014 FR-S Monogram Whiteout AT
sillierabbit is offline   Reply With Quote
Old 10-21-2014, 02:26 AM   #12
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
One question...
Is this a SERIOUS question and thread?
If so wow stupidity can flow like water..
Old 10-21-2014, 03:15 AM   #13
Texas BRZ
Imperfect
Texas BRZ's Avatar
Drives: 2025 C8 Z06s and more!
I understand that you're worried about wear and tear on your vehicle. And in my opinion, you're punishing and abusing your car by racing other cars on public roads much more than you would compared to taking your need for speed and car to the track... Pay the $150 - $300 that you would on a traffic citation and apply it on a HPDE event. You'll learn much more than driving on public roads will ever teach you... And to safely and properly drive your car fast while taking great care of it at the same time. Why do I mention all this? Because I once had the mindset like you in the past.
We're both in Texas... PM me if you want info on attending a HPDE event with one of the top organizations in our state. Houston MSR is closest to you, and I see myself visiting there for the upcoming future as well.
Texas BRZ is offline   Reply With Quote
The Following User Says Thank You to Texas BRZ For This Useful Post:
Old 10-21-2014, 06:13 AM   #14
I chirped in second once and look what happened! These cars are not built for such antics! Once those nuts and bolts come from the dash you are DONE
calmtigers (10-21-2014), Sideways&Smiling (10-21-2014)
Excessive Rust? video inside BRZnut BRZ First-Gen (2012+) — General Topics 45 03-12-2014 07:53 PM
anyone notice excessive wind noise from windows? BRZnut BRZ First-Gen (2012+) — General Topics 18 06-11-2013 06:14 PM
Excessive smoking from left exhaust? Derrick Issues | Warranty | Recalls / TSB 3 11-25-2012 07:37 AM
Excessive negative camber? MTeator Suspension | Chassis | Brakes -- Sponsored by 949 Racing 10 06-22-2012 10:30 AM
Excessive wheel weights? muffinman Other Vehicles & General Automotive Discussions 6 05-25-2012 09:59 AM
