Old 10-17-2014, 08:12 AM   #29
Model Citizen
Lacking brains
Drives: frz
ok that eliminates those.
im kind of out of ideas being on the other side of the world
all we know is its running rich suddenly on SC tune that worked previously. Stock tune no SC not rich. you have checked for leaks on input side of SC but what about on pressure side/ intercooler ect
time to send logs to your tuner
Have checked everywhere i could.
Logs were sent to tuner yesterday once i put the sc back into the loop and had ruled out the typical things.
thanks again,
Originally Posted by Freeman View Post
Had a similar thing happen to a local guy. The way he explained it to me was that the computer that controls the injectors crapped out on him. $300 bucks to replace it.
Awesome thanks for info. From what i'm reading the computer box that sits on the passenger injector sheild is actually just for the di system?
My logs show the di system is kicking in at times, but the car is reading rich and basically killing fuel trims.
http://www.quirkparts.com/oe-subaru/...str=22635JB000 this place is local atleast.
hopefully don't have to get to doing that, but atleast its a new direction to look
have a techstream compatabile cable ordered from amazon, have never played with the software but it may give some more info, if not for $25 was worth having anyway.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 10-17-2014, 10:53 AM   #30
protpibe
protpibe's Avatar
Drives: 4-Runner Sport - 13' BRZ SportTech
From everything I've read in this thread, my guess would be fuel and electrical related.
I would start with the DI computer mounted to the side of the fuel injector cover on the RH side of the engine bay. You might also want to check all of the fuel injectors and their wiring under the covers. From there I would work backwards and look at things like the DI pump and the fuel pump.
Top Tier Imports - Check out my build journal HERE
protpibe is offline   Reply With Quote
The Following User Says Thank You to protpibe For This Useful Post:
Model Citizen (10-17-2014)
Old 10-17-2014, 11:55 AM   #31
Model Citizen
Lacking brains
Drives: frz
Originally Posted by vgi View Post
so from your posts i'm not clear if the car ran ok or not (besides misfires) on stock MAP and stock tune and supercharger plumbing removed (i guess you used stock air box with plugged extra connectors and also you plugged the vacuum hose going to the diverter valve from the break boost line)?
if yes, if double check all the vacuum hoses, diverter valve, map sensor (that the second KW sensor you tried on is identical to the original one you used)
if not, you could try to take a stock ecutek rom and mod it to use PI only to see if it's DI system throwing you off (you did not do fueling mods - injectors and/or pump, right?)
sorry if some of that sounds stupid (eg map sensor is the same) - it's just that things can be overlooked.
How do i edit to remove the di?
Sorry, i'm essentially tuning retarded.
Old 10-17-2014, 12:28 PM   #32
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Any one more experienced think this might be direct injector seal related?
Freeman is offline   Reply With Quote
The Following User Says Thank You to Freeman For This Useful Post:
Old 10-17-2014, 12:54 PM   #33
protpibe
protpibe's Avatar
From what I remember reading, a DI seal issue would cause distinct popping noises on cold start
Old 10-17-2014, 01:20 PM   #34
Model Citizen
Lacking brains
Drives: frz
thats what i've been questioning
but yeah, no pops
Old 10-17-2014, 02:41 PM   #35
Model Citizen
Lacking brains
Drives: frz
noticed that even at 14.6 afr the o2 sensor (s1 b1) is showing 2+ volts on my scan tool, same with these logs.
shouldn't an o2 sensor be reading .45v at 14.6 afr?
http://www.datazap.me/u/utekineir/o2...0&data=7-23-33
Edit::: Nvm. I was wrong. Oe front "Wideband" runs at a different voltage.
Old 10-17-2014, 05:41 PM   #36
steve99
Drives: FT86
Did notice in you logs the injector pulse widths drop when the problem happens and the throttle stays constant. it possible its the DI computer as others have suggested which i believe is the one under the bonnett. hopefully you coulds swap it out to check, but check with tuner .
Dont swap you main ecu passenger side kick panel, with someone as i believe its a secutiry coded set with the dash/imobiliser/ecu swaping any of those three may cause issues due security and disable one or both cars.
Old 10-19-2014, 10:39 AM   #37
Model Citizen
Lacking brains
Drives: frz
This looks like a valid culprit.
Old 10-19-2014, 12:41 PM   #38
Model Citizen
Lacking brains
Drives: frz
el oh el
Old 10-19-2014, 01:36 PM   #39
protpibe
protpibe's Avatar
wtf lol
What is that?
Old 10-19-2014, 02:11 PM   #40
stonenewt
Drives: BMW 120d
I think you're looking at an exhaust moggy!
stonenewt is offline   Reply With Quote
Old 10-19-2014, 02:35 PM   #41
dabocx
dabocx's Avatar
Drives: Scion FRS
what
dabocx is offline   Reply With Quote
Old 10-19-2014, 02:40 PM   #42
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
So how does it run without the cat now?
Sellout is offline   Reply With Quote
Auto throttle / Anti stall mods discussion brn12345 Software Tuning 12 04-03-2017 07:39 PM
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 01:01 AM
Erractic loss of power at low RPM Bg8780 Issues | Warranty | Recalls / TSB 8 05-01-2013 03:13 PM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 09:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
