#15 |
I Love custom Turbo kits
Drives: Limited BRZ
DAT blood doe.....
How hard was removing them? Did that fix it??
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | Model Citizen (10-15-2014) |
#16 | |
Lacking brains
Drives: frz
I ****ed around an hour or two to get them without jacking. Was way easier and less painful just to toss it up in the air and undo a mount. Ape hands don't help. Gotta pick up replacement plugs. Oem is it at the moment right? Least far as general local availability? |
| The Following 2 Users Say Thank You to Model Citizen For This Useful Post: | glamcem (10-16-2014), Sportsguy83 (10-15-2014) |
#17 |
Drives: Limited BRZ
As far as I know, yes....
#18 |
Lacking brains
Drives: frz
No luck after changing the plugs,
on the upside, they looked reasonably due for it anyway. |
#19 | |
Drives: FT86
You long term fuel trims at idle low RPM are about 12% in that first log. and your AFR under light load just off idle and at idle are 11.2 seems very rich for 950rpm low load no boost. something upsetting fueling ? air leak ,crook o2 sensor , leaking injector ? can you log COMMANDED AFR ie what ecu is asking for as well as the measured AFR from 02 sensor ? |
| The Following User Says Thank You to steve99 For This Useful Post: | Model Citizen (10-16-2014) |
#20 | |
Lacking brains
Drives: frz
Put the sc kit map sensor back on, flashed delicious tune, connected plumbing. As requested: http://www.datazap.me/u/utekineir/ne...0&data=5-41-66
#21 | |
Drives: FT86
That new log look like what I would expect LTFT is low (zero) AFT 13 or 14 low rpm low load. So thats with stock tune and stock MAF/MAP sensors. No injector changes ? Might point to crook map/maf sensor (or their was leak in gasket at maf sensor. |
#22 | |
Lacking brains
Drives: frz
http://www.datazap.me/u/utekineir/more?log=0&data=5-12 http://www.datazap.me/u/utekineir/ne...og=0&data=5-12 http://www.datazap.me/u/utekineir/ne...og=0&data=5-12 take a look at the rail pressure on those logs. |
#23 |
Drives: FT86
Looked at some of my logs and the fuel pressure drops to 3 or 4 at low rpm. and goes to 13 to 19 higher rpm , that is only high ressure fuel pump the low pressure port fuel pressure is not monitored
your running rich so would assume that would be due over pressure, you would think low pressure would make it lean. that tune you have has run ok previously ?? , its not a super safe rearly rich base tune just to get you to tuner ?? |
#24 | |
Lacking brains
Drives: frz
In the vein of running rich it looks to be consistently be -25 on the stft on a lot of my logs. Spraying carb cleaner I was unable to find any sort of vacuum leak. |
#25 | |
Drives: FT86
#26 | |
Lacking brains
Drives: frz
and had a local guy come by and let me use his maf a few days ago with no change. |
#27 | |
Drives: FT86
im kind of out of ideas being on the other side of the world all we know is its running rich suddenly on SC tune that worked previously. Stock tune no SC not rich. you have checked for leaks on input side of SC but what about on pressure side/ intercooler ect time to send logs to your tuner Last edited by steve99; 10-17-2014 at 12:06 AM. |
#28 |
Drives: 2013 Ultramarine FR-S
Had a similar thing happen to a local guy. The way he explained it to me was that the computer that controls the injectors crapped out on him. $300 bucks to replace it.
| Auto throttle / Anti stall mods discussion | brn12345 | Software Tuning | 12 | 04-03-2017 07:39 PM |
| Loss power after gas fill up HELP! | Ad8707 | Issues | Warranty | Recalls / TSB | 63 | 08-21-2014 01:01 AM |
| Erractic loss of power at low RPM | Bg8780 | Issues | Warranty | Recalls / TSB | 8 | 05-01-2013 03:13 PM |
| Hi rev power loss? | lbroskee | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 09-29-2012 09:47 PM |
| CEL, Loss of Traction Light, Loss of Power | pituala | Issues | Warranty | Recalls / TSB | 19 | 09-05-2012 11:23 AM |
