Old 07-02-2014, 04:21 PM   #1
brn12345
brn12345's Avatar
Auto throttle / Anti stall mods discussion
A friend of mine suggested if anything can be done with the available mapping solutions to allow for a sort of auto throttle anti stall setup. So imagine your in traffic and you have to balance throttle and clutch to keep rolling and stopping. Now what if all you had to do was let go of the clutch and the ecu would add throttle. This would be ideal if it can be switched on and off. I am thinking using the sport button to toggle this. Our cars already have something similar when cold. Try it next time the car is cold and you will find that you can let out the clutch without applying throttle and the car would move without stalling. Can something like this be programmed?
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
The Following User Says Thank You to brn12345 For This Useful Post:
Sportsguy83 (07-02-2014)
Old 07-02-2014, 04:23 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
When cold its because it is trying to force 1500 RPMs idle to warm it up. I bet it can be implemented easily with a custom map.
Old 07-02-2014, 04:52 PM   #3
chas3wba0
chas3wba0's Avatar
Drives: Yes
A seasoned MT driver shouldn't need this...
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 07-02-2014, 04:55 PM   #4
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I think it's called an automatic transmission.
Jyn is offline   Reply With Quote
The Following 4 Users Say Thank You to Jyn For This Useful Post:
arghx7 (07-06-2014), continuecrushing (07-02-2014), wparsons (07-03-2014), zooki (07-03-2014)
Old 07-02-2014, 05:03 PM   #5
d1ck
Drives: Black 2013 FRS
Set your idle speed to 1500RPM. That said it seems a bit silly to me.
d1ck is offline   Reply With Quote
Old 07-02-2014, 05:15 PM   #6
brn12345
brn12345's Avatar
Ok, question is can it be something linked to the sport button? Meaning if I select sport mode idle will be 1500?
Old 07-02-2014, 05:17 PM   #7
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
you can also put a brick on the gas pedal, and just bounce off the limiter. When you need to go forward, just put the car in gear and release the clutch.
This also works well for hills. So its like a hill/traffic assist.
Caution though, now that this idea is out scion will release a new frs special edition with this feature. It will be called the FRS Monogram 10 Series 1.0 HT(hill/traffic).
Pre-order now, only 100,000 will be made.
Old 07-02-2014, 05:28 PM   #8
phrosty
This does sound like a good idea.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 07-02-2014, 05:29 PM   #9
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Set the idle based on gear, I think you can do this in ecutek. If 1st gear set idle to 1,200 or something.
post_break is offline   Reply With Quote
Old 07-03-2014, 10:01 AM   #10
wparsons
wparsons's Avatar
Why even bother? You can get the car moving without throttle in 1st gear with a normal idle. I do it in traffic ALL the time when using the gas would get me going too fast.
If you're bored (or traffic REALLY sucks) you can get up to 3rd gear without using the gas at all too.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
D_Thissen (04-03-2017)
Old 07-04-2014, 02:50 PM   #11
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You can easily get to 6th gear without throttle.
Old 04-03-2017, 08:28 AM   #12
brn12345
brn12345's Avatar
Wanted to revisit this issue and maybe 3 years later someone has an idea on how it might be done. As much as some of the earlier posts were helpful i still cant get the desired function. Refer to the first post please to understand what is being asked.
Old 04-03-2017, 07:39 PM   #13
steve99
Unless you skilled at ECU coding/programming (actual functional code changes not just altering existing maps) you going to need ecutek.
Ecutek can activate/deactivate custom maps based on position of sport or Trac buttons.
Unfortunatly ecutek doent have a custom map intup or output function to directly control idle speeds.
Then you going to have to experiment with custom maps for stuff like load vs rpm vs vehicle speed and add throttle under certian conditions.
you would have to test it very carefully so it not going to launch you into the car in front under certain conditions.
Im sure it could be done to some degree, but would require a lot of testing so it would not be dangerous.
Im pretty sure my 2012 manual Toyota corolla has something like this as if you nearly stall it, my natural reaction is to quickly depress the clutch, and the car then revs at about 2000 for a second with no throttle input, its kind scary sometimes. Im not sure id want something like that on a brz.
The best way ive found to smooth low rpm is to get maf scaling correct at idle and low rpm.
Part throttle faster than full throttle brn12345 Engine, Exhaust, Transmission 38 10-21-2021 12:20 PM
Throttle response after intake mods Aaron_blatherwick Engine, Exhaust, Transmission 2 05-22-2013 05:18 PM
To those with the auto -any throttle lag or hesitation at low speed? ahausheer Engine, Exhaust, Transmission 22 07-25-2012 05:21 PM
Started a discussion on reddit/r/auto rideh Scion FR-S / Toyota 86 GT86 General Forum 0 12-29-2010 10:51 PM
