Old 10-11-2014, 09:11 PM   #1
Model Citizen
Lacking brains
Drives: frz
Loss of power/stall under light throttle.
I developed a bit of an issue today.
Basicaly the car sputters and cuts out above 2-4k rpm, and pretty much constantly under load, repeated throttle application results in a stall. Ended up having to get a ride home and bring the car back with my trailer today.
I initially was suspecting coil pack but there are no codes, and shows no misfires.
Here are logs.
http://www.datazap.me/u/utekineir/fr...r?log=0&data=5
Heres a video while parked in neutral.
[ame="https://www.youtube.com/watch?v=iAmsoLkv3uA&list=UUhvDJ0loszAdzRWUwe6V3-A"]Frs sputter - YouTube[/ame]
Engine wise. Car has kraftwerks sc base kit, delicious tune, vta catch can.
Any advice, direction to look would be appreciated.
Thanks.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
Old 10-12-2014, 01:37 AM   #2
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Have you checked for leaks? make sure there is no popped hose under the intake manifold
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Model Citizen (10-12-2014)
Old 10-12-2014, 05:52 AM   #3
Model Citizen
Lacking brains
Drives: frz
Vacuum hoses are on and clamped, when i popped one in may before clamping the result was surging.
This is a flat out cut.
Just put a camera snake down to see both sides of rotorex unit blades looked normal, turned freely with crank.
Changing to spare map sensor now and checking everything else. Bit early to be starting car directly under bedroom.
Will try pulling battery terminal too.
No codes is the weirdest part.
Old 10-12-2014, 06:32 AM   #4
Model Citizen
Lacking brains
Drives: frz
No luck
idle is also smooth, not surgey like in the past when i've had leaks.
[ame="https://www.youtube.com/watch?v=m-P_7FVZ71g&list=UUhvDJ0loszAdzRWUwe6V3-A"]External - YouTube[/ame]
delicious tune is speed density iirc,
when i unplug the maf car gets worse and pops code. not sure swapping someones maf may help but i'm going to try do that soon as i can get someone around.
Old 10-12-2014, 08:14 AM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Here are logs.
Thanks.
I flashed a friend's turbo car and it did something really similar to this.
Issue was that we flashed his car for 4 bar MAP sensor but he had left stock one in there.
Quick sensor change and everything was perfect.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Model Citizen (10-13-2014)
Old 10-13-2014, 10:54 AM   #6
Model Citizen
Lacking brains
Drives: frz
This the car cut out mid autox run.
Tried an extra map i had (kw sent me 2).
And also tried a maf off another frz.
No dice
Next step i think is tilting maf elbow up to remove from plumbing and stock map sensor and tune
The Following User Says Thank You to Model Citizen For This Useful Post:
Sportsguy83 (10-13-2014)
Old 10-14-2014, 09:38 AM   #7
Model Citizen
Lacking brains
Drives: frz
Removed the sc plumbing from the equation, flashed to stock, stock map sensor.
Finally got a misfire in #4 to show.
http://www.datazap.me/u/utekineir/mi...=5-51-52-53-54
guess picking up a coilpack is next?
on this car i've gotta undo a motor mount and lift the engine a bit to fit right?
Old 10-14-2014, 09:44 AM   #8
Sportsguy83
Drives: Limited BRZ
With the proper tools, it can be done without lifting.
Model Citizen (10-14-2014)
Old 10-14-2014, 10:02 AM   #9
Model Citizen
Lacking brains
Drives: frz
Awesrome. Thank you sir
I know on my forester even though plugs were doable. Because of how it sat lower than an impreza it was juat about easier to lift a side at a time. Eliminating that was the best part of removing the sibframe spacers (other than geometry correction).
Near 40k and hard use.
Maybe just lift and do plugs anyway?
Any plug reccomendations?
Sportsguy83 (10-14-2014)
Old 10-14-2014, 10:07 AM   #10
Sportsguy83
Drives: Limited BRZ
I don't know if there are any plug options other than stock ones.
Plugs require more tools/cursing to get done but if you are there and want to do it might as well.
There's posts in the forum for tools used to change plugs and it involves a few short swivel extensions.
Old 10-14-2014, 10:30 AM   #11
Model Citizen
Lacking brains
Drives: frz
I had that sort of sequence on the forester, Even with a bit more space it was misery.
Thanks
Old 10-14-2014, 10:49 PM   #12
Model Citizen
Lacking brains
Drives: frz
no dice on new coilpack
[ame="https://www.youtube.com/watch?v=HphiZE03Hjk"]Nope - YouTube[/ame]
Old 10-15-2014, 12:44 PM   #13
Model Citizen
Lacking brains
Drives: frz
Put a boroscope on throttle body its opening.
[ame="https://www.youtube.com/watch?v=ibhGH7iYbrc"]Throttle body boroscope frz brz - YouTube[/ame]
Not sure if this log has any relevance with the throttle position sensor.
http://www.datazap.me/u/utekineir/mi...data=5-7-40-42
Also removed the sc pulley adaptor taking the load of the sc compressor off of the crank. No change.
On initial start I was actually able to rev up to 4k+ then the bogging commenced.
Going back to thinking spark related.
Old 10-15-2014, 02:18 PM   #14
Model Citizen
Lacking brains
Drives: frz
passenger side
image by utekineir, on Flickr
Driver side
Auto throttle / Anti stall mods discussion brn12345 Software Tuning 12 04-03-2017 07:39 PM
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 01:01 AM
Erractic loss of power at low RPM Bg8780 Issues | Warranty | Recalls / TSB 8 05-01-2013 03:13 PM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 09:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
