Old 10-15-2014, 01:35 PM   #253
AznBRZer
Drives: 16 CBS WRX Limited
Originally Posted by yomny View Post
Well keep in mind that the tech at the dealer told me this fluctuation is normal and when cold it would be around the low mark, as long as it doesn't completely vanish from the reservoir bottle then we are good. I know this isn't normal to other cars but maybe it is to this guy b
That's why you're supposed to check it when it's warm, which I do, but it shouldn't be at the low mark when cold regardless.
AznBRZer is offline   Reply With Quote
Old 10-15-2014, 01:57 PM   #254
Hanakuso
Originally Posted by aagun View Post
waterproof tape
Can you take a picture of this waterproof tape? Are you talking about teflon tape?
Btw this is what my hose looks like. I've cleaned it off at least 3-4 times since i've owned the car.
Hanakuso is offline   Reply With Quote
Old 10-15-2014, 03:26 PM   #255
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Coolant Disappearing
Save yourself the headache it will fluctuate between low and full. I had my car pressure checked and double checked at the dealer, if it goes below low then have it checked if not forget it!! It's like the idle dip and the crickets!! There's no fixing it!! I completely understand it shouldn't be at low, that means it's low duh but this car functions that way.
BTW- not interested in starting a war but for the sake of others later on reading this as a guide. Check coolant when cold, when hot the level may be over the full mark.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
The Following User Says Thank You to yomny For This Useful Post:
AznBRZer (10-15-2014)
Old 10-15-2014, 03:27 PM   #256
yomny
yomny's Avatar
The waterproof tape is Teflon tape, used in plumbing.
Old 10-15-2014, 07:03 PM   #257
aagun
Drives: 86
YES YES IT IS teflon tape
aagun is offline   Reply With Quote
The Following User Says Thank You to aagun For This Useful Post:
Hanakuso (10-16-2014)
Old 10-16-2014, 05:23 PM   #258
Hanakuso
Thanks just installed some telfon tape. I noticed my coolant is almost completely gone from the reservoir. Not sure if I should fill it up or take it to the dealer.
Old 10-16-2014, 07:28 PM   #259
aagun
Drives: 86
make sure the tape locked up the holes between the hose and the reservoir.
Old 10-16-2014, 07:50 PM   #260
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
After topping mine off once I was fine. I think it burped out air from the first factory fill. If you've already refilled in the past then you may want to go.
B-R-Z is offline   Reply With Quote
Old 10-16-2014, 08:16 PM   #261
Hanakuso
I haven't refilled yet. For about a year it stayed at the low line and I just realized it's below that now.
I'll probably just refill it and send my oil in for lab results. If it doesn't drop or any trace of coolant in the oil then i'll stay away from the dealer.
Old 10-17-2014, 10:38 AM   #262
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
I have a feeling this solution will fix my issue. I've noticed the little black rubber hose is completely white/blue now.
What is this 'fix'? The guy edited his post and nothing is shown.
Grimlock is offline   Reply With Quote
Old 10-17-2014, 12:20 PM   #263
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I believe it was teflon tape in an attempt to seal off the hose at the top of the reservoir, theory being that the water is evaporating out of the reservoir tank.
In any case I don't think I've seen anyone with proof that the coolant is leaking out in a dangerous way, a top off every couple of months isn't the end of the world, you should be checking it roughly monthly anyway.
Old 10-17-2014, 12:59 PM   #264
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
If you seal the area around the hose to tank interface, are you also sealing the breather hole at the top of the tank?
JDKane527 is offline   Reply With Quote
Old 10-17-2014, 01:03 PM   #265
strat61caster
Not sure, personally just let it evaporate, top off with water and give it a flush as it gets dirty or at the recommended 60k.
Old 10-17-2014, 01:36 PM   #266
Hanakuso
His post still shows up in the quotes on this page. It was quoted twice. It's basically wrapping the hose with some teflon tape.
FRS uses a lot of coolant? JLMtm Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 124 01-23-2015 07:34 AM
Coolant Question boredom.is.me Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-15-2013 08:50 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-14-2013 12:33 AM
Alright to use 5-6 old coolant? Hanakuso Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 04-11-2013 09:47 PM
Low Coolant Tt3Sheppard Issues | Warranty | Recalls / TSB 12 11-25-2012 01:03 PM
