Old 10-15-2014, 02:57 PM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Model Citizen View Post
passenger side
DAT blood doe.....
How hard was removing them? Did that fix it??
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Model Citizen (10-15-2014)
Old 10-15-2014, 03:03 PM   #16
Model Citizen
Lacking brains
Drives: frz
DAT blood doe.....
The cut was actually from skid plate.
I ****ed around an hour or two to get them without jacking. Was way easier and less painful just to toss it up in the air and undo a mount. Ape hands don't help.
Gotta pick up replacement plugs.
Oem is it at the moment right? Least far as general local availability?
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following 2 Users Say Thank You to Model Citizen For This Useful Post:
glamcem (10-16-2014), Sportsguy83 (10-15-2014)
Old 10-15-2014, 03:04 PM   #17
Sportsguy83
Drives: Limited BRZ
As far as I know, yes....
Old 10-15-2014, 08:49 PM   #18
Model Citizen
Lacking brains
Drives: frz
No luck after changing the plugs,
on the upside, they looked reasonably due for it anyway.
Old 10-16-2014, 02:27 AM   #19
steve99
Drives: FT86
Mate I know sod all about turbo's or supercharged stuff but
You long term fuel trims at idle low RPM are about 12% in that first log.
and your AFR under light load just off idle and at idle are 11.2 seems very rich for 950rpm low load no boost.
something upsetting fueling ? air leak ,crook o2 sensor , leaking injector ?
can you log COMMANDED AFR ie what ecu is asking for as well as the measured AFR from 02 sensor ?
Model Citizen (10-16-2014)
Old 10-16-2014, 11:54 AM   #20
Model Citizen
Lacking brains
Drives: frz
You have a very good point sir.
Put the sc kit map sensor back on, flashed delicious tune, connected plumbing.
As requested:
http://www.datazap.me/u/utekineir/ne...0&data=5-41-66
Old 10-16-2014, 06:09 PM   #21
steve99
Drives: FT86
As requested:
That new log look like what I would expect LTFT is low (zero) AFT 13 or 14 low rpm low load.
So thats with stock tune and stock MAF/MAP sensors. No injector changes ?
Might point to crook map/maf sensor (or their was leak in gasket at maf sensor.
Old 10-16-2014, 08:18 PM   #22
Model Citizen
Lacking brains
Drives: frz
Right now i'm kinda starting to think fueling.
http://www.datazap.me/u/utekineir/more?log=0&data=5-12
http://www.datazap.me/u/utekineir/ne...og=0&data=5-12
take a look at the rail pressure on those logs.
Old 10-16-2014, 09:34 PM   #23
steve99
Drives: FT86
Looked at some of my logs and the fuel pressure drops to 3 or 4 at low rpm. and goes to 13 to 19 higher rpm , that is only high ressure fuel pump the low pressure port fuel pressure is not monitored
your running rich so would assume that would be due over pressure, you would think low pressure would make it lean.
that tune you have has run ok previously ?? , its not a super safe rearly rich base tune just to get you to tuner ??
Old 10-16-2014, 09:44 PM   #24
Model Citizen
Lacking brains
Drives: frz
The car has been running like a champ for months. It abruptly shit the bed mid drive the other day.
In the vein of running rich it looks to be consistently be -25 on the stft on a lot of my logs.
Spraying carb cleaner I was unable to find any sort of vacuum leak.
Old 10-16-2014, 09:55 PM   #25
steve99
Drives: FT86
looking like one of the sensors has gone, seems to be ok with stock map/maf sensors on stock tune but crook when you use the new sensors for SC tune, tune is unchanged so pointing to the sensors yu changed if i was a betting man
Old 10-16-2014, 10:05 PM   #26
Model Citizen
Lacking brains
Drives: frz
I had a spare map sensor and its been swapped in (kw sent me 2 originally).
and had a local guy come by and let me use his maf a few days ago with no change.
Old 10-16-2014, 11:47 PM   #27
steve99
Drives: FT86
ok that eliminates those.
im kind of out of ideas being on the other side of the world
all we know is its running rich suddenly on SC tune that worked previously. Stock tune no SC not rich. you have checked for leaks on input side of SC but what about on pressure side/ intercooler ect
time to send logs to your tuner
Old 10-17-2014, 07:48 AM   #28
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
Had a similar thing happen to a local guy. The way he explained it to me was that the computer that controls the injectors crapped out on him. $300 bucks to replace it.
Freeman is offline   Reply With Quote
Auto throttle / Anti stall mods discussion brn12345 Software Tuning 12 04-03-2017 07:39 PM
Loss power after gas fill up HELP! Ad8707 Issues | Warranty | Recalls / TSB 63 08-21-2014 01:01 AM
Erractic loss of power at low RPM Bg8780 Issues | Warranty | Recalls / TSB 8 05-01-2013 03:13 PM
Hi rev power loss? lbroskee Scion FR-S / Toyota 86 GT86 General Forum 3 09-29-2012 09:47 PM
CEL, Loss of Traction Light, Loss of Power pituala Issues | Warranty | Recalls / TSB 19 09-05-2012 11:23 AM
