#57 |
Drives: 04' 400whp S2000, 01' DD S2000
I came from a 2001 s2000 to my 14 brz. Did my research and the car is supposed to be rather pleasant to drive in the snow. Local owner was out in every snow storm with 6"+ of snow on the ground and never got stuck.
Invest in GOOD snow tires
2001 - Honda S2000 (Daily Driver)
2004 - Honda S2000 (400WHP widebody project car) |
#58 | |
Remember everyone, there's about a 99.9% chance that your Grandmother (or maybe Great Grandmother at this point) learned to drive in a rear-wheel drive, 3 on the tree, 4,000lb car. My first 3 cars never had a new set of tires on them. I always bought biased-ply "used tires" or "recaps" because that was what I could afford. And yes, I drove to school up-hill both ways, in snow and ice, so get off my lawn!
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
| The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (10-08-2014) |
#59 |
Drives: BMW 120d
Part of the problem is tyres are becoming more specialised. A friend of mine has had one of his cars for 35 years from new, his comment is that modern all season tyres in the snow are about as good as the cars original 'sports' tyres & if things got really bad you got your snow chains out.
| The Following User Says Thank You to stonenewt For This Useful Post: | Tcoat (10-08-2014) |
#60 | |
To stick to the "I am old theme" I remember when you options were pretty much: Summer Winter Wide or narrow whitewalls!
#61 |
Drives: '13 FR-S
Drove all last winter on the OEM bridgestones (not the primacy summer tires). Chicago's worst winter in over a decade.
It was fun, in short. The car turns and stops very well in the snow, but starting to move can be problematic if you're in unplowed over 3/4". You will get the hang of it, but it has the potential to get stuck if you don't plan ahead. Honestly, it wasn't as bad as I thought, though I have secured a set of winter tires for THIS coming year and am happy to have done so. We'll see how much better it is (spoiler alert: lots). Winter tires are amazing. They turn "not so bad" cars in the snow into tanks, and make sports cars do-able. And on the LSD thoughts? Yes, it will keep you from getting stuck spinning one tire, but in turn, it makes the car MUCH MUCH MUCH more tail happy in the snow, so it's not 100% a bonus. Open diff's are safer when moving I suppose. My main takeaway? Drifting everywhere for 4-5 months makes you a MUCH better driver, so take the opportunity to learn as much control as you can. And have fun. |
#62 | |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | Dadhawk (10-08-2014) |
#63 | |
#64 |
Drives: FRS 10 Series
| The Following User Says Thank You to khan For This Useful Post: | Ultramaroon (10-08-2014) |
#65 |
He knows he is just yanking his chain!
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (10-08-2014) |
#66 | |
Drives: 2015 FR-S
LSDs with internal clutches don't lock up completely - the maximum torque transfer is between 2 and 2 1/2 to 1, so there's still a fair amount of torque at the wheel with poor traction. But there has to be some traction in order to compress the clutches in the diff, so really slick surfaces may not allow the tire without traction to generate enough force to transfer torque to the other side. And there's a time lag for clutch engagement in the diff, so it can actually cause more skidding by engaging in the middle of a turn or a slide. A Torsen ("torque sensing") diff can transfer a full 90% of torque to the wheel with bite. It's also much faster than a clutch-based LSD and is continuously variable, unlike the other two that have to engage in some way to be effective. So a Torsen displays less of the bad behavior that plagues lockers and clutch-based LSDs on slick roads. A Torsen will be open if one wheel loses all traction, though - there has to be at least some bite for it to work (although less than most clutch-based LSDs require). There's a downside to open diffs that affects us on the track much more than on the road, but it's a consideration any time one wheel spins. One of the worst things you can do on the track is to immediately and rapidly try to pull the car back onto the blacktop if you put a drive wheel off. The wheel that's on grass is spinning as though it were on ice if you don't have a locked rear and you stay on the power. Jerking the wheel to haul it back onto the blacktop can result in sudden traction, and that snaps half shafts when the rapidly spinning wheel grabs hold of the ground under full power. FYI the right thing to do is to slow while keeping 2 on and 2 off, and then to bring it back onto the track safely while controlling the throttle to avoid wheel spin. Should you be nuts enough to find yourself in this situation with one wheel on ice, the same advice applies - but backing off in an icy turn could provoke a spin, so be careful. |
#67 | |
Drives: 2013 BRZ Sport-tech WRB
I'll agree with all of this. The torsen helps a lot when accelerating, but driving this car in the snow makes you aware that if you break both rear wheels loose (which you will) you lose all static friction laterally. It is easily controlled when the rear end breaks loose, but it does so very easily. Whether it has to do with some part of the traction control that won't disable without the pedal dance, I never encountered the situation where one wheel completely on ice would cause the diff to act like it was open. If I spun tires it was always both. Winter driving experience definitely adds a lot to driver skill. You're driving the car at its absolute limits - even if that is only 30 km/h. I really enjoy winter driving, just not in traffic. The number of people who think they don't need to switch tires AND don't think they need to change their driving style is far too high. |
| The Following User Says Thank You to navanodd For This Useful Post: | CatDaddysBBQ (10-11-2014) |
#68 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | khan (10-08-2014) |
#69 | |
I don't know if someone already fully answered this but it basically reprograms the shift patterns, not only does it just lock out first gear, but it also shifts a bit earlier just to limit your torque and throttle response. It doesn't mess with the traction control or throttle mapping or anything other than the transmission, its basically softens the throttle response and such through the gears
#70 |
Yep!
Looks like we have a new "Technical Debate Group" developing when a quick question on driving in the snow turns into a physics and advanced mechanics (Oh that is not politically correct "automotive technician") class so we need some jerks to keep the forum in balance! I promise to do my part.
| quick question about this car in snow | andrewmay9 | CANADA | 32 | 01-03-2015 04:11 PM |
| Buying FR-S. Quick Questions. | maverpl | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 03-28-2014 11:25 PM |
| Quick Release or Quick Lock Steering Wheel and Theft defense too? | 1086 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 01-24-2014 04:50 PM |
| Few quick BeSpoke questions | NOMNOM | Electronics | Audio | NAV | Infotainment | 0 | 04-17-2013 01:39 AM |
| Few quick set up questions | Im_SPEED | Tracking / Autocross / HPDE / Drifting | 14 | 08-23-2012 03:28 PM |
