CANADA Canada
Old 10-03-2014, 12:55 AM   #1
andrewmay9
Drives: 2014 scion frs asphalt
quick question about this car in snow
Im in the toronto area and our winters can get pretty bad and i have my 2014 frs as my DD so i will be taking it through the winter. Just wanted to know how this car holds up in winter with proper snow tires? I only have experience driving FWD cars in winter with all season/snow tires so a bit worried about the upcoming winter.
Also i was curious about rust-proofing. I've been told that i don't need to rust proof the car just keep it clean by washing it every other week, just undercoat the bottom with a spray which i intend to do at the end of october. Any insights on this? I came from a rust-bucket mazda which even rustproofing couldn't save.
andrewmay9 is offline   Reply With Quote
Old 10-03-2014, 07:07 AM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
This car is surprisingly good in the snow with a proper set of tires. I've had mine through two winters now. My recommendation: a cheap set of 16" steel wheels and Bridgestone Blizzaks (either the WS70 or the new WS80) in a 205/55/16 size.
I would get it rust-proofed...heavy salt use in southern Ontario. Use either Krown or Rust Check. I use Rust Check.
Old 10-03-2014, 07:10 AM   #3
jvincent
jvincent's Avatar
I'll second what @roddy said. I was fine last winter even with the shit-ton of snow we had.
I had Toyo GSI-5 in 205/55/16 on mine. Allow wheels though. No ugly steelies for me.
Old 10-03-2014, 07:20 AM   #4
roddy
roddy's Avatar
For sure the steelies are fugly, but they're durable, and touch-ups are easy...if they start to show some rust, a quick spray with some black tremclad, and you're good to go. My own personal reason for running steel wheels in the winter is that alloy wheels (especially clear coated ones) tend to develop leaks around the bead after a couple of seasons in the salt.
Old 10-03-2014, 08:23 AM   #5
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
OP please use search in CANADA subforum...many threads
http://www.ft86club.com/forums/showthread.php?t=74317
http://www.ft86club.com/forums/showthread.php?t=49559
http://www.ft86club.com/forums/showthread.php?t=57277
http://www.ft86club.com/forums/showthread.php?t=55047
http://www.ft86club.com/forums/showthread.php?t=57498
http://www.ft86club.com/forums/showthread.php?t=50899
http://www.ft86club.com/forums/showthread.php?t=56581
drewbot is offline   Reply With Quote
Old 10-03-2014, 08:45 AM   #6
that_guy
Dances with Cones
that_guy's Avatar
Drives: 2013 Scion FR-S Raven
I ran mine for 2 seasons on Conti Extreme Winter Contacts because they were non-directional unlike the Blizzaks allowing me to rotate them around the car and keep wear even - especially important on a lowered car. Mine were mounted on steelies and I simply sprayed the wheels and welds with rust proofing cavity wax to prevent rust. Worked great.
The car is exceptional in winter if you drive smart. Never drive in winter on all-seasons or summer tires.
2013 Scion FR-S - Raven
2011 Scion tC - Cement - SOLD
that_guy is offline   Reply With Quote
Old 10-03-2014, 09:09 AM   #7
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
It will be the most fun you ever had in snow...and on 4 wheels
Rayme is offline   Reply With Quote
Old 10-03-2014, 09:22 AM   #8
1Cor10:23
1Cor10:23's Avatar
Good tires as suggested by everyone will serve you fine. Just use common sense - if it's really bad out, don't drove. I drive mine last winter and found that I felt more confident driving in the snow in VSC-Sport; nannies kicked in a lot less so the car was more predictable. The worst is when it starts kicking in when you're turning at an intersection. It's better to have a predictable slide then having no idea when it might decide to do some uneven stabilization.
Old 10-03-2014, 09:48 AM   #9
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
My WRX is way more fun in the winter...
Still a great car for fun in the winter.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 10-03-2014, 11:00 AM   #10
D_Thissen
D_Thissen's Avatar
Mine survived a winter in NW Ontario (Thunder bay to be exact). With winter tires (General Altimax Arctics 205/55/16) I never got stuck once!
Old 10-03-2014, 11:23 AM   #11
Kazuya
Kazuya's Avatar
Drives: Takumi
Rule of thumb for me after the hell on earth last winter is, if you're plowing, you ain't driving.
Kazuya is offline   Reply With Quote
Old 10-03-2014, 12:35 PM   #12
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Finally someone that didn't write funner.
krayzie is offline   Reply With Quote
Old 10-03-2014, 03:33 PM   #13
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
I had a WRX and I respectfully disagree.
Old 10-03-2014, 03:39 PM   #14
BRZZZZZZZZZZ
Car Nut
I'm willing to bet your WRX did not have a welded rear diff and front LSD installed+other goodies.
Snow tires question Kelbyat07 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 12-08-2013 09:19 PM
New guy with a quick question Bullnettles Engine, Exhaust, Transmission 28 05-09-2013 12:03 AM
Quick Question geb2391 BRZ First-Gen (2012+) — General Topics 2 04-07-2013 11:41 PM
Quick Question??? soontobrz BRZ First-Gen (2012+) — General Topics 12 12-16-2012 11:02 AM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 09:53 PM
