Old 08-23-2012, 12:49 AM   #1
Im_SPEED
Drives: FRS hot lava
Few quick set up questions
So i finally pulled the trigger and picking up a used frs. Going to jump right in and start my ST? Prep with coil overs and rims and tires im set on a 8" wheel running 245/40/17 or the 245/35 r1r. Im going with bc racing coil overs i loved them on my stc celica out od the box spring rates are 8k/8k sould i go custom like 8k/7k or what open to opinions. And second are the upgraded shift springs worth the extra 300$. And the most important question of them all what color numbers sould i run. Its a hot lava frs with a black roof. I have blue with silver outline now but i was thinking blackwith silver.
Im_SPEED is offline   Reply With Quote
Old 08-23-2012, 12:52 AM   #2
ayau
Drives: Some rust bucket
have you tracked the car yet? you'll want to know what the car's limits are before dumping money into it.
Old 08-23-2012, 01:27 AM   #3
Im_SPEED
Rubish.. i dont see the point if it changes when ever you start swaping parts and goofing with the alignment.
Old 08-23-2012, 02:00 AM   #4
dsgerbc
Drives: BRZ(sold), STI
obvious troll is obvious.
/ban
dsgerbc is offline   Reply With Quote
Old 08-23-2012, 02:14 AM   #5
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
dont feed the troll!!!
86_ZN6 is offline   Reply With Quote
Old 08-23-2012, 07:29 AM   #6
celica73
Drives: '13 BRZ / '11 Outback / '06 Tundra
I'd go with the 8k rates until you know you want something different. Seems like as good a starting point as the next.
I doubt you want to shorten the gearing with the 245/35 tire, unless you plan to raise the redline or generally have tight courses in your region.
It's pretty clear the "troll" people don't actually read posts, or know what an "STC Celica" is. I'm coming from a 7th gen Celica myself - I got 12 great years (bought it in Oct '99) and a lot of autocross runs out of that car.
celica73 is offline   Reply With Quote
Old 08-23-2012, 08:12 AM   #7
Im_SPEED
Originally Posted by celica73 View Post
I doubt you want to shorten the gearing with the 245/35 tire, unless you plan to raise the redline or generally have tight courses in your region..
Good point i always forget about the little detail. Never had to worry about that on the celica 64mph in second was always good enough.
Old 08-23-2012, 08:21 AM   #8
mla163
Overthinking it
Drives: BRZ in CS
You bought a used 2013 FRS?
mla163 is offline   Reply With Quote
Old 08-23-2012, 08:35 AM   #9
Im_SPEED
Yes got it from a friend of a friend it was good deal was holding out for a brz but it was a GOOD deal.
Old 08-23-2012, 10:44 AM   #10
mla163
Overthinking it
Drives: BRZ in CS
If you are serious, read Scooby South's build thread.
R1Rs are the wrong tire. They are best on light cars. Look at RS3s, Starspecs or similar. You should get a wider wheel than 8" and as wide a tire as possible.
BC racing is crap IMO. I'd look at AST, KW, or whatever RCE is working on.
Old 08-23-2012, 11:19 AM   #11
des
des's Avatar
Did you buy Annie's car? Loved that black roof on it.
If you're coming from FWD, not sure I would touch anything except tires for a bit. Good luck!
des is offline   Reply With Quote
Old 08-23-2012, 11:27 AM   #12
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
I don't think anyone knows what spring rates for sure and naturally that will be affected by your sway bar strategy. You would still have a lot of other things to do to get power up and weight down.
TomR
ABQautoxer is offline   Reply With Quote
Old 08-23-2012, 02:24 PM   #13
Im_SPEED
yes i bought Annie's car i havent seen it in person yet getting it Saturday but im sure it looks bad ass. and im thinking hard about doing what you are saying just holding off and run stock but rims and tires but i will still be lightly preped in an ST class.
i have read that thread i got alot of good info off of it.
as for the R1R i mostly race on an old tri oval and the r1rs stick good to that surface and stick when they are right off the bat and you dont have to wait for them to get super hot like my old Kumho XS but im may go with rs3 next if i dont like the r1rs on this car. ok i will look into the other coilovers like is said the bc racing worked great on the Celica
thank you for your replays and not being concerned about the dietary habits of a mythical creature.
Old 08-23-2012, 02:36 PM   #14
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Annie and her car ADHD is famous. I sold her an Integra Type R a few years back, one of her very many.
Quick use of FR-S after debadge Tdooley Cosmetic Modification (Interior/Exterior/Lighting) 2 08-17-2012 01:14 AM
Some quick shots Memphis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 9 06-30-2012 05:09 PM
quick SWP BRZ shots (+ FXT) illmatic BRZ Photos, Videos, Wallpapers, Gallery Forum 11 06-12-2012 10:18 AM
