Northwest AK, ID, OR, WA
Old 10-07-2014, 02:51 AM   #309
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
wow i bought pics and can't download them
@digital_assassin @torqdork
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
Old 10-07-2014, 10:45 AM   #310
torqdork
torqdork's Avatar
Drives: RV-7
#4 for the FIA curb shot. Plus I got to say FIA again.
torqdork is offline   Reply With Quote
Old 10-07-2014, 12:35 PM   #311
torqdork
torqdork's Avatar
Drives: RV-7
Old 10-07-2014, 12:59 PM   #312
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by Decay107 View Post
If there is anything that ORP taught me this year, it's how to deal with camber change!
My takeaway from AROO was the effects of trail braking on our cars. I started applying it tentatively for the first time and found how relatively easy it was to rotate the car without too much drama at least on a flat surface like T1 and T2. I didn't attempt it on other turns but became confident, consistent, smoother and maybe even a little quicker through the chicane by day's end using trail braking. Reliable, predictable brakes helped. Never had any fade from the Carbotech XP10's and Motul 600.
Old 10-07-2014, 01:50 PM   #313
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
@torqdork Yes, I was playing around a bit with trail braking T1 and T2 last time I was out, but was a little too unsure of my brakes at AROO to explore further. That being said my biggest take away was dealing with fading brakes, which I hadn't experienced in earnest until this past weekend.
Decay107 is offline   Reply With Quote
Old 10-07-2014, 02:01 PM   #314
thehapaone
Wasian Ninja
thehapaone's Avatar
My takaway was that I need real brakes to get the most out of my car...burning through a nearly new set of pad is no bueno and probably explains why I lost it at the chicane once and nearly a couple other times. Ordering some Project Mu HC800s to hopefully fix this problem
Old 10-07-2014, 02:39 PM   #315
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
If you're gonna track it often, a BBK will save you $ in the long run. That will be my next big project. BBK/Cooling/sways & braces for the winter. Now the only question will be hold off having a kid so I can rebuild the engine for more boost.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 10-07-2014, 02:55 PM   #316
Decay107
Decay107's Avatar
Not sure I'm quite sold on BBKs being a better value yet, from my calculations it would take at least 10 years of HEAVY (like 2-3 times per month heavy) tracking to allow the minimal cost difference in replacement pads and rotors to make up for the cost of the kits. For me it's going to be a replace on failure part. Once I burn the dust boots and cook the seals in my OEM calipers it will be time to look at the the AP sprint kit. Also Everything I have read indicated that the rear OEM set up is more than sufficient for just about any level of abuse.
Old 10-07-2014, 03:53 PM   #317
thehapaone
Wasian Ninja
thehapaone's Avatar
I agree on that my rear brakes to little to no damage from the track even though my fronts went from 8mm to 0mm...Debating on what to run now as I want a track duty pad that won't kill me on the streets (rated 0-x not more than 0 to x) Project Mu HC800s seem to be the sweet spot for me but vendors are saying they are backordered right now
Old 10-07-2014, 05:06 PM   #318
digital_assassin
digital_assassin's Avatar
Drives: 2013 FR-S Matte Orange
My dust boots were melted off the weekend before last. Completely melted off.
digital_assassin is offline   Reply With Quote
Old 10-07-2014, 05:12 PM   #319
torqdork
torqdork's Avatar
Drives: RV-7
I actually started the day wanting to work on late braking with higher initial pressure, lightening before and during turn-in. On the first attempt I got both wrong and was a little hot entering T1 with trail brake. That's when I experienced a quicker rotation and had to counter steer in both T1 and T2. After that I kept trying other T1 braking points until finding the sweet spot while working staying with trail brake.
So much to work on, I'm thinking about attending a driving school in CA early next year using their track prepped sports cars at a modern facility with quality instruction. Expensive, but in the long run might be cheaper than a couple of seasons in my cars with no consistent instruction.
Old 10-07-2014, 05:33 PM   #320
Decay107
Decay107's Avatar
My dust boots were still there as of last Friday (not sure of condition though). We'll see how they look when I swap pads out this weekend.
Old 10-07-2014, 05:47 PM   #321
digital_assassin
Eddie said as soon as you run a hot session you'll cook'em but it's nothing to worry about. He said not to bother rebuilding, just let them go.
Old 10-07-2014, 06:20 PM   #322
BRZPDX
Boosted Member
BRZPDX's Avatar
what are the dust boots for? So no worry's if they melt off?
hpde, racing, track, track day
Portland Raceway Track Day for PDX86ers in September 6th for beginners and up stockysnail Northwest 83 12-02-2013 12:01 PM
September 4th Import night at Portland International Raceway. Car show, Drag races, + stockysnail Northwest 12 09-12-2013 02:35 AM
Some fun at Portland international raceway! FRSfan111 Tracking / Autocross / HPDE / Drifting 0 09-07-2013 11:31 PM
Portland Raceway Track Day for PDX86ers in August 9th for beginners and up stockysnail Northwest 106 08-15-2013 01:13 AM
SCCA - Portland International Raceway Thatruth2001 Northwest 8 10-08-2012 01:17 AM
