Old 10-05-2014, 06:48 PM   #1
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Corroded pins/connectors in light harness
I am trying to replace some extremely corroded connectors in a harness for a DRL light strip. (this one: http://www.ft86club.com/forums/showthread.php?t=25959)
I bought the kit second hand, but stupid me, didn't ask for more pictures of the connectors and didn't think road salts would be so devastating on supposedly weather sealed connectors. I learned my lesson, I just want to fix it up so I could use this.
The female terminals:
The male terminals:
Does anybody know what these things are called and where I can buy them? I'll probably need 4, to repin/terminate all the connectors. Thanks in advance for any help or advice.
*EDIT* After some more digging based off of @jonzhuxD's suggestion, I have found the actual datasheet for the connectors and housing. Check it out:
http://www.seaps.com.sg/pdf/b_mt_e.pdf
aegisdrgn is offline   Reply With Quote
Old 10-05-2014, 09:01 PM   #2
putter
Drives: 2014 Subaru BRZ limited
Go to radio shack purchase a spray can of gold connector this product will clean and seal your present connector without replacing product cost about $20.00.
putter is offline   Reply With Quote
Old 10-05-2014, 09:31 PM   #3
aegisdrgn
aegisdrgn's Avatar
Unfortunately, I didn't take a picture of the REALLY corroded connector. The rounded tip on the worst one has broken off and it no longer makes a connection to the female portion, so I need a new one.
Old 10-05-2014, 11:29 PM   #4
jonzhuxD
Drives: Ultramarine FR-S
They're Denso connectors. Here's a link to some, might be able to find them cheaper, I just grabbed the first link on eBay.
http://cgi.ebay.com?ViewItem&item=400778203186
jonzhuxD is offline   Reply With Quote
Old 10-06-2014, 12:12 AM   #5
aegisdrgn
aegisdrgn's Avatar
that's exactly it! Thanks a lot! Now to find a cheaper version...
Old 10-06-2014, 08:04 AM   #6
Chimera
Drives: FRS
CocaCola will remove the corrosion, you can use a variety of protection products, I use the battery stuff myself.(its red.. idk what its really called)
you can clean corrosion like that with coke about 3 times before the terminal will become useless in my experience.
OEM Tail light connectors aschnell Cosmetic Modification (Interior/Exterior/Lighting) 12 11-02-2021 03:02 PM
BRZ Radio Breakout Harness and/or Pins and Sockets nquillen Electronics | Audio | NAV | Infotainment 4 06-22-2014 10:40 PM
Fog Light Harness mit_peid Cosmetic Modification (Interior/Exterior/Lighting) 5 06-20-2014 02:39 AM
Fog light harness? Perry Cosmetic Modification (Interior/Exterior/Lighting) 2 11-04-2013 03:32 PM
Foglight Harness Pins for sale FRSHunter Hawaii 3 08-22-2013 12:29 AM
