Old 10-03-2014, 11:11 AM   #743
cnk
Drives: '13 DGM BRZ Limited
Originally Posted by ScionFrsFan View Post
Help!
http://www.datazap.me/u/scionfrsfan/...6?log=0&data=1
Can someone please check this out.
Recently my check engine light came on, code P0456 (Evaporative Emissions System)
The car seems to runs fine. I do notice on start ups the rpm rises then drops right away, then starts to idle steady.
My car is STOCK. I am running stage 2 EL E85 V2.06. Weather is starting to get a little bit colder, not sure if that has anything to do with it. Is E85 causing the problem? I'm not exactly sure what to look for, can someone check my data to make sure engine is okay!
I checked gas gap (silly stuff), so far light has come on 3 times. Once a few weeks ago, the last two within a week.
Thank you !
Why are you running a stage 2 EL map if your car is stock?
Old 10-03-2014, 11:16 AM   #744
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
E85
Old 10-03-2014, 11:19 AM   #745
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
Don't worry, no key
This is what happens when you flash with no pants.
Old 10-03-2014, 11:24 AM   #746
cnk
E85
Thanks. . found the link about running that map on a stock car. . personally I still wouldn't do it, but it's his car so whatever.
P0456 is an evap leak so it's most likely your gas cap. Make sure the rubber o-ring is there and that you hear the cap click when you close it.
Old 10-03-2014, 12:39 PM   #747
s2d4
s2d4's Avatar
Originally Posted by Wayno View Post
Don't worry, no key
Hahah, I did that once too.
Old 10-03-2014, 06:56 PM   #748
steve99
Drives: FT86
Don't worry, no key
Dont put your running laptop on top of or near your key fob on the seat either did that the other day after flash and scared myself as car woud not start, it blocks/interfers with signal from key fob
Old 10-03-2014, 07:03 PM   #749
steve99
Drives: FT86
Help!
Thank you !
check gas cap is tight and as someone else said the ring is good and that when you open gas cap after car has been in sun you get a pressure release as tank should be a sealed circuit, if no pressure release indicates a leak in system check lines under bonnet to evap canaster are all good ect. if it persists g back to petrol and take it to dealer under warantee, some of those lines are under intake manifold and it ight actually be a prolem with the purge valve , also chech evap canister for cracks
your log looks ok , bit of knock arround 2000 rpm caused iam to drop to 0.98, and fuel trims look a bt high around 10% was that first tank of e85 ? with soe resdua petrol
Old 10-03-2014, 07:42 PM   #750
ScionFrsFan
I played with the gas cap but it nervousness that my datalog isn't looking good.
I have been running E85 for awhile now, I flashed to V2.06 a few weeks ago. When I was running V2.0 Beta I never had the light pop on. The light only pops on when I start car...never when im driving.
Thank you!
ScionFrsFan
ScionFrsFan is offline   Reply With Quote
Old 10-03-2014, 10:27 PM   #751
steve99
Drives: FT86
Thank you!
there is nothing rearly bad in that log just a bit of minor knock and fuel trms a bit high but all still within safe limits .
there was no changes between v2 beta and non beta car may have just deveped a fault
ScionFrsFan (10-04-2014)
Old 10-04-2014, 01:20 AM   #752
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
updated to 2.0, installed the new xml files and reflashed my car, but whenever i plug in the oft i cant view the live data on the OFT. It just stays on connecting to cars ecu. Anyone got an idea?
bkblitzed is offline   Reply With Quote
Old 10-04-2014, 02:41 AM   #753
steve99
Drives: FT86
read oft tips link below.
you need to download the new template file from the oft downloads page and manually apply it as per instuctions on oft downloads site. also lt the oft update via internet and make sure your on open flash manager 11.1.1 as per downloads page, then all will be good. Their was a heap of oft interface updates
Old 10-04-2014, 05:00 AM   #754
bkblitzed
is better than you
bkblitzed's Avatar
ah missed that k cool thanks
Old 11-08-2014, 10:28 PM   #755
Cuse
Drives: Brz blue series
Where can i find the DL for CAl ZA1JD00C? Ive been looking for it for quite sometime and can't find it
Cuse is offline   Reply With Quote
Old 11-09-2014, 09:02 AM   #756
akyp
Drives: 2012 86
I have recently installed a P&L catted EL header. Running OTS Stage 1 I am getting considerable FLKC: http://www.datazap.me/u/akyp/2014110...=0&data=1-4-14
Already pulled some timing following instructions in this thread: http://www.ft86club.com/forums/showthread.php?t=61820
The only change was the header (did reset ECU prior to installation). Thoughts? Am I even using the correct map?
akyp is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
