Old 09-06-2013, 09:06 PM   #15
goke186
From doing some digging it looks like the plugs are a PITA to change but not impossible, I am thinking about going with lower temp plugs if i can. I will be contacting my service manager and having a talk. The minute I heard that they were required to change at 30k i was suspicious and looks like I was right to be.
FIVE AXIS DESIGN http://www.fivead.net (FIVE:AD Edition Ultramarine FR-S)
VTR http://vtrweb.com/ (Reccomended Pacific NW Shop!) [CLOSED]
AVO Turbo http://www.avoturboworld.com (Great Products for a Great Price!)
goke186 is offline   Reply With Quote
Old 09-06-2013, 11:40 PM   #16
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Originally Posted by goke186 View Post
From doing some digging it looks like the plugs are a PITA to change but not impossible...
Oh shit. It just occurred to me where the spark plugs are on this car. This is my first boxer engine.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-08-2013, 10:06 PM   #17
goke186
@Anthony, yep... they are on the sides of the engine and not the top like we are used to lol. It wont be cheap but im betting a regular shop will still charge a bit less than the local Stealership
Old 09-08-2013, 11:12 PM   #18
Anthony
Weight Nazi
Anthony's Avatar
Oh I'll be doing them myself unless you have to have some sort of crazy ass tool to do it. Which I doubt you do.
Old 09-14-2013, 03:49 PM   #19
stugray
Drives: 2013 GBS BRZ Limited
You have to jack up the engine 2 inches.
Even the dealer doing it in 2 hours sounds a little fast.
Old 09-14-2013, 11:38 PM   #20
Anthony
Weight Nazi
Anthony's Avatar
I can do that. So you have to unbolt the engine from the mounts and then lift it 2 inches?
Old 09-15-2013, 12:15 AM   #21
alex_86
alex_86's Avatar
Drives: 2013 scion firestorm frs
Originally Posted by Marchy View Post
30k for plugs, that dude is on crank. A pig rich turbo car plugs are good for 60k. Did the 500 for plugs and other misc include labor? I am curious how long that job is rated to take.
30k is rated at 4hrs on average and in this case including the plugs i assume. that is with the OP's dealer.
alex_86 is offline   Reply With Quote
Old 09-15-2013, 12:16 AM   #22
alex_86
alex_86's Avatar
lol sir, it could be done in about 130. that's including the whole 30k plus plugs.
Old 10-03-2014, 11:22 AM   #23
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
I'm at 27,600...and will be taking my car in at 32k because I went a little past on my previous service.
I just got off the phone with them and they told me it would be $659 for the 30k service. Some of the things involved in the service include oil change, change cabin filter, rotate tires, change brake fluid, something with rear differential fluid, and I think that's it.
I'm not very savvy with car maintenance, so can someone explain if changing the brake fluid and differential fluid should be $659? All the other things mentioned I know are super simple. What I'm trying to avoid is paying $650 for something I can get done for $200 somewhere else.
ericmpena is offline   Reply With Quote
Old 10-03-2014, 12:18 PM   #24
Kody
Drives: 2013 Subaru BRZ
IMO, you're getting ripped off simply because you can do most/all of this stuff yourself for less.
If you buy a jackstand and jacks, then the right fluids for the various changes (engine, transmission, diff) you'd end up spending less money and have tools left over that you can use for the life of the car.
Just look up DYI's for this stuff and you'll see how easy (and relatively cheap) most of it is. Plus you'll have the satisfaction of knowing that it was done right.
Kody is offline   Reply With Quote
Old 10-03-2014, 07:17 PM   #25
ericmpena
ericmpena's Avatar
I wasn't sure how involved any of this would be. If you think I should be able to DIY without putting myself at risk for screwing it up then I'll give it a shot. I just didn't trust myself messing around with transmission or brake fluid. Last thing I want is for my brakes not to work because I messed something up!
Old 10-03-2014, 07:23 PM   #26
themajesticone
themajesticone's Avatar
Drives: '13 UM86
You can't put the car on a lift and change the plugs from underneath?
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 10-03-2014, 08:59 PM   #27
ericmpena
ericmpena's Avatar
Are you asking me if I can do it, or if it's possible to change them from underneath?
I read that you gotta lift the engine or something. Read through this thread and I'm pretty sure someone said you needed to lift the engine.
Old 10-03-2014, 09:57 PM   #28
themajesticone
Drives: '13 UM86
I am asking, in general, if it is possible to change them while underneath if the car is on a lift. I have heard the same with boxer engines where you have to lift the engine, but I am pretty sure you do not have to in order to change the plugs. Might just be another method is all
BRZ + Supercharger = ??? 1/4 mile girlracer Forced Induction 38 09-11-2014 11:28 AM
My first 100 mile impression bdbx18 BRZ First-Gen (2012+) — General Topics 20 12-12-2012 11:42 PM
1000 mile break in service for BRZ? Tonym427 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 08-27-2012 03:00 PM
7500 mile service done. 30k will suck. FRSpdDmn Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 36 08-09-2012 09:34 AM
Standing Mile _hollywood Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 02:33 AM
