Old 07-24-2012, 06:08 PM   #1
FRSpdDmn
Drives: 128i, Z3 Coupe, Fiero GT
7500 mile service done. 30k will suck.
Just took my car in for its 7500 mile service. Yeah, that would be 1000 miles per week for me since I got it! The service wasn't an issue, but the service manager and I talked for a while and he told me something.... unfortunate.
A spark plug change is required at 30,000 miles (see edit below). Now, of course, Scion Service Boost runs out at 25k. But here's the kick in the nuts... The engine must be lifted in order to access and change the plugs! I looked down at the head and, sure enough, its right up next to the frame rail. Now, I don't know how much will need to be disconnected in order to do this, but I would say that the engine will need to be lifted about 6" to gain access. While I can access an engine hoist, this sounds like the suck for normal maintenance. This will likely be a $500 service at the dealer...
EDIT: Dealer was apparently wrong about the 30k service. Plugs are changed at 60k according to the manual.
-Anthony
Former '13 Whiteout FR-S, BMW 128i, BMW Z3 Coupe, Pontiac Fiero GT
2017 Pirelli World Challenge TC Rookie of the Year
2012 NASA SpecE30 National Champion
www.DriveFasterNow.com
FRSpdDmn is offline   Reply With Quote
Old 07-24-2012, 06:11 PM   #2
KaliKev
FT86 News Addict
KaliKev's Avatar
Drives: Toyota FJ
wow!
KaliKev is offline   Reply With Quote
Old 07-24-2012, 06:13 PM   #3
bakerr6
Drives: 2013 raven black fr-s
I live in cincy, if you need, we can tackle this together
bakerr6 is offline   Reply With Quote
Old 07-24-2012, 06:18 PM   #4
D1cker
Drives: B9 S4/ND2
I knew the engine had to be lifted, but I didn't know we were going to do it as early as 30k!
D1cker is offline   Reply With Quote
Old 07-24-2012, 06:18 PM   #5
Snoopyalien24
Mr. Sarcasm
Snoopyalien24's Avatar
What?? Aww man, that sounds terrible. So approximately every 1 1/2 - 2 years this...
Snoopyalien24 is offline   Reply With Quote
Old 07-24-2012, 06:19 PM   #6
FRSpdDmn
Hopefully my travel will die down and this at least won't be until next year!
-Anthony
Old 07-24-2012, 06:22 PM   #7
bakerr6
haha mine wont be until next year, but I have access to a little more help than you do it sounds. Luckily, the father-in law is a diesel mechanic, and has access to a lot of tools/knowledge that I do not possess
Old 07-24-2012, 06:23 PM   #8
nquillen
Drives: SWP BRZ
I believe that it manual says every 60,000 for replacement.
http://www.cars101.com/subaru/brz/br...ml#maintenance
At least that's what it says for the BRZ, with iridium plugs you should be able to get at least 90k
nquillen is offline   Reply With Quote
Old 07-24-2012, 06:24 PM   #9
bakerr6
Gives me a good reason to check/replace anything that looks worn. The other benefit is, that you could remove the engine to do some upgrades at the same time.
I bet scion made the engine either easy to lift/remove from the engine bay to facilitate this normal maintnence.
Old 07-24-2012, 06:24 PM   #10
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
Is this really true? 30k!!!! What the hell is the reason for that when most cars are good for 100k.
DrDuquette is offline   Reply With Quote
Old 07-24-2012, 06:26 PM   #11
SkullWorks
Drives: SSM LT MT BRZ
My car is gonna do so much dyno/R&D (actual R&D) that I was planning ondrilling thru the frame rails and welding pipe back into the holes so I have access to change plugs, since we all (should) know that the stock heat range wont hold out beyond a couple PSI for boosted applications.
SkullWorks is offline   Reply With Quote
Old 07-24-2012, 06:35 PM   #12
FRSpdDmn
You're right. The service manager told me 30k. I will have to consult my owner's manual, but I can't imagine why the FR-S would differ from the BRZ.
-Anthony
Old 07-24-2012, 06:43 PM   #13
Mr. Mcoupe
Mr. Mcoupe's Avatar
Drives: ExigeS,M3,S2k,MCpe,MR2T,T4R,Sienna
Something does not sound right or left.
Current: 19 GT-R[]17 M2[]17 WRX[]14 T4R[]12 NV2500[]07 Exige S[]07 S2k[]05 M3[]03 M3[]02 MCoupe[]94 MR2T[]93 MR2 T[]92 MR2 T[]91 MR2 T[]95 SC400[]
Gone but not forgotten: 04 STI[]05 MR2 Spyder[]04 S2k[]03 IS300[]90 MR2[]
Mr. Mcoupe is offline   Reply With Quote
Old 07-24-2012, 07:06 PM   #14
Lonewolf
Lonewolf's Avatar
Drives: Moped
Manual says 60K...Look on page 75 of the service manual overview
1/4 Mile times Boosted2.0 Tracking / Autocross / HPDE / Drifting 368 02-13-2021 07:52 AM
1000 mile break in service for BRZ? Tonym427 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 08-27-2012 03:00 PM
7500 mile review. Superhatch BRZ First-Gen (2012+) — General Topics 16 07-23-2012 03:43 PM
Standing Mile _hollywood Scion FR-S / Toyota 86 GT86 General Forum 5 07-16-2012 02:33 AM
Why do all fourm mods suck (except these ones) LexusFman Off-Topic Lounge [WARNING: NO POLITICS] 15 02-15-2012 09:30 AM
