Old 09-18-2014, 01:48 PM   #379
TheBatman
TheBatman's Avatar
Drives: Scion FR-S 10 Series
Originally Posted by CARNZ View Post
The AT upper oil pan is different and has that fitting molded into it. They didn't want to make it super easy...
I had originally considered buying the different upper pan/lower block, but decided it wasn't worth the money vs just installing a fitting.
Ah now that's annoying. I can't imagine how it is more cost effective to have different lower blocks especially when that plug is already there... What exactly is that plug even supposed to be used for??
TheBatman is offline   Reply With Quote
Old 09-18-2014, 05:59 PM   #380
CARNZ
CHECK ENGINE
Drives: 2004 STi
manufacturers do some strange things sometimes
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 09-21-2014, 02:26 AM   #381
PhoKingCool
PhoKingCool's Avatar
Thanks for putting together this write up!
PhoKingCool is offline   Reply With Quote
Old 10-02-2014, 05:07 PM   #382
Philly758
Drives: GMC
Is there any disadvantage to using the throttle body lines instead? This install seem a lot easier and I don't need to make a mess with coolant and buy 1-2 gallons from subaru to replace it all.
I have also probably had my parts for 6 months now and haven't installed them. If I just use the TB lines it would be done this weekend...
Philly758 is offline   Reply With Quote
Old 10-02-2014, 10:51 PM   #383
Kostamojen
I'm no Engineer but I won't recommend the throttle body route to anyone. My goal with this was to replicate the OEM setup, using the coolant channels designed for this. I've been running on mine for almost a year now zero issues.
Old 10-03-2014, 01:25 AM   #384
Trac Toy
Trac Toy's Avatar
Do what you want bud. This thread has been here a while and most options have been discussed. Factory routing is the best. If it was better to use the throttle body they would have.
.o0+Eric+0o.
2016 Chrysler 200S 3.6
2013 FRS 6MT
Trac Toy is offline   Reply With Quote
Old 10-05-2014, 12:59 PM   #385
sickmint79
Drives: bmw
what's the negative with the throttle body?
sickmint79 is offline   Reply With Quote
Old 10-06-2014, 02:27 AM   #386
Trac Toy
Trac Toy's Avatar
Not enough coolant flow to be effective.
.o0+Eric+0o.
2013 FRS 6MT
Old 10-06-2014, 02:43 AM   #387
EZx2
Drives:
1. Did somebody compared 2 methods (throttle vs. stock on turbo).
2. May somebody post routing stock-like , with heater hoses (easiest possible way) ?
Thanks
EZx2 is offline   Reply With Quote
Old 10-07-2014, 04:40 PM   #388
Philly758
Drives: GMC
The post at the top of this page shows real-time oil temperature analysis under normal driving conditions, with this cooler installed off of the throttle body. Appears to be effective. Maybe the original/OEM routing is slightly better, but this will definitely help keep temps down.
Originally Posted by TIE Pilot View Post
Good info:
-Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install
http://www.ft86club.com/forums/showthread.php?t=72961
You can get this for < $200
http://www.ft86club.com/forums/showpost.php?p=1945226&postcount=40
I could always use the throttle body for the winter and change it out for the OEM routing in the spring if I am motivated.
Old 11-24-2014, 05:20 PM   #389
toeout
Just ordered this setup From Heuberger Subaru. Ordered 14:30, got an email that my order shipped at 16:30.
toeout is offline   Reply With Quote
Old 11-24-2014, 08:09 PM   #390
nunonuna
nunonuna's Avatar
I'm planning to install this OEM cooler, but trying to replicate the Cusco set up. I will post details about it if anyone is interested.
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
FLYFISHR (11-24-2014)
Old 11-26-2014, 05:24 PM   #391
nunonuna
nunonuna's Avatar
Originally Posted by Model Citizen View Post
image by utekineir, on Flickr
I wish I saw your this post before I did this~ LOL
Part cost I paid was about same but I had to bore 1/4 npt thread because adapters I found only had 1/8 npt. Tapping new bigger thread on existing smaller thread for the first time was PITA.
Oh and I got the open box deal on mishimoto hose kit for 50 bucks only~
Only the box was open, but the hoses were in original sealed plastic bag.
Old 11-27-2014, 03:55 AM   #392
nyfries
Drives: 14 FRS Whiteout
Oil cooler is legal for STX in 2015. Time to give this a thought. Plan to build a track/stx autox car. How does this hold up on a NA car in track day? Sufficient or leave something to be desire? Any clearance issue for those with grimmspeed intake? It look like it will be tight if not impossible.
Sent from my iPad using Tapatalk HD
nyfries is offline   Reply With Quote
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
