Old 09-29-2014, 05:01 PM   #15
FirestormFRS
Originally Posted by Poodles View Post
Oil catch can doesn't increase longevity...
If changing the oil was good for the engine, we'd be seeing lower oil change intervals, not longer. In fact there's an SAE paper on how changing oil too often can lead to increased wear as it takes time for the additive pack to activate and work to protect the motor.
So you never change your oil? 7500 mile intervals are recommended...I'll stick to my change the oil statement. As for the "mods" I'm pretty sure a normally driven car would never need any mods to last a very long time. There are lots of bone stock vehicles with 300k+ miles on the original driveline. They probably aren't driven by asshats though
FirestormFRS is offline   Reply With Quote
Old 09-29-2014, 05:51 PM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Exactly.
If one were driving it normally, regular care will make the car last a long time.
If one were to drive it aggressively or take it to high RPMs often, you'd need things like oil coolers, catch cans, etc to improve longevity.
Mods need to reflect the owner and the driving conditions, it should not reflect a glaring need on the car.
-alex
Old 09-29-2014, 06:58 PM   #17
Poodles
Drives: 2015 Series.Blue
Changing the oil filter is more important than changing the oil itself. I know someone that runs oil analysis and redline oil that changes the filter ever 5K miles, takes the oil sample, and then tops the oil back off. He's done this for a few years now and the oil analysis still shows the oil is fine. Not in this car, but you get the point.
Also oil change interval was changed to 6K miles for 2015.
Originally Posted by mav1178 View Post
Exactly.
-alex
Lets be honest here, the car is a performance focused sports car, it's GOING to be driven aggressively. This isn't a Camry...
Old 09-29-2014, 07:33 PM   #18
mav1178
mav1178's Avatar
While I would love to agree, I also want to be realistic to the OP because the question itself sets up the wrong type of answer.
And I do know two original owners of a Nissan 240SX, both bought by ladies in their early 20s who still own the same car 20+ years later. Neither one of them is driven hard and I can see tons of young adults driving this car daily without pushing it.
Or just look at all the original owners of a Miata. There's a lot of them as well.
-alex
Old 09-30-2014, 12:17 AM   #19
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Calum View Post
Get a tune. Seriously, most of the tunes I know of run less knock than the factory tune.
Aside from that, use good fluids and change them often.
This brings to question the amount of knock the factory tune sees with 93 octane fuel, or whatever Japanese premium grade fuel they used to test this car at Subaru versus 91 CA piss water. Is a tune really that beneficial when the intended grade of high octane fuel is being used? Or did Subaru engineers really drop the ball on the tune.
I hear the the MY15 WRX also knocks quite a bit on 91 octane fuel.
Old 09-30-2014, 08:48 AM   #20
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
It's early here...but are people really arguing an aftermarket tune helps the longevity of the engine?
What is this I don't even....
Old 09-30-2014, 10:11 AM   #21
stugray
Drives: 2013 GBS BRZ Limited
At least for the MY 2013 BRZs, the factory will not put on a ROM that addresses the DI seal issue (transient timing advance).
So unless you want blown DI seals, you need to get a tune that corrects the problem.
Toyota will fix the 2013 FR-Ss, SOA will not.
Old 09-30-2014, 10:47 AM   #22
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Stay stock and follow the user manual's suggestions. No tuner or after market company has tested their changes in your car like the factory. They don't care so much, because they don't have a warranty to chase them. Even if they wanted to test, they don't have the resources to do so.
Old 09-30-2014, 10:48 AM   #23
s2d4
s2d4's Avatar
Yes that can be true but arguing?
What is this I don't even.....
Old 09-30-2014, 11:35 AM   #24
acro
Drives: GT-86
Exactly.
-alex
I disagree. As one poster said maintain your car properly according to your service manual with only oem or better than oem products. My previous car went well over 100k and was hammered a lot. Not one issue with the engine. Oh yeah I did keep it stock besides an air filter.
acro is offline   Reply With Quote
Old 09-30-2014, 03:11 PM   #25
stock
stock's Avatar
Drives: 2015 FRS Steel (manual)
Originally Posted by Wes View Post
keep it stock
I will, thanks.
stock is offline   Reply With Quote
The Following 2 Users Say Thank You to stock For This Useful Post:
mav1178 (09-30-2014), Wes (09-30-2014)
Old 09-30-2014, 05:44 PM   #26
dem00n
dem00n's Avatar
Drives: Scion FRS
http://dictionary.reference.com/browse/arguing
Old 10-01-2014, 12:24 AM   #27
s2d4
s2d4's Avatar
It's true.
Old 10-01-2014, 01:41 AM   #28
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
This is not true. For example, stock STi's have dangerous AFRs to meet emissions requirements. A proper aftermarket tune will not only unlock more power, but also increase reliability. Note that I said a proper tune, some tuners do not understand or respect the concept of correct flow (air/fuel) and are basically experimenting with your car/money. Not all tunes/tuners are created equal.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
No longer available funx Canada Classifieds 3 10-29-2013 09:10 AM
Engine Cover mods? Thongpocket Cosmetic Modification (Interior/Exterior/Lighting) 8 09-18-2013 02:48 PM
Engine Mods and CELs Captain Snooze Engine, Exhaust, Transmission 2 04-08-2013 10:13 PM
NA engine mods for turbo money? subatoy Engine, Exhaust, Transmission 62 11-28-2012 04:32 PM
check engine/CEL/DTC/MIL code list arghx7 Engine, Exhaust, Transmission 3 07-04-2012 10:37 PM
