Old 09-12-2014, 07:08 PM   #99
chris86
Drives: 2013 Dark Gray BRZ
Originally Posted by Ammonia View Post
I use the Nismo ones, and they're perfect. Just slightly longer than stock, didn't have to remove the hub.
I dont have spacers either.
They cost more, but sounds like it's worth it. What are you using for lugs. I bought open ended ones for the long ARP ones, could use them anyway with nismo studs?
chris86 is offline   Reply With Quote
Old 09-12-2014, 07:11 PM   #100
wparsons
wparsons's Avatar
Originally Posted by chris86 View Post
They said the ARP studs don't fit in the back. I've never done anything like this before so I didn't really know what to tell them other than ppl have done it. But they were convinced the studs wouldn't be able to fit to get them installed.
I didn't go to the dealer (yet at least) bc I figured it would be cheaper.
Sounds like they're trying to install them without removing the rear hubs.
You can get the ARP studs into the front hubs without removing them from the car (just pull the rotors), the rears you need to remove the hubs to fit the ARP studs in. You can get the stock studs out and back in with the hub still on the car, but longer ones won't fit without removing the hub.
flickr
Old 09-12-2014, 07:14 PM   #101
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
Do they really? I could have sworn mine were cheaper.
I just bought some closed ended tuner lugs from Autozone so your open ended ones will work fine.
boooooooooooooooooost
Ammonia is offline   Reply With Quote
Old 09-12-2014, 07:26 PM   #102
chris86
Where did you find them? This seems to be the going rate for them ($110 for ten)
http://www.frsport.com/Nismo-4222RS0...F-_p_7865.html
I got ARP ones on amazon prime for $37 per set of 5.
Old 09-13-2014, 03:20 AM   #103
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
How are these studs treating you?
I want stronger studs without being super long.
I bought ARP studs and was gonna just suck it up with how long they were and brought them with new lugs to a shop and they said they couldn't install them bc they are too long in the rear.
Now I'm reading this thread in greater detail, I think I'd like the nismo ones bc I don't have spacers and don't think ill need them. Are these working out for you?
Mine are holding up fine. If those guys can't fit the ARP studs you should start looking for another mechanic. They need to remove the rear hubs in order to fit the long studs. I didn't want to mess about with all that work so I chose the Nismo ones.
Fizz is offline   Reply With Quote
The Following User Says Thank You to Fizz For This Useful Post:
wparsons (09-13-2014)
Old 09-15-2014, 07:12 PM   #104
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Anyone else have a huge amount of trouble getting the front hubs off? I've been pretty liberal with the PB Blaster and have been beating on the 4 bolts from behind to get it to break free... nothing.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-15-2014, 07:19 PM   #105
Hanakuso
I really wish ARP would make standard size studs..
Hanakuso is offline   Reply With Quote
Old 09-16-2014, 08:56 AM   #106
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
I had to take a hammer to my ratchet to break them. The rears were worse than the fronts for me, but then again i've only got 9k miles and it's never seen snow/salt and rarely rain.
I have used a breaker bar as well on some.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 11-02-2014, 12:42 AM   #107
Quentin
Drives: ‘16 4Runner, ‘19 Corolla HB
One of the lug nuts I got with my wheels trashed a stud, so it looks like I'll be replacing a stud if I dam find one tomorrow. Grrr. I figure the washer method will suffice for just one. I've used a similar idea to press bearing into my mountain bike's bottom bracket.
Quentin is offline   Reply With Quote
Old 11-09-2014, 10:49 PM   #108
daiheadjai
daiheadjai's Avatar
Drives: 2003 S2000, 2008 Fit
Just wondering: I am going to replace a front hub assembly (yay wheel bearing!).
I really just want to remove the rotor - will I need the caliper piston tool?
Will the pistons compress if I just slide the caliper/pads away from the rotor?
Thanks!
daiheadjai is offline   Reply With Quote
Old 11-09-2014, 11:58 PM   #109
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Thanks!
You have to remove the caliper bracket also (to get the rotor off).
If you are not changing the rotor or pads, you will not have to compress the piston. Just remove bottom caliper bolt, rotate caliper body up, remove pads, rotate caliper body down, put bolt in a few threads, remove caliper bracket bolts, suspect caliper from spring/shock/whatever (not the brake line) with wire, zip ties, bungie, etc, pull rotor off, remove abs sensor and then remove the hub.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
daiheadjai (11-10-2014)
Old 12-01-2014, 03:41 PM   #110
Krovi
Krovi's Avatar
Drives: '14 Midnight Purple FR-S
Sorry for the thread revival, but does anyone know for sure if 25mm spacers fit on the ARP studs?
'14 MIDNIGHT PURPLE FR-S 『フェイリス』
Follow me on Instagram @overlim.it
Krovi is offline   Reply With Quote
Old 12-01-2014, 04:05 PM   #111
DAEMANO
Time Traveller
Stock studs are 40mm, ARP are 60mm = +20mm - 25mm spacer = 5mm diff. I've seen ppl put 3mm spacers on with no problem, those extra 2mm could be a thread or two of bite. This is close.
When I contacted H&R about extended studs + 25mm spacers they said they didn't develop a 25mm + extended stud product because their engineers didn't feel this was a good idea. Therefore they only offer 25mm bolt on spacers for the 86.
The Following User Says Thank You to DAEMANO For This Useful Post:
Koa (01-02-2015)
Old 01-02-2015, 04:00 AM   #112
marusteri
Drives: 2013 BRZ Limited AT
Very good info, thanks!
Small correction/addition: Dave said that he torqued the bolts holding the front caliper mounting to 59 ft-lbf and then for the rear brakes he used the same torque. I see in the service manual that the torque should be 59 ft-lbf for the front but for some reason it has only 49 ft-lbf for the rear.
Also the service manual says that the 2 bolts holding the caliper mounting, the 4 bolts holding the hub and the rear axle nut are all non-reusable parts . Usually most of us would reuse such bolts without thinking too much about them, but we already know that the OEM bolts holding the wheel in place aren't strong enough to withstand repeated use. So I don't feel good about reusing other bolts that Subaru says shouldn't be reused.
quirkparts.com has the P.N. 902170049 for the axle nut but so far I couldn't find the part number for the other non-reusable bolts
Florin
marusteri is offline   Reply With Quote
The Following User Says Thank You to marusteri For This Useful Post:
DAEMANO (01-02-2015)
flush with stock wheels. with Stud installation. adamturbo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 43 12-10-2012 04:30 AM
Wheel stud Guaruja Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 10-11-2012 02:42 AM
Lug Nut Stud feldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-22-2012 10:26 PM
Scion FRS center wheel caps replacement? Silverback Cosmetic Modification (Interior/Exterior/Lighting) 10 09-03-2012 02:16 AM
Are there any RWYB Wheel to Wheel road races? LexusFman Other Vehicles & General Automotive Discussions 1 11-05-2011 12:28 PM
