#85 |
No, but you'll probably need open ended lugs.
#86 |
USMC
Drives: 2013 FR-S 6-MT Raven
Noooooo!!!!
#87 |
Drives: Raven
What would be a reasonably size adapter(5x100->5x114.3) to use on the arp stud. I don't want the studs to hit the back of the wheel.
Instagram: erik239
#88 |
USMC
That's it. Open ended lugs.
#89 |
Drives: 13' Subaru BRZ Limited SWP 6MT
Don't use Ichiba studs, as others in this thread have posted.
My story posted here: http://www.ft86club.com/forums/showp...5&postcount=38
#90 |
Thanks
What size washer to place between open end lug nut and hub to push stud in?
#91 |
USMC
#92 |
USMC
APR studs with Muteki neo chrome lugs
#93 |
Senior Addict
Drives: 86 GT
Any size will do really, as long as the ID for the washer is bigger than the stud diameter. You'll need a few washers to space the lug nut out otherwise you'll bottom out on your socket as you tighten it. Do you have a cordless impact wrench? They're awesome for this job. Only needs a few zaps to pull and secure each stud.
#94 |
This pile is only 2 years old, only saw one winter 23k miles. Cant get hub apart here. (Rear) Going to have to order new ones. Everything that should be simple isnt.
#95 | |
Drives: 2013 Dark Gray BRZ
I want stronger studs without being super long. I bought ARP studs and was gonna just suck it up with how long they were and brought them with new lugs to a shop and they said they couldn't install them bc they are too long in the rear. Now I'm reading this thread in greater detail, I think I'd like the nismo ones bc I don't have spacers and don't think ill need them. Are these working out for you? |
#96 | |
FWIW the extra length with the ARP studs is incredibly annoying when you don't have a cordless impact, very convenient when you do.
#97 |
They said the ARP studs don't fit in the back. I've never done anything like this before so I didn't really know what to tell them other than ppl have done it. But they were convinced the studs wouldn't be able to fit to get them installed.
I didn't go to the dealer (yet at least) bc I figured it would be cheaper. |
#98 | |
Drives: Whiteout FRS, Audi A4, 135i (sold)
I use the Nismo ones, and they're perfect. Just slightly longer than stock, didn't have to remove the hub. I dont have spacers either.
boooooooooooooooooost
| flush with stock wheels. with Stud installation. | adamturbo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 12-10-2012 04:30 AM |
| Wheel stud | Guaruja | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 10-11-2012 02:42 AM |
| Lug Nut Stud | feldy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 09-22-2012 10:26 PM |
| Scion FRS center wheel caps replacement? | Silverback | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 09-03-2012 02:16 AM |
| Are there any RWYB Wheel to Wheel road races? | LexusFman | Other Vehicles & General Automotive Discussions | 1 | 11-05-2011 12:28 PM |
