Old 09-12-2014, 01:25 PM   #29
acj47
acj47's Avatar
Well? WTF did they say, don't be a cock tease!
They said it was the first they had heard of this issue, and asked me to measure the thickness of the factory flange and the bolt hole diameter, and will try to source longer bolts.
I'll post again when I have more information.
acj47 is offline   Reply With Quote
The Following User Says Thank You to acj47 For This Useful Post:
ZionsWrath (09-12-2014)
Old 09-12-2014, 01:37 PM   #30
ZionsWrath
Thanks
ZionsWrath's Avatar
Show them this thread. It seems it is far from the first instance lol
Old 09-12-2014, 01:52 PM   #31
acj47
acj47's Avatar
Already did
Old 09-12-2014, 02:14 PM   #32
stugray
Drives: 2013 GBS BRZ Limited
Ace hardware. Grade 8 bolts $10.
Seeing the driveshaft fly out of a 450 hp 75-Camaro and attack a pack of street racing onlookers - Priceless!
The Following User Says Thank You to stugray For This Useful Post:
flippy (09-12-2014)
Old 09-12-2014, 02:16 PM   #33
stugray
I have the same issue on my DSS CF shaft, ordered and installed last week. So far DSS has been unresponsive to my request to help source longer bolts (no, just going to ACE Hardware is not acceptable to me).
EDIT: just heard back from DSS after 3 days.
Looks like that bolt has already loosened based on the torque marks.
And Grade 8 bolts from Ace hardware are just as good as any other grade 8 bolt you can find (except for maybe Chinese ebay).
And WAIT! You are dissing Ace Hardware bolt quality, but youd rather drive around with half of a nut's thread engagement???
G-Man (09-12-2014)
Old 09-12-2014, 03:27 PM   #34
ToyoburuBRZ
ToyoburuBRZ's Avatar
Drives: Black BRZ
Originally Posted by mrk1 View Post
mcmaster.com easy source for hardware, usually only 2 days away
Mcmaster doesn't ship to Canada any more unless you are a big company that was already making orders through them. It is the worst thing to happen to Canada ever (cuz I can't think of anything worse that has happened up here)
ToyoburuBRZ is offline   Reply With Quote
Old 09-12-2014, 03:45 PM   #35
Dude that scares the CRAP outta me!!!!!
Pogoed on a shaft once and although I laughed about it later I don't mind confessing I almost had to change my pants at the time.
Old 09-12-2014, 08:40 PM   #36
FirestormFRS
2 threads fully through is very much the standard in all manufacturing. Probably hold forever but may fail on the first hard launch.
FirestormFRS is offline   Reply With Quote
Old 09-15-2014, 06:22 PM   #37
acj47
acj47's Avatar
Torque marks: there's only a 25% chance that that nut came from that location before I unbolted it...
Driving around: never said I was driving around like this...
Old 09-18-2014, 02:42 PM   #38
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Did anyone have trouble getting those 4 bolts off?
I been trying for over an hour, and looks like I'm about to strip the bolt... Sigh...
Carlitoz3 is offline   Reply With Quote
Old 03-30-2023, 12:47 PM   #39
FrickingReallySlow
Drives: 2015 FR-S
Does anyone know if these driveshaft bolts needs to be partially threaded? or can be fully threaded. If anyone knows the right length of the bolt to buy for Carbon driveshaft or aluminum driveshaft please let me know! thanks
FrickingReallySlow is offline   Reply With Quote
Old 03-30-2023, 08:22 PM   #40
stacyu18
Drives: 2014 subaru brz
i just installed a carbon fiber drive shaft today use blue lock tight on the nuts seems to be just fine just like the factory
stacyu18 is offline   Reply With Quote
Safe to run 5w-30 oil? NON-VTEC Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 47 03-12-2017 12:01 AM
DriveShaftShop Carbon DS - Vibration! Ray_32 Engine, Exhaust, Transmission 49 09-18-2014 09:46 PM
Two bolts for front camber safe? eSOLOR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 07-21-2014 10:22 PM
Aftermarket camber bolts safe? was385 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 04-19-2013 11:30 AM
Be Safe! Mr. J BRZ First-Gen (2012+) — General Topics 21 11-21-2012 05:46 PM
