crew chief
Drives: Race car FR-S
driveshaftshop bolts, is it safe?
NASA SpecE30 Racer
That looks like enough thread engagement to me as long as they are not lock nuts and thus not utilizing the locking part at the top of the nut.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
Drives: 2013 MT Asphalt FRS
How does that bad boy feel?
Looking into getting the same thing. |
Drives: Mazdarati
How much would it cost to go get new bolts and do it right compared to how much will it cost you when it fails.....?
First 86 Driver Baby!
Drives: FR-S, Flex
Thanks
does it torque to spec?
Drives: Scion FR-S
When we do bolting in industry, we try to have at least 2-3 threads above the end of the nut. What you have would not be considered acceptable.
Add lightness!
Drives: 17' WRX
That would not fly on aircraft. 2-3 threads through the nut. I had a similar problem with my driveshaft. I ditched the stock washers and used loctite red, which is a pretty hokey fix, getting the right bolts would be the right thing to do. Holds fine but might be a PITA if you have to rotate your driveshaft.
Drives: 2013 DGM BRZ
Go spend $4 on bolts, that's not safe at all.
#10 |
crew chief
yeah the thing is to find bolts with a grade high enough for the job. I don't have such a shop around.
I must admit i didn't even think about taking the washer off, that would give me something like 2 threads in addition. |
#11 |
NASA SpecE30 Racer
You don't have a local hardware store with grade 8 bolts and nuts? I would go with a longer bolt, nut, and a lock washer if you are worried.
- King Tut
#12 |
Drives: Scion FR-S
They aren't standard bolts. They are partially threaded so shear load isn't taken through the thread. You'd probably be ok to use a little loctite and remove the washer if it gives you enough engagement.
#13 |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
1 big vote for NOT acceptable.
2013+14+15 Atlantic Region Motor Sports Autocross STX Champion
2013+14+15 Atlantic Region Motor Sports Overall Autocross Champion 2017 Bluenose Autosport Club Overall Rallycross Champion Powered by Great North Performance, Jani-King Canada, and OK Tire. |
#14 |
Nope. Replace with correct length. Probably grade 8 if I had to guess.
| Safe to run 5w-30 oil? | NON-VTEC | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 47 | 03-12-2017 12:01 AM |
| DriveShaftShop Carbon DS - Vibration! | Ray_32 | Engine, Exhaust, Transmission | 49 | 09-18-2014 09:46 PM |
| Two bolts for front camber safe? | eSOLOR | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 07-21-2014 10:22 PM |
| Aftermarket camber bolts safe? | was385 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 12 | 04-19-2013 11:30 AM |
| Be Safe! | Mr. J | BRZ First-Gen (2012+) — General Topics | 21 | 11-21-2012 05:46 PM |
