Old 08-28-2014, 03:01 AM   #43
Alain
FRSKEE
Alain's Avatar
Drives: 2014 Monogram Series Whiteout
Originally Posted by CenCali86 View Post
I can not find 25mm slip on spacers... Even all of the companies I call (Eibach, H&R, Ichiba, etc...) claim they do not go above 20mm with the slip on style. They are all bolt on for 25mm+.
Mine are bolt ons i just hammered out the studs.
Alain is offline   Reply With Quote
Old 08-28-2014, 10:30 AM   #44
CenCali86
CenCali86's Avatar
Drives: FRS 10 Series
Well I found FT86Speedfactory claimed to have 25mm Eibach slip on spacers... even after I called Eibach and said they only made up to 20mm. We will see when the package shows up.
CenCali86 is offline   Reply With Quote
Old 08-28-2014, 12:25 PM   #45
power_of_ra
power_of_ra's Avatar
Drives: 2014 BRZ Limited CBS
let me know.. planning on getting 25mm from eibach all around as well on stock wheels/tires
power_of_ra is offline   Reply With Quote
Old 08-29-2014, 12:10 AM   #46
Alain
FRSKEE
Alain's Avatar
I see. Mine cost me 60 for front and back so yeah. Worked well. Went through five track days so far and counting. No problems yet.
Old 08-29-2014, 09:53 AM   #47
silverbullet
Drives: 2013 BRZ LTD Silver
$.02 I have tracked cars with bolt on spacers and have never had an issue and currently run 25mm rear and 17mm front ichiba hubcentric bolt on spacers that have been on the car for 30k of hard driving and a few track days and autox's and haven't had an issue. Also, porsche puts bolt on spacers on some of their cars from the factory and some porsche guys run bolt ons as big as 3" and track the cars without an issue.
silverbullet is offline   Reply With Quote
Old 08-29-2014, 09:57 AM   #48
CenCali86
CenCali86's Avatar
My issue isn't with running bolt on spacers, it's that I already have ARP extended wheel studs that would not be able to work with bolt on spacers.
Old 09-05-2014, 10:33 AM   #49
CenCali86
CenCali86's Avatar
Well turns out the spacers that were sent to me were the Eibach 25mm bolt on. SpeedFactory says there was some miscommunication when they were checking the spacers. As far as I can tell there is no one makeing a 25mm slip on style spacer, just the bolt on style.
This should work just fine but now I have to press out the studs that come installed on the spacer.
Old 09-07-2014, 08:11 AM   #50
RC51rydr
RC51rydr's Avatar
Just installed V3 Spacers Hubcentric 20mm fr & 25mm rr. For the most part I did it for looks as they finish the car off very well and gives it a more aggressive look. What I'm not so sure at this point, driving it for a couple days now, is the effect it has on the steering and ride.....minute differences but noticeable to me. The steering is a tad bit heavier but not where as you don't feel confident in cornering...it still corners amazingly. I feel the bumps and cracks in the road more as well....not sure if I can get over this. I feel like this one is going to drive me nuts. Gonna drive it for a few more days before making a decision to take them off.....we'll see.
RC51rydr is offline   Reply With Quote
Old 09-11-2014, 04:52 PM   #51
CenCali86
CenCali86's Avatar
Eibach sportlines with 20mm up front and 25mm in the rear.
Size:  391.6 KBName:  ImageUploadedByTapatalk1410468726.794277.jpg
Size:  341.0 KBName:  ImageUploadedByTapatalk1410468740.195535.jpg
Old 09-11-2014, 05:07 PM   #52
wheelhaus
wheelhaus's Avatar
Are you saying you feel bumps more through the chassis or through the steering wheel?
It could also be a placebo, where you think you're feeling new sensations but it's only because you're looking for something to be different so you're more perceptive to everything. I'm not calling you out or anything, but personally I felt little to no difference, same tires, same wheels, just offset. The only geometric difference I feel would even be perceptible would be scrub radius, which might have the effect of heavier steering depending on the alignment.
Old 09-11-2014, 06:35 PM   #53
RC51rydr
RC51rydr's Avatar
Feeling it through the chassis. The placebo affect is most definitely a possibility and I am unfortunately neurotic like that. I'm getting used to it now and am just going to enjoy the ride.
Old 09-14-2015, 03:27 AM   #54
Astroboy
Astroboy's Avatar
Drives: None
Wheel Spacers on stock wheels??
Does any one track their car with the spacers?
Astroboy is offline   Reply With Quote
Old 09-14-2015, 03:32 AM   #55
Astroboy
Astroboy's Avatar
Drives: None
Attachment 90609Attachment 90610Attachment 90611
Have you noticed any differences in handling? Also, do you track with this set up?
Old 09-14-2015, 04:13 AM   #56
JD001
JD001's Avatar
Drives: Subaru BRZ
Size:  305.9 KB I too have Eibach 20mm and 25mm on my BRZ. I think 25mm up front may push the wheel out too far, see photos below.
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 08:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 11:43 AM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 08:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
