Old 08-31-2013, 01:36 AM   #1
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Spacers and stock wheel studs
Will I need longer wheel studs if I added a 5mm spacer to my RPF1's?
Old 08-31-2013, 01:53 AM   #2
Fast_Freddy
Drives: Passat
It's easy to figure this out. Remove one lug nut and then count how many turns it makes to reach full tightness. Multiply this number by 1.25 and subtract 5. If the result is 12 or more, you're good to go.
Remember that wheel hub thickness varies from wheel to wheel so what works for one doesn't necessarily work for another. If you come up short an alternative to longer wheel studs is ET lug nuts. These extended shank style nuts add roughly 5mm of thread engagement but are only available in limited colors and styles compared to std wheel nuts. Gorilla is a great source. Good luck.
Fast_Freddy is offline   Reply With Quote
Old 08-31-2013, 08:55 AM   #3
Drftfan
Drives: Argento FR-S
No. I am running them on the rear of my frs with no issues. Anything above 5mm yes.
This is your first performance car?
Drftfan is offline   Reply With Quote
spacers and stock studs abutterman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 07-17-2013 10:55 PM
Spacers / Studs VOID Warranty? N_I_N Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-30-2013 03:32 PM
Longer wheel studs for those with spacers 000 Racing AUSTRALIA 0 03-20-2013 06:41 AM
H&R Spacers, ARP Studs, Muteki Lugnuts - ForcedFabllc.com ForcedFab_Jon Wheels and Tires 1 12-05-2012 12:45 PM
Small wheel studs PrinzJ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 10-10-2012 04:47 PM
