#7407 | |
Either way....moral of the story... Everyone should get a baseline, and with the phantom it is dead simple. Unbolt SC and replace with stock intake pipe and run it on the dyno again. |
#7408 | |
If you could we would be well over 230whp with just NA mods...15 for tune, 15 for exhaust, 10 for a intake, 20 for a header. |
#7409 | |
Drives: Passat
Isn't this your dyno sheet? ![]() Are we to believe that you made 206/185 on a Dyno Dynamics running pump gas and an early tune while VR46 can only manage 197/175 running e85, header, HFC front pipe and the latest OFT tune? Isn't it possible that some of your results were provided in normal DD mode while others were in comp. mode? Adding 10% to your old result would mean 227/204 on a Dynojet which doesn't seem likely. However VR46 making 217/193 is much more in line with expected results for a header, e85 and TQ250. I'm pretty sure that the above sheet is displaying "comparison mode" numbers. In fact, I'm sure that all of the Dyno Dynamics sheets posted on page 1 are in comparison mode. I agree about the baseline 100%. Especially when you guys are always saying that it only takes 5 mins to uninstall the ESC. Last edited by Fast_Freddy; 09-11-2014 at 01:47 AM. |
#7410 | |
There are so many variables it is hard to compare, the only thing that matters is baseline to dyno run. All of the runs were in the exact same mode. |
#7411 |
Was doing some cold weather testing today with the TQ300. Suprisingly it works DAMN good at 1 degree C
![]() Going to try and get a longer video today. [ame="https://www.youtube.com/watch?v=xWlbzHE5Cas"]Phantom supercharger tq300 - YouTube[/ame] |
#7412 |
#7413 |
daGangsta
Drives: 2013 FR-S 6MT
So ETA is what now again? I was told July...thought he meant 2014 not 2015
#7414 | |
Drives: 93'Camry, 82'Corolla, 76' Celica
If i did all of the tuning mods, then fixed the y-pipe design with a 30 degree merging system (good for another 15hp on dynos), some of this would add-up. In particular, exhaust modifications that eliminate factory level power output restrictions, would help a boosted car. This would only apply though if the cars stock exhaust system had some very restrictive exhaust system details in it's design. It would not add up directly, but if you have made exhaust mods already, they certainly would not be in vain, adding the Phantom System. I doubt the FRS/BRZ's system is much of a restriction as it sits to a 200hp (flywheel) engine, and relatively civil sound levels. Add some boost though, and it could hold back a significant amount of power. I'm sure it was very carefully designed to be polite about it's fun.
#7415 | |
I'll see if he has any updates and let you guys know. Thanks, |
#7416 | |
Drives: Passat
Oh well, I tried to explain it. Congrats on making more whp and wtq with a bone stock engine and pump gas than current ESC owners can manage with headers, HFC front pipes, e85 and better tuning. Must have been that cold Canadian weather... |
#7417 |
Drives: '14 FRS White
alrighty. so, as im reading back through the thread i figure ill ask real quick. (its a big thread). i installed the kit as per the instructions. car will start and run fine, so thats good. but, the voltage monitor is stuck at 26.6-26.7. i hear no noise from the controller. voltahe doesnt move up or down. obviously hitting the switch has no effect. the vacuum tube is stuck on the pipe too well. im afraid to pull it off to test the drag reduction. (but will if necessary). what am i missing here? (also, just got done redoing the whole thing from scratch, everything seems tight)
#7418 |
Drives: FR-S,GTI
Check your battery connections again. Something is very wrong. The meter should read at least 28 v. It sounds like the batteries are not connected to the alternator.
#7419 |
okay, update time. it is the harness that goes from the interior to the engine bay. I pulled it out and rigged it up a bit, went to start it up and 28v. clicked the switch, it was pushing air. the wire is still not 100%, i had to jiggle it a bit, but i'll solve that tomorrow. Woot.
#7420 | |
Time Traveller
| Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
