Old 09-10-2014, 12:37 PM   #1
KonTheory
Drives: '14 FRS
Alignment and Camber questions for Dummys(me)
I recently bought some Enkei RPF1s 17x9 +45 and Nitto NT05 235/40/17
Im getting them installed today and they are giving me an alignment
They are also putting in my whiteline camber bolts for free during alignment
Im just wondering what is an optimal Camber for my car?
I DD it but also take it to the occational AutoX
I was reading that -1.5 is a good start?
please help lol
'14 Raven FRS - Toyota Badges - Helix Smoked Side Markers - K&N Drop-in - 3" Nameless Axleback 4" Mufflers - Tinted Back Windows - RCE Yellow Springs - Openflash Tablet - OLM HID Kit - Cusco strut bar - TRD Quickshifter - 17x9 Enkei RPF1's with Nitto NT05's
KonTheory is offline   Reply With Quote
Old 09-10-2014, 01:00 PM   #2
Racecomp Engineering
Zero your toe front and rear.
Go for -1.75 degrees front camber if they can get it. Rear isn't adjustable without extra parts but should be OKAY.
Enjoy.
- Andy
KonTheory (09-10-2014), omegared19 (09-11-2014)
Old 09-10-2014, 01:02 PM   #3
KonTheory
Drives: '14 FRS
Thanks, yeah im on RCE yellows as well, feels great..
and is it worth buying somerthing to adjust the rear?
Old 09-10-2014, 01:05 PM   #4
I'm very anal about alignment, so I probably would. But in reality for a mostly DD car you don't need to worry about it with our springs since the drop isn't huge.
- Andy
Old 09-10-2014, 02:27 PM   #5
Turkish
Serial Cone Killer
Turkish's Avatar
Drives: '14 BRZ - WRB Premium 6MT
- Andy
I have found, through trial and error, that alignment is probably the most important part of setting up for autocross. Like Andy said for DDing, not as big of a deal. However if you find that you do not like the balance of the car in terms of oversteer and understeer, adjustability in your alignment settings is key. Ultimately, what you want with your car is your choice. Also, check out the this thread: http://www.ft86club.com/forums/showthread.php?t=45554 The info in that thread is invaluable to figuring out your suspension needs.
For those who hear him call...
... his name is...
C'THULHU
Turkish is offline   Reply With Quote
The Following 3 Users Say Thank You to Turkish For This Useful Post:
KonTheory (09-10-2014), omegared19 (09-11-2014), Racecomp Engineering (09-10-2014)
Old 09-10-2014, 03:40 PM   #6
wparsons
wparsons's Avatar
Normally I would say max out the camber you can get from the bolts, but with 17x9 +45 I doubt you'll have clearance between the wheel and lower spring seat (strut) for that without a spacer.
flickr
Old 09-10-2014, 07:40 PM   #7
knipple
Drives: 2013 Ultramarine Scion FR-S
You definitely will not be able to run anymore camber with a 17X9 +45 (other than that gained by the drop springs) without spacers. I used to run 17X9 +35 on stock suspension and with -1 deg camber, the inner sidewall of my tires was millimeters from the spring perch.
knipple is offline   Reply With Quote
Old 09-10-2014, 10:35 PM   #8
wparsons
wparsons's Avatar
I have -2* up front with camber bolts and slotted struts and next to no clearance with 17x8 +45's. 17x9 +35's would have ~3mm less clearance than my setup, but should still be able to get about -1.5*.
flickr
Old 09-11-2014, 01:18 PM   #9
KonTheory
Drives: '14 FRS
I did go with 3mm spacers.. dunno how much that will help but from what Ive read its enough to stop any sort of rubbing
Also I have the cusco strut bar,
is it necessary to preload the strut bar?
Old 09-11-2014, 01:55 PM   #10
omegared19
omegared19's Avatar
Drives: White 2013 BRZ Limited 6MT
Enjoy.
- Andy
Once you get the adjustable parts for the rear, start playing with alignments that feel right for you. Also are you going to use this as a DD or a weekend warrior toy? I do a lot of mountain runs on windy roads, and found (personally) -1.75 front and a -1.5 rear camber with zero toe and zero caster felt awesome for my needs.
However I've also invested in all the adjustable parts I need for the rear. So remember it also depends on what you want to spend on your set up.
omegared19 is offline   Reply With Quote
Old 09-11-2014, 02:05 PM   #11
KonTheory
Drives: '14 FRS
Problem is I commute 80kms a day(50ish miles)
so i dont want to go crazy, but I do like to autox..
so Im pretty much looking for the limit of camber that I can go to without wearing the tires out too much..
Old 09-11-2014, 06:53 PM   #12
wparsons
wparsons's Avatar
Toe kills tires, not camber. The combination of toe and camber is what gives camber a bad rep.
-2* with zero toe up front will be fine for commuting.
flickr
Old 09-14-2014, 05:38 PM   #13
KonTheory
Drives: '14 FRS
So I took it in for the alignment, and the guy there told me they had no problem getting one side to -1.5 but the other side wouldnt go passed -1.2.. so he put them both to -1.2
does that seem right?
also the rears are sitting at -2.2 and all I have done suspension wise is RCE Yellows
Old 09-14-2014, 06:29 PM   #14
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
it's possible. Usually people equalize at 1.3.
1.5 on one side and 1.2 on the other could mean a very slightly mis-aligned cross member, but well within the specs.
remember that realistically 0.1 degrees is very very very small, it just seems large since everyone talk's so feverishly about it on suspension forums.
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 02:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 04:40 PM
Rear Camber/Alignment Question anewprelusion Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 09-26-2013 12:39 AM
Alignment questions Thongpocket Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 09-12-2013 02:50 PM
Alignment/coilover questions yomny Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-04-2012 05:48 PM
