Old 08-01-2012, 02:55 PM   #1
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Question Alignment/coilover questions
I was wondering what the proper route was to make camber adjustments once the car is dropped via coilovers. The coilovers I'll be getting(most likely auto fortune) will have adjustable pillow top mounts in the front which i think allow for camber adjustment. What would be the best way to adjust camber and anything else needing correction after a drop(1.25")? I know the rear Agency power, perrin others make adjustable lower control arms and some other companies make those bolts which i still dont know how they work but also adjust camber. I think it'll be a good help for me and for others in the near future if we could establish the best way to correct/adjust car geometry after a drop, given that the car has no oem adjustment. thank!!
yomny is offline   Reply With Quote
Old 08-01-2012, 04:10 PM   #2
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
If you want more complete control. Camber plates up front should give you enough to adjust. Rear control arms are your best choice for a 1.25" drop. The bolts only allow very minor adjustments in camber.
denkigrve is offline   Reply With Quote
Old 08-01-2012, 04:12 PM   #3
epson1
Drives: 2013 BRZ Limited
Coilovers with adjustable top hats (pretty much any coil over ever) and Cisco or AP rear lower control arms
/thread
epson1 is offline   Reply With Quote
Old 08-02-2012, 10:21 PM   #4
yomny
yomny's Avatar
Thanks for the confirmation, its just what i had in mind.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
Old 08-03-2012, 12:51 AM   #5
Mitch
form follows function
Drives: RIP '13 BRZ
I'm getting Whiteline hats in the front and camber bolts front and back.
Mitch is offline   Reply With Quote
Old 08-03-2012, 01:23 AM   #6
track_warrior
Track Junkie
track_warrior's Avatar
Drives: Faster than the Stig!
Here is my setup and what i did hope it helps.
http://www.ft86club.com/forums/showthread.php?t=13614
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
track_warrior is offline   Reply With Quote
Old 08-04-2012, 02:11 PM   #7
yomny
yomny's Avatar
I've been reading that when camber is increased so is toe-in in this car. How to adjust the toe in the car, do the bottom adjustable control arm contribute to this or only camber. I want to make sure when i drop the car that everything that's off set could be adjusted and since it seems nothing is adjustable in this car. Thanks!
Old 08-04-2012, 03:21 PM   #8
schtebie
Drives: CBS BRZ Limited
The Cusco arms only adjust camber, they won't adjust toe-in.
schtebie is offline   Reply With Quote
Old 08-04-2012, 04:00 PM   #9
fatoni
i think one of you is talking about the front suspension while the other is talking about the rear
Old 08-04-2012, 04:48 PM   #10
yomny
yomny's Avatar
Thanks for the clarification schtebie.. i wasn't really talking about any specific location as i don't really know in details which side is affected but just wanted to see if anyone knew what to do to correct toe when dropping since it isn't adjustable, wherever it would be necessary front or rear.
Alignment Specs? 86_ZN6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 06-10-2013 06:30 PM
Actual alignment specs from BRZ taosracer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 06-29-2012 09:33 AM
Alignment needed after lowering car? Lowellrenzo Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 06-16-2012 02:57 PM
Whiteline alignment products Nardi330 AUSTRALIA 4 06-16-2012 03:25 AM
is the alignment on the FRS/BRZ adjustable? neveronlinefrs Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 04-05-2012 03:58 PM
