Old 09-09-2014, 01:02 PM   #1
FullBlown
FullBlown's Avatar
Drives: Scion FRS
FBM Stage 3 BIG BORE 2.19 Liter Shortblock
Here is something we are testing. It is our stage 3 Big Bore 2.19 liter motor.
With the success of our stage 1 and stage 2 short blocks. We have decided to test a stage 3 block. Our stage 3 will feature a 90mm - 90.25mm bore combined with our iron sleeve that are machined and installed to our specs.
We hope to have results with back to back comparison shortly.
FullBlown is offline   Reply With Quote
Old 09-09-2014, 01:03 PM   #2
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
:O
Old 09-09-2014, 01:05 PM   #3
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Just what I've been looking for. Can't wait to see further details.
crazyfrenchbiker is offline   Reply With Quote
Old 09-09-2014, 03:08 PM   #4
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Im not sure if the open deck concerns me...does that really matter much anymore in modern engines these days? This seems to make great power but its fully open. The EJ was semi closed IIRC.
Old 09-09-2014, 03:36 PM   #5
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
This with a stroker kit, 90mm square, would be great.
Freeman is offline   Reply With Quote
Old 09-09-2014, 03:50 PM   #6
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
whats the estimated power rating, how will this line up with stock trans, will it be able to use the same ecu and wiring, weight, engine postion compared to stock...
Scavanger is offline   Reply With Quote
Old 09-09-2014, 04:06 PM   #7
Dipstik-sportech
Dipstik-sportech's Avatar
Really? Did u seriously just ask that?
An increase in piston diameter will in no way affect transmission fitment, wiring, or engine position
Old 09-09-2014, 04:21 PM   #8
FullBlown
FullBlown's Avatar
Drives: Scion FRS
The open deck design really helps with cooling and being that the oem sleeves are very thick to begin with.. I would't be concerned about it.
Old 09-09-2014, 04:22 PM   #9
FullBlown
FullBlown's Avatar
Drives: Scion FRS
That is correct, nothing will need to be changed. Why is your signature not updated ??
Old 09-09-2014, 04:35 PM   #10
Dipstik-sportech
What do I need to change lol?
Old 09-09-2014, 05:41 PM   #11
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Need to add your 1/4 mile time you just got on the base kit like LJ @FullBlown has in his sig.
Old 09-09-2014, 06:09 PM   #12
Dipstik-sportech
Changed
Old 09-09-2014, 06:34 PM   #13
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Thanks for developing and pushing the envelope.
hmong337 is offline   Reply With Quote
Old 09-09-2014, 06:53 PM   #14
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Hmm....which kidney to sell right or left? I've always been a lefty
New rumor: 1.6-liter turbocharged engine one year after initial introduction Clode Scion FR-S / Toyota 86 GT86 General Forum 208 12-16-2016 07:14 PM
Comparison of the best ~2 liter N/A engines ever produced mit_peid FR-S / BRZ vs.... 331 07-30-2016 04:24 PM
Center Bore MooKz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 03-09-2015 03:56 PM
Hub Bore Correction Wesley Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-02-2013 08:00 PM
Subaru BRZ 2.0L Shortblock JPxM0Dz Engine, Exhaust, Transmission 7 12-16-2012 03:26 PM
