#129 |
Drives: 86
#130 | |
They call me Stan
Drives: Firestorm FR-S
| The Following User Says Thank You to iStanley For This Useful Post: | Juan_Ri (10-06-2014) |
#131 |
Drives: Scion FR-S
Here a picture with turn signals on
#132 |
Drives: Scion FR-S
#133 |
They call me Stan
They look amazing! I never thought I would cut mine open but if it looks like that, then I definitely would.
So you pretty much wrapped the red "brake light" part it in carbon fiber. I'm curious of how you did it? That's exactly how I want mine to turn out. |
#134 |
Drives: Scion FR-S
Yes I wrapped with cf paper the side marker but I cut a rectangule so the light can get thru and paint the side part flat black; the tuff part will be cutting the piece of acrylic (painted with smoke spray) to cover signal light area. I did not paint black the inside around part of the brake light, but after I finish, I realize that there is no need on leaving that chrome, so you can paint it completly flat black just leaving the lip,but if you dont like the lip you can paint all black. Also, If you put the smoke on the signal, you will need a plasma led white bulb for it to be brighter. Later, when I get some time, I'll open it again to paint the inside chrome and just leave the lip... Hope it helps; just let me know if you need any help.
#135 | |
They call me Stan
#136 |
Drives: Scion FR-S
#138 |
They call me Stan
#139 |
Drives: Scion FR-S
It would look better if you paint everything black, just keep the lip chrome and paint the inner part black. I put the red part of the break in a table and keep it level as possible, then put a few drops of oil in the small circles of the leds and clean them when the rest is dry so the light can pass thru it... Use electrical tape to cover the lip, is more easy to give the right form and cover better the chrome from the paint... and be careful while open it, the chrome gets scracthe easily... When sealling at the end, do not push to much the silycone, it could be visible from outside if too much is applied... Anything, just let me know
#140 | |
They call me Stan
| Smoking or Redding BRZ/FR-S Tail Lights | DarrenDriven | DIY (Do-It-Yourself) Guides | 596 | 02-20-2021 10:11 PM |
| Black Housing Tail Lights (FR-S) | sw20kosh | Cosmetic Modification (Interior/Exterior/Lighting) | 20 | 04-13-2016 11:38 PM |
| FR-S smoked tail lights and reverse lights | jjdrivesajazz | Cosmetic Modification (Interior/Exterior/Lighting) | 43 | 02-21-2013 08:38 PM |
| opening tail lights? | JollyJON | Cosmetic Modification (Interior/Exterior/Lighting) | 34 | 07-23-2012 04:35 PM |
| Are you going to smoke out your tail lights? | Liquidsnake | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 06-06-2012 09:02 AM |
