Old 09-02-2014, 02:45 PM   #127
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Twin4Life View Post
It seems a high majority of 86 owners wish to go FI. Why didnt you buy a faster car to begin with?
Some of us did buy a faster car previously. Adding power is easy, finding a chassis that weighs 2700 lbs is much harder.
The Following 3 Users Say Thank You to King Tut For This Useful Post:
bedabi (09-07-2014), CSG Mike (09-02-2014), glamcem (09-03-2014)
Old 09-02-2014, 02:59 PM   #128
thill
Well and keep in mind Mazda did extend the warranty on the RX-8 to 96 months and 100K miles. I have owned 3 RX-7's and can attest that rotary engines are high maintenance. But I had all of my original rotaries go over 100K miles without drama. You just get used to checking your oil once a week and adding as needed. I suspect a lot of failed rotaries are coming from people used to low maintenance engines where you can go 3-7K miles without adding a drop of oil.
The Following User Says Thank You to thill For This Useful Post:
Old 09-02-2014, 04:11 PM   #129
CSG Mike
CSG Mike's Avatar
There's no car that's faster within 100 lbs of the curb weight... except the S2000.
Old 09-02-2014, 04:12 PM   #130
CSG Mike
CSG Mike's Avatar
Could not have said it better myself.
Old 09-03-2014, 03:14 PM   #131
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
because it didn't exist I mean when all things consider (cost, weight, handling, ability to fit 4 wheels for track days etc..)
I've also owned way faster cars (and bikes) also.. There are still some little issues with the twins even after FI but those are not as big as the other cars in the market IMO.. if they offered a 250 whp BRZ at higher cost I would get that instead of course
glamcem is offline   Reply With Quote
Old 09-03-2014, 03:53 PM   #132
stevo585
Drives: White 2014 BRZ
Even then the S2K is only faster less than 100mph. I did the same test with a APR stage 1 MKVI GTI I pulled on him in 5th gear. I have just OFT, header, e85.
stevo585 is offline   Reply With Quote
Old 09-03-2014, 04:13 PM   #133
serialk11r
Drives: '06 AM V8V Coupe
Boxster Spyder? Normal Boxster/Cayman? Exige V6?
Noble M600? Okay that was trolling.
Old 09-03-2014, 04:41 PM   #134
CSG David
CSG David's Avatar
LaFerrari.
Old 09-03-2014, 05:44 PM   #135
serialk11r
Originally Posted by CSG David View Post
LaFerrari.
Pretty sure that car holds well over 200lbs of fluids lol.
Old 09-04-2014, 11:27 AM   #136
WolfpackS2k
WolfpackS2k's Avatar
Drives: '12 C63 P31, '23 GRC
Lol, LaFerrari is considerably heavier than the FRS. Way more than 100!
The Following User Says Thank You to WolfpackS2k For This Useful Post:
CSG Mike (09-04-2014)
Old 09-04-2014, 11:51 AM   #137
Jaden
Road-hole
Drives: 2013 Whiteout FR-S
nope...
boxster spyder, 400lbs heavier...
Regular boxster 200lbs heavier
exige qualifies but costs 3x as much...
Jaden
Jaden is offline   Reply With Quote
The Following User Says Thank You to Jaden For This Useful Post:
Old 09-04-2014, 01:02 PM   #138
serialk11r
Jaden
lol, where are you getting your numbers...
Regular Boxster is 2890, FRS is about 2800.
Boxster Spyder is the lightest Porsche in recent times, clocking in at 2811 claimed.
Old 09-04-2014, 01:42 PM   #139
Jaden
Road-hole
well here you go...
2,943 lbs
The curb weight of the 2012 Porsche Boxster is 2,943 lbs.
even the 2014 boxster-s is 2910 and 2976 respectively for stick and pdk for 2014, so it's still 150-225 lbs heavier...
http://www.porsche.com/usa/models/bo...turesandspecs/
boxster spyder 2011 Curb weight, as tested (lbs.) 2,908
http://www.edmunds.com/porsche/boxst...est-specs.html
The frs is 2754 btw, not 2800...
Jaden
The Following 2 Users Say Thank You to Jaden For This Useful Post:
CSG Mike (09-04-2014), mwjcyber (09-06-2014)
Old 09-04-2014, 01:43 PM   #140
serialk11r
2,943 lbs
Jaden
My bad I forgot the Boxster was 20lbs more than the Cayman. I always thought the BRZ came in over 2800 though.
Anyways they're pretty close. The Boxster Spyder definitely makes the cut (though it does cost 2 times the BRZ). With smaller wheels you could definitely get the base Cayman MT within 100 lbs of a BRZ Limited. Porsche wheels are ridiculously fat and heavy.
Dezoris | FR-S Build | Supercharged & More Dezoris Member's Car Journals 329 03-21-2016 04:48 PM
The curse strikes again Blood BRZ First-Gen (2012+) — General Topics 22 04-23-2013 02:08 PM
This is what i get for going in on my day off (curse strikes again) wrxgoose Scion FR-S / Toyota 86 GT86 General Forum 62 03-28-2013 08:02 PM
CSG BRZ playing with the big boys...Boosted NSX, DNA Motoring S2000, and a Ferrari... CSG Mike BRZ Photos, Videos, Wallpapers, Gallery Forum 1 02-12-2013 09:51 AM
The Curse Strikes. Again. SubieNate Scion FR-S / Toyota 86 GT86 General Forum 46 02-08-2013 03:47 PM
