#85 | |
Drives: BRZ Pearl White
Indeed, given the suspension on the BRZ is just an Impreza I am dubious much engineering was ever applied to the BRZ. The front struts are fitted at a steeper angle to get them under the desired hoodline with minimal effect on actual handling, the suspension settings are identical to the Impreza apart from a modest difference in ride height, the alignment is identical. I suspect the spring rates aren't a lot different and the ride height is less than 1 inch lower. Curb weight is virtually the same, a BRZ with two passengers weighs the same as an Impreza with just the driver. I'm betting the BRZ fits the exact same bump stops as the Impreza and the engineers understood that removing the fwd would make the car more tail happy without much alteration to anything. |
#86 | |
#87 |
Village Idiot
Drives: '13 FR-S Ultramarine Manual
Why are you back?
| The Following 5 Users Say Thank You to jebuwh For This Useful Post: | Captain Snooze (09-03-2014), Dipstik-sportech (09-03-2014), gramicci101 (09-03-2014), Tgionet (09-04-2014), wparsons (09-03-2014) |
#88 | |
The stock rear dampers do not control the spring correctly. They allow jounce too easily and damp rebound incorrectly. The high speed control (high stroke rate) is awful in both directions. Some may say this was deliberately engineered and I say it was a mistake. I think Subaru just decided to save money. It'd be interesting to know if Subaru actually changed much from the Impreza except shortening the effective damper stroke. The way this car can be provoked so easily into oversteer is a real pity, and robs the car of some of its true potential especially for fast road driving on bumpy roads. The ride is truly appalling and unnecessarily so as it yields no advantages. |
#89 | |
Drives: GT86
And I do not recognise your complaints. It does not step out easily, nor does it bounce of the road for nothing. Well of course I could provoke that, you learn the limits, just saying that when colouring within the lines, this car is pretty impressive compared to other off the shelf sport cars that have to do it all. In such driving, the damping works pretty well and body control is just fine. It's not a WRC rally car of course and could be improved a lot for such driving, a lighter wheelset with more sidewall was one such improvement. But for a car that has to do all kinds of driving, it's good. I do recognise the rear suspension stroke is a bit short (I would not lower it on stock struts) and I notice the overdamped front especially when driving over small fast undulations, but those are relatively minor complaints related to ride comfort when cruising. It's a sports car after all. |
| The Following 2 Users Say Thank You to Trettiosjuan For This Useful Post: | gramicci101 (09-03-2014), wparsons (09-03-2014) |
#90 | ||
Because compromise ®
Drives: Red Herring
Jounce is is the derivative of jerk. Do you mean compression? Edit. In Australia jounce is a physics/engineering term but having looked at 3 online dictionaries the definition of jounce as to move in an up-and-down manner http://www.merriam-webster.com/dictionary/jounce to make short up-and-down movements http://www.merriam-webster.com/thesa...unce%5Bverb%5D to move joltingly or roughly up and down; bounce http://dictionary.reference.com/browse/jounce Quote:
Your use of hyperbole is interesting. Of course it is easy to provoke; you turn the steering wheel and adjust the throttle. Nothing easier but I am suggesting you have to induce it. It is not going to oversteer if driven smoothly. All 3 models understeer on constant throttle. More hyperbole. You are making a value judgement but are making an objective statement. Inane comment. Most cars are built to a budget. Of course better dampers could have been fitted but 99% of buyers wouldn't care or know the difference. A better sound system could have been fitted, lighter wheels, a lighter battery fitted, where do you draw the line? Oh look, the $38k car has just become a $48k car.
#91 | ||||||||
You know what else the rear motion ratio means? It needs less shock travel for the same amount of wheel travel as the front. Quote:
Spring rates aren't even close, weight distribution isn't even close. Look at how much further forward the engine sits in an Impreza/WRX/STI to make room for the AWD gearbox. Further, the suspension isn't all Impreza. There are some shared parts, but not everything is a full carryover, especially the springs/shocks. As for the strut angle, what evidence do you have to suggest that the angle is actually different, and if it's different that the only reason was to reduce the hoodline height? Stop taking what you think the engineers did and spreading it as fact. Quote:
As for me, I'm giving information based on facts. You're just spreading your opinions, which contradict facts. Start citing your sources on all the BS you claim is fact.
| The Following 2 Users Say Thank You to wparsons For This Useful Post: | Captain Snooze (09-03-2014), CSG Mike (09-03-2014) |
#92 | |
Drives: Red Herring
"The front struts are fitted at a steeper angle" "the suspension settings are identical to the Impreza apart from a modest difference in ride height" "spring rates aren't a lot different" "less than 1 inch lower" "Curb weight is virtually the same, a BRZ with two passengers weighs the same as an Impreza with just the driver" BRZ castor 5°54’, current Impreza castor 6°30′. BRZ front toe 0±3mm, Imp 0±2 mm. BRZ rear toe 2±3mm, Impreza 0±2 mm. Yep, look identical to me.
#93 |
For our friends down under:
http://144.162.92.233/faculty/djones...suspension.pdf Used primarily in USA. Means the same as bump for UK speakers. Ride is subjective but only to a point. I prefer the stock ride in the BRZ to the stock ride in the Cayman for example. It is still appallingly bad given how easily and cheaply it can be improved simply by fitting Bilstein shocks to the rear axle. You are welcome to enjoy your "sporty" ride that achieves nothing useful or measurable. Some people even enjoy the hole in the firewall that lets engine noise into the cabin. It seems some people like tatoos and nose rings. Each to his own. I prefer a car that handles well and rides properly. I also prefer a car that corners better than the stock BRZ. I am very sure the initial market for this car was snapped up by those who enjoy a little oversteer just after breakfast. I'm equally sure that market has been pretty much satisfied and from 2015 on Subaru and Toyota are improving the car to capture more serious and knowledgable customers before releasing a revised model. If this car rides and handles so well why on earth did such an active aftermarket spring up so quickly? This whole suspension topic is about what is "wrong" with the stock car. For the informed enthusiast the most serious deficiency is the ride and the second most serious deficiency is the handling balance. Both can pretty much be fixed with better designed and built shocks and struts. Not sure about the bump stop problem yet but in about four weeks I should have better information about that. BRZ manufacturer's weight figures show it to be 66 kg lighter than a four door base Impreza. So if you are comparing occupant numbers a BRZ with two adult occupants will be heavier than an Impreza four door with a driver, on average. For three occupants in the BRZ to equal one in the Impreza you'd need at least two kids if you want to make a point, though what that point might be escapes me. Then compare the 0-60 times to see how relatively sporty the two models are.... I might as well also throw in the opinion that the Torsen fitted to this car could benefit from a reduced bias ratio. Doesn't affect the ride though. Last edited by Ubersuber; 09-03-2014 at 10:35 AM. |
#95 | |
Off Topic
#96 | |
Drives: GT86
#97 | ||||
I'll wait patiently for another of your replies where you completely avoid providing any evidence, data, sources, etc and just blabber on with your, incorrect, opinion.
#98 | |
Off Topic
| The Following User Says Thank You to gramicci101 For This Useful Post: | Trettiosjuan (09-03-2014) |
| Tags |
| making seniors look bad, uberstupid |
| For those who ride, there's a group ride happening tomorrow if you're interested. | Yamaha_R6 | Northwest | 3 | 03-07-2014 10:32 PM |
| Simple mods to improve handling while improving looks? | Jinzen | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 06-07-2013 12:48 PM |
| What's your other ride, winter ride etc. | wtout86 | Other Vehicles & General Automotive Discussions | 13 | 12-07-2012 01:36 AM |
| Does the ride quality change with time?? | BRZnut | BRZ First-Gen (2012+) — General Topics | 22 | 12-01-2012 09:26 PM |
