Old 09-01-2014, 05:52 PM   #659
Fleischwagen
Drives: 2013 BRZ, 1979 Scirocco 16v
Hey guys, just wondering where I stand with my Stage 2 93 oct flash. Car has a Tomei UEL, Perrin 2.5 non-res catback, K&N panel filter and modified stock snorkel.
(Note, this pull was in 2nd gear only, approximately 75 degrees at 7:30 am, so relatively low humidity)
http://www.datazap.me/u/fleischwagen...log=0&data=1-7
Fleischwagen is offline   Reply With Quote
Old 09-01-2014, 11:24 PM   #660
TJ3000
Drives: MT Raven Black FRS
@Shiv@Openflash can I use a Mac or do I have to use windows?
TJ3000 is offline   Reply With Quote
Old 09-02-2014, 02:32 AM   #661
tracerit
Drives: '13 SSM BRZ Limited 6MT
is there a preset tune for the following mods: Perrin Inlet hose, Perrin 2.5" Catback resonated exhaust? Considering switching from my Unichip if there's not much work involved with changing settings and such.
tracerit is offline   Reply With Quote
Old 09-02-2014, 02:44 AM   #662
steve99
Drives: FT86
Read OFT TIPS link below will answer your questions.
Quick answer is yes
Stage 1 OFT Tune would be flash and go maybe 10 minutes, would take you longer to remove uni-chip.
Which TUNE should I run and what Mods are supported
Check the file called "release notes" in the zip file for the tunes you download from the site .
Rough guide OTS Map Requirements:
Stage 1- For vehicles equipped with original header. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune.
Stage 2- For vehicles equipped with aftermarket cat-less headers. Other exhaust modifications also compatible. Stock airbox (with or without aftermarket drop-in panel filter) also recommend. Premium grade fuel or fuel as specified by tune
91 (USA) octane or better required for 91 octane tunes
93 (USA) octane or better required for 93 octane tunes
E85 required for tunes labeled E85 (ie fuel with 60 to 90% ethanol content)
Exception for Stock cars running E85 use Stage 2 E85 EL header tune http://www.ft86club.com/forums/showthread.php?t=67310
tracerit (09-02-2014)
Old 09-02-2014, 02:08 PM   #663
football751
Drives: n/a
The OFT doesn't have specific tune files for all the various mods like the Unichip does. So you're not going to find a tune that specifically says "Perrin inlet hose and catback exhaust" like I'm sure you have from Unichip. I have a Unichip on my FJ, so I know they have different tune files for different brands of intakes, exhausts, etc. The OFT is more general, but is also much more customizable and tuneable than the Unichip. I like the OFT on my BRZ much more than my Unichip on my FJ.
football751 is offline   Reply With Quote
The Following User Says Thank You to football751 For This Useful Post:
Old 09-02-2014, 04:33 PM   #664
chas3wba0
chas3wba0's Avatar
Drives: Yes
Quick answer is yes
What do you think for a catted UEL header? I have the one from FT86SpeedFactory (not a high-flow cat, so I assume it's closer to the stock header than it is to a catless) and I've been running Stage 1. Stage 2 just felt a little "hesitant".
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 09-02-2014, 04:55 PM   #665
football751
Drives: n/a
What was your reasoning for getting the header? If you can't run Stage 2 with it you're probably not getting much benefit compared to the cost. Just MHO.
As to your question, you may be able to try Stage 2 91 if you have 93 octane in your area. The less-aggressive 91 tune with 93 octane may work out. Other than that is Stage 2 doesn't feel right you may have to work with Shiv to design a Stage 1.5 tune for you, as you could probably get more performance than Stage 1 is giving you.
Old 09-02-2014, 05:04 PM   #666
chas3wba0
chas3wba0's Avatar
Drives: Yes
Mostly sound and better torque curve, both of which it does deliver, albeit at a relatively high cost. I'm a bit anal about rasp, so catless wouldn't do it for me.
Unfortunately, I'm in Cali so only have 91 available
Old 09-02-2014, 06:30 PM   #667
Stealthy
Drives: 2014 WRB Bravo Romeo Zulu
Is there a major difference in regards to power with the stage 1 93 vs stage 1 91?
EDIT: Found answer by googling in an older thread
Originally Posted by Shiv@Openflash View Post
Just to clarify, our tunes are mapped for 91-93oct. Just like the factory tune. What this means that it's more likely that us 91oct folks will see knock correction from time to time. While 93oct folks will be knock correction free for the most part. At least that is how it is in theory. In the upcoming release of 91 and 93 oct maps (with v1.60 OTS map release), what you will be presented with are two maps. One slightly less aggressive and one slightly more aggressive. Don't expect there to be a substantial power difference between them. Maybe 2-3whp up top
Stealthy is offline   Reply With Quote
Old 09-02-2014, 09:52 PM   #668
tracerit
So I should go with Stage 1 as recommended and then do logs and adjust the values from there?
Old 09-04-2014, 09:12 PM   #669
stevo585
Drives: White 2014 BRZ
Looks too rich but that's how the tunes are. Mine is the same way.
stevo585 is offline   Reply With Quote
The Following User Says Thank You to stevo585 For This Useful Post:
Fleischwagen (09-04-2014)
Old 09-04-2014, 09:15 PM   #670
Fleischwagen
Better to be rich than lean… hah the car feels amazing, tonsssss of power after I did the header/stage 2 tune. Car feels completely different, in the best way possible!
Old 09-04-2014, 09:29 PM   #671
B-R-Z
I love peanut butter
B-R-Z's Avatar
Drives: 2013 SWP BRZ Limited
I need to order one of these tablets. I have a catless uel header and k&n filter and everyone says how insane the stage 2 uel tune is...ahh trying not to spend any more money on mods this year. Somebody talk me in to it lol.
B-R-Z is offline   Reply With Quote
Old 09-04-2014, 09:41 PM   #672
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Those parts with the stock tune don't really work too well.
Did that help?
Cheers,
shiv
Shiv@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
DC2R (09-04-2014), jsquared (11-26-2015), Migero86 (09-04-2014)
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
