Old 06-21-2014, 11:40 PM   #57
youcantseeme24
youcantseeme24's Avatar
Drives: 2013 subaru brz
man.... just cant kill this thread!
youcantseeme24 is offline   Reply With Quote
Old 09-01-2014, 05:33 PM   #58
oldeskewltoy
dedicated enthusiast
oldeskewltoy's Avatar
Drives: Surreptitious(AE71), & Grunt(AE95)
@oldeskewltoy
So, were you ever able to get a hold of a FA20 to work your magic?
nope..... I've managed to acquire a couple of Nissan heads (CA18DET, and SR20DE)... but still no FA20 heads
but I'm still interested
Here is a recent 4AG head....
recent exhaust port going through transition from stock to ported
Information is POWER - LEARN the facts!
oldeskewltoy is offline   Reply With Quote
The Following 2 Users Say Thank You to oldeskewltoy For This Useful Post:
Hawk77FT (09-01-2014), sato (09-15-2014)
Old 11-16-2014, 05:46 PM   #59
Turdinator
Señor Member
Turdinator's Avatar
Originally Posted by Tim Radley View Post
But that is not always true. Sometimes more airflow leads to a decrease in horsepower
Can you explain this statement?
1974 TA22 Celica
2013 86 GT
Old 12-02-2014, 11:36 AM   #60
oldeskewltoy
You Fox News'd me... you took a small bit and blew it out of its context.... Here is its context....
Originally Posted by andrew20195 View Post
I thought the short radius doesn't really matter, as inertia will force a vast majority of the air along the long radius?
In essence you are correct... but if we can also gently shape the short radius to aid in filling.... the more air flow, the better.... and that includes the short radius... by improving ALL areas we improve the ports function, and find more horsepower where there was less.
Oh... and I'm not talking about "hogging" anything out either... My goal in porting is to improve the casting... because the basic casting is a mass produced part.... and as such has flaws
small thread divert.... A TV show... on Ferrari's factory explained that Ferrari has highly skilled technicians porting the CASTING SAND before the metal is poured... because it was less costly to then perfect the shape in sand, then it was to pay someone to port the finished castings...
Back to Toyota/Subaru and the FA20... as advanced as this engine is... it still is a mass produced casting without any one porting/perfecting it... either before, or after casting.
A lot can be done inside the port.... without hogging anything
exhaust
intake
As you can see in the above shots.... the bowl to port transitions have been blended to allow for added airflow in the same overall space.
See..... No hogging...
Now... to answer your question... More air VOLUME may not be good... because at some point you sacrifice air velocity... for volume. Velocity is important because it helps in cylinder filling.
The IDEAL... is to increase the volume without decreasing velocity.
The Following User Says Thank You to oldeskewltoy For This Useful Post:
Nah (10-26-2016)
Old 09-09-2015, 07:54 PM   #61
ort895
ort895's Avatar
how much would should this run us?
Yeah its an auto, deal with it.
ort895 is offline   Reply With Quote
Old 12-17-2018, 06:27 PM   #62
ML
ML's Avatar
Drives: 13 White MT FR-S
I am the thread necromancer. Any updates in this field?
Old 12-17-2018, 09:18 PM   #63
Lantanafrs2
Drives: 2013 frs red
No and for good reason. Not worth it.
Lantanafrs2 is offline   Reply With Quote
The Following User Says Thank You to Lantanafrs2 For This Useful Post:
Tcoat (12-17-2018)
Old 12-18-2018, 04:16 PM   #64
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Since there are companies working on intake manifolds this would be a good complimentary mod to go along. When trying to squeeze every ounce of power out of an NA setup we the consumer will determine if its "worth it" or not.
SuperTom is offline   Reply With Quote
Old 12-18-2018, 04:35 PM   #65
ML
ML's Avatar
Every "built" motor I see for sale these days say they have a P&P so you can't tell me people aren't doing it.
Old 12-18-2018, 04:53 PM   #66
Lantanafrs2
If it worked on an na platform there would be dyno charts all over the place. Stock cams, stock rpm limit no dice imo
Old 12-18-2018, 04:55 PM   #67
Lantanafrs2
Ports don't need to reflect light to flow well btw.
Old 12-18-2018, 05:31 PM   #68
Lantanafrs2
Exhaust ports many times are shaped for anti reversion so you need to be careful there.
What did you wash/shine/polish/wax today? tuckdaddy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-04-2013 07:42 PM
Glass polish? SubarooMike Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 11-08-2012 01:33 PM
Port and polish? Extrude hone? mrha Southern California 0 07-11-2012 09:54 PM
Saving / Re-using polish and waxing supplies? eikond Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 06-25-2012 04:25 PM
