go_a_way1
Old 08-28-2014, 04:12 AM   #2479
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Originally Posted by Cliu91 View Post
How does someone who is compeltely noob in this subject (tire size, wheel size, etc.) learn more about this?
Well, for the very basics, the Rack is always a good source of info. On this page, the Tire Tech and Wheel Tech sections are places to start: http://www.tirerack.com/about/techcenter.jsp.
I still refer to this page from time to time: https://www.rsracing.com/tech-wheel.html.
dradernh is offline   Reply With Quote
The Following User Says Thank You to dradernh For This Useful Post:
Cliu91 (08-28-2014)
Old 08-28-2014, 10:09 AM   #2480
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by Mlprltw View Post
I'm looking at a set of 57DR gram lights, but I'm wondering if 18 x9.5 it too wide? With a 38mm offset. I don't know too much about the fitment for my frs. It's lowered with H and R super sport springs.. Any help would be appreciated!
See here, always the first place to look at when looking at a specific wheel and you get to see that specific size/offset mounted:
http://www.ft86club.com/forums/showthread.php?t=7535
And voila:
http://www.ft86club.com/forums/showthread.php?t=25675
He is running coilovers though, it might fit with springs, will be tight.
Slick is offline   Reply With Quote
Old 08-28-2014, 12:42 PM   #2481
Smokey
GT86 HIGH AUTO PEARL
Smokey's Avatar
Drives: 2013 GT 86 Tiptronic Pearl White
Hi Guys, just wanting to know if anyone has kept the stock wheels for weight purposes and possibly painted them silver or any other colour. I have a pearl white 86
Smokey is offline   Reply With Quote
Old 08-28-2014, 10:31 PM   #2482
Autocon
Autocon's Avatar
Drives: 2014 Whiteout FRS
I'm looking to get a set of Enkei Kojin 17x9 45 5x100 but I'm on stock suspension. Will this work on stock or will I need to get spacers for the front? Or can this only work with coilovers/springs?
I have tried to read up on this as much as I can but I am still really new to this wheel stuff but with all the numbers and stuff its crazy confusing ha.
Thanks!
Autocon is offline   Reply With Quote
Old 08-28-2014, 11:30 PM   #2483
Slick
Slick's Avatar
Thanks!
It'll work on stock suspension and clear okay, but if you drop it on springs or camber bolts, you'll be too close to spring perch and need to add spacers at that point.
The Following User Says Thank You to Slick For This Useful Post:
Autocon (08-29-2014)
Old 08-29-2014, 12:11 AM   #2484
Autocon
Autocon's Avatar
Awesome thanks for the info!
If you don't mind, what exactly is spring perch? Just trying to learn what I can
Old 08-29-2014, 09:17 AM   #2485
Slick
Slick's Avatar
It's the piece from the strut that the spring sits on, see below.
Old 08-31-2014, 01:25 PM   #2486
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Just because I never found a definite answer if 04bbs wheels fitting without spacers, yes they fit without spacers. On lowering springs with 225-45 rs3's
bkblitzed is offline   Reply With Quote
The Following User Says Thank You to bkblitzed For This Useful Post:
Slick (08-31-2014)
Old 08-31-2014, 01:57 PM   #2487
Slick
Slick's Avatar
04 BBS as in 2004 WRX BBS wheels? What size and offsets are they? Guessing 17s from the tire size you posted.
Old 08-31-2014, 01:59 PM   #2488
bkblitzed
is better than you
bkblitzed's Avatar
yup, 04 STi wheels. 17x7.5 and offset i think is around 55. My new track setup
Old 09-05-2014, 12:14 AM   #2489
Neokolzia
Drives: 1996 Celica GTFour ST205
I'm on Stock Wheels (Limited Aozora so STI rims), but my father has some 205/45R17's that are good quality, picking up my car tomorrow, and wondering if I should even bother putting these on? They are decent quality ZR's compared to the original, I know they'll fit but just wondering if its remotely a good idea or should I consider trading them for a better pair?
Neokolzia is offline   Reply With Quote
Old 09-05-2014, 12:34 AM   #2490
K-NoMs
Drives: 2015 BRZ Series.Blue in WRB
Will a set of Enkei T6S 18x9.5 with +45 offset and 1 inch drop fit? I apologize of this has been asked before, searching through 100 pages on my phone is a little hard.
K-NoMs is offline   Reply With Quote
Old 09-05-2014, 01:07 AM   #2491
infinit
infinit's Avatar
Drives: 2014 BRZ
New guy here, need a little help on wheel and tire combo. I searched and read as much as i could but just wanted to be sure. I plan on buying Rota P1-R's 18x9.5 +38 and was wondering if that would fit in the front, i know the back would be okay, i am lowered on eibach sportlines. If it does fit what would be the best tire size? Thanks.
infinit is offline   Reply With Quote
Old 09-05-2014, 01:33 AM   #2492
Neokolzia
Fairly sure this is a common setup, I've heard of 19's even fitting fine without rub with 1" drop in similar size.
Still looking for a answer myself if I should get these tires on or just don't bother.
The Following User Says Thank You to Neokolzia For This Useful Post:
K-NoMs (09-05-2014)
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
