Old 08-24-2014, 11:19 PM   #2465
itswences
Drives: 2014 Brz stock.
I'm a noob, and this probably has been answered before but would 18x9 with 35 offset and an inch drop be smart? and what size tires would be good?
itswences is offline   Reply With Quote
Old 08-25-2014, 12:52 AM   #2466
Kwise1
Kwise1's Avatar
Drives: Raven FRS
Originally Posted by boonFRS View Post
Read the first 20 pages and the last 10 and didn't see any info on this.
18x9.5 et35 squared.
What tire sizes should I run? Also would like to squared tires also for rotation purposes.
I do want a slight stretch for looks since it'll be a show car. On the fitment calculator it's showing that I'll be perfect with 235/40 front and rear. My buddy recommended 225/40 but the calculator is showing too much stretch for my taste.
Car is currently dropped on eibach sportline.
Thanks in advance.
If you plan on doing coils 225/40 is the way to go
Kwise1 is offline   Reply With Quote
Old 08-25-2014, 01:45 AM   #2467
Hotstuf1818
Elite Custom Lighting
Hotstuf1818's Avatar
Drives: 2014 Scion FR-S
Will these fit?
Anyone know if these will fit?
http://unleashedwheels.com/varrstoen-es6.html
And don't fking judge me. Im poor
Hotstuf1818 is offline   Reply With Quote
Old 08-25-2014, 10:19 AM   #2468
Kwise1
Kwise1's Avatar
Drives: Raven FRS
Looks like they come in 18x9.5 5x100 with a 35 offset. That will fit with some camber up front if you are lowered
Old 08-25-2014, 03:41 PM   #2469
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Yep, no issues provided you have a bit of camber which you should already have due to the 1" drop. -2.0 is ideal, a bit more (over 2.5) and it may be too close to the strut. Closer to -1.5 camber and it will start poking out but shouldn't rub.
Good tire size to run would be 245/35R18, matches OEM diameter bang-on.
I've been running this setup for a year and a half, now with 255/35R18.
My sign below shows my setup on my 245/35 Contis.
Slick is offline   Reply With Quote
Old 08-25-2014, 03:44 PM   #2470
Hotstuf1818
Awesome thanks a lot guys. Just purchased them. All black gloss with gold rivets.
Did a little stretch for the tire.
Old 08-25-2014, 03:59 PM   #2471
Cliu91
Cliuless
Cliu91's Avatar
Drives: Whiteout Scion FRS 2014
How does someone who is compeltely noob in this subject (tire size, wheel size, etc.) learn more about this?
Cliu91 is offline   Reply With Quote
Old 08-25-2014, 04:01 PM   #2472
Hotstuf1818
Ask around. I learned a lot.
Old 08-25-2014, 04:04 PM   #2473
Slick
Slick's Avatar
Some of it is basic math, knowledge about the car and what sizes and offsets work well and what doesn't.
Old 08-25-2014, 07:52 PM   #2474
FrSnake
Resident Noob
FrSnake's Avatar
Drives: Satin White BRZ Limited
Originally Posted by FrSnake View Post
Okay so this will be an odd question based on how many people love their coilovers. I have a set of 18x9.5, +45 Enkei Kojins that I would love to run on my car. Keep in mind that my car is not to race and disappointingly... I can't really swing coilovers financially and I refuse to go cheap with them. So it's the stock suspension life for me, and I'm okay with poke, but I need to figure out tires that will work so they can be rotated. I will be getting spacers too, most likely 10mm or whatever is recommended to keep me from rubbing too much.
I could use some help figuring this out if anyone's got a little time.. Thanks!
How about mine? Anyone know anything? Don't really want to buy tires that won't work/ need to know if I should just sell them
USAF2013 SWP BRZ Limited- CAI, Borla Cat-Back Exhaust
“Speed has never killed anyone, suddenly becoming stationary… That’s what gets you.” -Jeremy Clarkson
FrSnake is offline   Reply With Quote
Old 08-26-2014, 08:00 PM   #2475
itswences
Could you post some pictures of your car? I'd really like to see the setup before I commit to the specs.
Old 08-27-2014, 03:12 PM   #2476
Slick
Slick's Avatar
On Eibach Prokit, 18x9+35 and Conti Extreme DW 245/35R18
And now this year with 255/35R18's mounted.
Old 08-27-2014, 05:17 PM   #2477
Slick
Slick's Avatar
You won't have that poke until you add spacers. You may need 3-5mm spacers up front since you're on stock suspension and 0 camber, rears should be okay though.
Best tire is a 245/35R18 so you minimize any rub from the poke and proper OEM diameter.
Ideally that wheel size would be better with a 255 or 265 wide tire, but don't think you'll be able to run that wide on stock suspension, it will be too close.
So you'll have a bit of stretch with 245's but not too much. Kinda like my sig below.
The Following 2 Users Say Thank You to Slick For This Useful Post:
FrSnake (08-28-2014), LXXXV1 (09-05-2014)
Old 08-28-2014, 12:12 AM   #2478
Mlprltw
Drives: Toyota fr-s
I'm looking at a set of 57DR gram lights, but I'm wondering if 18 x9.5 it too wide? With a 38mm offset. I don't know too much about the fitment for my frs. It's lowered with H and R super sport springs.. Any help would be appreciated!
Mlprltw is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
