Old 08-29-2014, 11:31 AM   #71
CSG Mike
CSG Mike's Avatar
Originally Posted by Yui-Chan View Post
Yes...I meant, a stock porsche might not be as capable as your tuned setup.
I never mentioned ride quality/comfort.
I also meant, how your car compares to a porsche since it has similar power now.
It's still just a Subaru.
Or do you mean in terms of street racing?
Old 08-29-2014, 11:44 AM   #72
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
PFC08 FTW. You'll get more track days out of them so they'll cost the same or less in the end.
Old 08-29-2014, 01:10 PM   #73
ddeflyer
I'd say your's sounds grouchy; kind of like "I'm annoyed and gonna tell you about it".
Fun car leads to autocross, autocross leads to track days, track days lead to lemons, lemons leads to racing school, racing school leads to spec Miata...
No idea where it leads next!
ddeflyer is offline   Reply With Quote
Old 08-29-2014, 03:16 PM   #74
Yui-Chan
Drives: Toyota
Haha. You're funny.
Yui-Chan is offline   Reply With Quote
Old 08-29-2014, 04:02 PM   #75
ddeflyer
It is amazing what you can do with enough money. For example, for a few million dollars you can strap a C130 to a BRZ and really make it fly!
Old 08-29-2014, 11:46 PM   #76
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
At least the engine's in the right place.
:trollface:
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
Racecomp Engineering (09-09-2014), Yui-Chan (08-30-2014)
Old 09-09-2014, 07:26 PM   #77
BRZ NA
Drives: WR blue
Jackson Racing Supercharger, CARB (California Air Resource Board) legal
So I m assuming norcal legal too?
BRZ NA is offline   Reply With Quote
The Following User Says Thank You to BRZ NA For This Useful Post:
CSG Mike (09-09-2014)
Old 09-09-2014, 08:00 PM   #78
CSG David
CSG David's Avatar
Yes.
Old 09-09-2014, 09:13 PM   #79
BRZ NA
Drives: WR blue
Originally Posted by CSG David View Post
Yes.
Sorry forgot to mention, No problem w smog check too?
Old 09-09-2014, 09:45 PM   #80
CSG Mike
CSG Mike's Avatar
Correct, we smogged our 2014 BRZ AFTER we put the JRSC on; it was purchased out of state, which means its required to get a smog check to be registered in California.
BRZ NA (09-10-2014)
Old 09-10-2014, 12:44 AM   #81
Yui-Chan
Drives: Toyota
I've always wondered how various "CARB approved" parts and kits worked at a smog station, come test time (I''ve never owned real CARB aftermarket parts b4). I usually revert everything back to stock (or illegal $200 smogs back in the day lol.. too old and don't wanna do that anymore haha).
But ya...what was the process, and were there any differences you noticed between a totally stock car, if you don't mind sharing? ...did the smog station give you a hard time, ask questions, gave a more intense visual check, or anything else out of the ordinary smog....?
Old 09-10-2014, 02:13 AM   #82
CSG David
CSG David's Avatar
They check for the EO sticker, look up the EO # in the CARB database, and match up the CARB component with the registered CARB EO component. When everything is verified, they will also add in the fact there are CARB aftermarket components on the vehicle. The new 2014 process that got rolled in as well includes a complete visual check on all components of the car and requires the OBD2 port to read all the sensors.
Our car went through the older sniffer process and yielded factory level emissions levels (way below limit).
The Following User Says Thank You to CSG David For This Useful Post:
Yui-Chan (09-10-2014)
Old 09-10-2014, 02:32 AM   #83
CSG Mike
CSG Mike's Avatar
You show up to smog, and smog like normal. No additional steps or anything, the tech should see the CARB sticker, and verify that the kit is indeed legal.
Old 08-07-2015, 05:25 PM   #84
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
Originally Posted by ddeflyer View Post
Given your choices I suspect you don't have much experience in track days.
First and foremost, ditch the carbon fiber and get a full, custom roll cage, harnesses (I'd assume you already have a HANs device) and mounting of your fixed back seat. Then go with 17x8 wheels (do long wheel studs while you are at it so you can get them on and off more easily), you don't need the extra width that much when on stock power and the tires are much cheaper.
Your brakes are not the right price, $2600 is the list price for the endurance kit, but probably better to get the sprint kit ($2100) since it weighs less. I'd skip the cooling ducts unless you actually manage to need them, less chance of overcooling the rotors. And don't forget pads for the rear (figure $220) and some new brake and other fluids ($300 worth or so I think).
For the engine, I'd do the JR oil cooler (more capacity) and skip the radiator (not needed on stock power). Also don't forget a catch can and removal of cats along with a solid tune, probably for E85.
And the different steering wheel? I wouldn't bother with that. You would want some data logging though, for that price you could have it permanently installed which would be nice.
I'm not that familiar with the coilovers, but I would budget more for that; you want to keep the wheels on the ground as best you can!
If there were any budget after that, I would think about a different differential; the e-diff function gets annoying pretty quickly once you turn off the traction control and I hear it should help with that.
is a catch can really that ncecessary?
Celery man
Electrical space wizard
Icanfaptothis86 is offline   Reply With Quote
Most power Normally Aspirated? FRSBRZGT86FAN Scion FR-S / Toyota 86 GT86 General Forum 606 02-18-2016 01:27 PM
200+ WHP Naturally Aspirated on 91 Octane DeliciousTuning Software Tuning 62 02-10-2015 08:34 PM
Morpheus, Scion dream Build. Supercharged FR-S by TuneCast scionsalesjay Member's Car Journals 51 07-07-2014 12:05 PM
dream track alignment? puma Tracking / Autocross / HPDE / Drifting 25 06-15-2014 07:32 PM
Dream.Build.Drive TylerLieberman Other Vehicles & General Automotive Discussions 3 05-28-2014 11:53 PM
