Old 08-16-2014, 10:08 PM   #547
twmade
Drives: GT86
@Shiv@Openflash I just sent you a private pm with my details - I have a 2015 car and it shows as my ECU have no tune files, can you let me know what to do?
twmade is offline   Reply With Quote
Old 08-16-2014, 10:37 PM   #548
steve99
Drives: FT86
best to email shiv pm,doent work
If your oft is brand new it will have v1.5x tunes loaded not the latest v2x tunes that support 2015 cars if your manual latest rom is calid D00C auto will be D00D , but you will have to download and apply the latest tunes to tablet
se link below OFT TIPS.
If still no joy email shiv your stock rom or at least the calid like ZA1JD00D or whatever
Old 08-16-2014, 10:48 PM   #549
twmade
Drives: GT86
I have a 2015 86 from China so I don't think the v2x tunes on the download section will work for me as it says it is for USDM cars - am I correct? For reference my CAL code is ZA1JA03N. I'll send Shiv an email to confirm ..
Old 08-16-2014, 11:03 PM   #550
steve99
Drives: FT86
lol by bad, thought you were in vancouver, yes on N rom support is for A01N series, shiv will have to make new rom for you and the romraider guys will probably need to define the A03N rom if tables are different
definitly email shiv with a copy of stock rom
Shiv shoul be able to make a map from the A01N rom to get you going. You can do it yourself if your handy with a hex editor but safer to let shiv sort it
twmade (08-16-2014)
Old 08-16-2014, 11:15 PM   #551
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by DC2R View Post
Yes please post
Sent from my SM-N900T using Tapatalk
Scosche Magic Mount
http://www.scosche.com/mmwindow
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following 2 Users Say Thank You to phobos512 For This Useful Post:
DC2R (08-17-2014), Slick (08-17-2014)
Old 08-17-2014, 12:34 AM   #552
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Originally Posted by solidONE View Post
Yup! With the new MAF scale it seems to come pretty close to target AFR's Less than 0.5:1 plus or minus from what I've experienced (as opposed to the older versions, that were way off). So it's probably safer to error on the richer side when changing the fuel table.
I scaled the MAF, and adjusted the AFR a "little bit" leaner. Small steps. The throttle response is excellent.
http://www.datazap.me/u/tonystewart/...log=0&data=1-7
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 08-17-2014, 01:38 AM   #553
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Not sure what your intake temps were but you're already registering higher MAF voltages at the top end with no knock in sight (I've found that cooler IAT's tend to register higher voltages), aside from a bit of tip in knock on the 3rd pull. I've also found that in higher temps the AFR's seem to lean out a little bit. You will have to account for the hot summer temps that you guys must see over there, but you weren't kidding about only adjusting it a little. lol I'm sure your daughter *wink wink nudge nudge* will love it.
Old 08-17-2014, 02:51 AM   #554
tonystewart
If the car wasn't leaving for college, I'd consider replacing the first cat (header) with a straight pipe, but the noise is uncomfortable after 6-7 hour drive.
I took those three pulls, added them to the MafScaling tool and ran it again, 11 adjustments from 5 down to 2.77.
Adjusted the AFR table from 5400 to 7400 as well. I may be close to accurate.
Wish I had that new Ptuning EL header with this tune
Old 08-17-2014, 03:12 AM   #555
akahenry
akahenry's Avatar
Drives: '18 STi
Originally Posted by phobos512 View Post
How well does this work? I'm slightly skeptical...
akahenry is offline   Reply With Quote
Old 08-17-2014, 08:47 AM   #556
phobos512
phobos512's Avatar
I had one for my phone and bought a second for my OFT. Phone one is adhesive mounted to dash, OFT one is the suction arm in that link (allows me to use in other cars). I stick it to the fixed window on the door. Works great. OFT weighs nothing so there's no issue. I'm not the only person that uses this style of mount - got the idea from this forum actually.
Old 08-17-2014, 09:13 AM   #557
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
This is very strong man. It's such a clean solution. Get the one with the adhesive back
drewbot is offline   Reply With Quote
Old 08-17-2014, 09:13 AM   #558
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
Mail me the rom so I can make a Romraider definition as well.
Td-d is offline   Reply With Quote
The Following User Says Thank You to Td-d For This Useful Post:
twmade (08-17-2014)
Old 08-17-2014, 09:13 AM   #559
tonystewart
It was 75F and it had just rained heavily, I will stick to datalogging after 11pm, I should have less temperature compensation affecting the data
Old 08-17-2014, 01:16 PM   #560
solidONE
solidONE's Avatar
This is with a catted header? Dang... What about just using the secondary cat on the front pipe instead?
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 12:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 10:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
