Old 08-16-2014, 06:21 PM   #15
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Originally Posted by frsqc View Post
anybody running stage 2 UEL 93 on 94 petro?
Yes. 10/10 would recommend.
- AdrianG
AdrianG is offline   Reply With Quote
The Following User Says Thank You to AdrianG For This Useful Post:
flippy (08-16-2014)
Old 08-16-2014, 06:24 PM   #16
wparsons
wparsons's Avatar
No Husky 94 at any stations I've tried near Toronto
flickr
Old 08-16-2014, 06:26 PM   #17
jvincent
jvincent's Avatar
Originally Posted by wparsons View Post
Have you logged IAM, FLKC and Knock Correction to see if you're getting any knock at part throttle in the 2500-3500 rpm range? I get a lot of knock in there on shell 91 with a 91 map, but it's fine above 4000rpm at WOT. I found that it's the worst when stuck in traffic.
On the 93 map with petro 94 there's no knock at all.
I haven't, but I'll try to do that. I have an OBD dongle for torque plugged in. Do you know if Torque logs those?
Its a minor pain to have the OFT in the car.
Old 08-16-2014, 06:26 PM   #18
frsqc
Drives: raven FRS
- AdrianG
thanks! im uploading it right now to the car, ill log what should i look to be worrysome?
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
Old 08-16-2014, 08:53 PM   #19
wparsons
wparsons's Avatar
Not sure, haven't ever used it.
flickr
Old 08-17-2014, 08:19 AM   #20
AdrianG
IAM, FLKC, KC Learned, STFT, LTFT, AFR... I could be missing something but that's a start.
- AdrianG
Old 08-17-2014, 08:22 AM   #21
AdrianG
Torque is really just a toy compared to OFT or OP2, the best rate you can hope for with elm327 is ~300ms which means it's pretty much useless for real data logging. And no, it doesn't have the parameters you need as far as I know.
- AdrianG
Old 08-17-2014, 08:58 AM   #22
wparsons
wparsons's Avatar
- AdrianG
Add commanded AFR as well.
flickr
Old 08-17-2014, 09:10 AM   #23
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Torque doesn't have IAM immediately, you have to program the address in
Off the bat you have AFR, STFT, LTFT, timing advance
drewbot is offline   Reply With Quote
Old 08-17-2014, 09:12 AM   #24
ShibaYuki
Drives: 2013 WRB Subaru BRZ Sport-tech
So should anyone recommend Shell 91 octane for a 91 map tune? I've been using Shell 91 ever since I got the car, and never got the crickets. But now that I'm going to be getting my OFT soon, I don't feel confident enough to stay in Shell 91 oct.
ShibaYuki is offline   Reply With Quote
Old 08-17-2014, 11:01 AM   #25
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
I've run stage 1, Stage 2 and Stage 2 with BPB only on shell 91, since a year, and i didn't really had any problem... I had to remove a little bit of timing on the last update over 6 000 rpm to remove some knock issue
but.. i'm starting to think about other brand of gas, to see if it could be better
Walla Walla is offline   Reply With Quote
Old 08-17-2014, 11:10 AM   #26
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
How is the BPB with the OFT tune? I'm rely interested in doing this before winter starts
Old 08-17-2014, 01:06 PM   #27
frsqc
Drives: raven FRS
iam is adv multiplier?
Old 08-17-2014, 02:47 PM   #28
frsqc
Drives: raven FRS
nvm , iam constant 1 0% knock correction. afr and such no idea what to look for but seems in check.
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
Drift-Office : AVO Turbo Kit Stage 1 ~ 91 Octane Calibration Drift-Office Forced Induction 30 04-18-2013 02:25 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Stage 1 93 or E85 Octane ECUTek tunes Available in Miami Bill@SiR Engine, Exhaust, Bolt-Ons 0 08-30-2012 03:45 AM
