Old 08-15-2014, 02:44 PM   #1
flippy
flippy's Avatar
Drives: 2013 Firestorm Scion FRS
OFT v2.0 Stage 1 93 Octane in Canada
Do you guys use 94 Petro canada gas? It has up to 10% Ethanol
Is it good enough for this OTS map or should I use 91map?
Originally Posted by bdanisi View Post
Can we close this thread it wasn't intended to become vaginal pun fodder
flippy is offline   Reply With Quote
Old 08-15-2014, 03:03 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I've always found that the Petro 94 gas in Canada to be pretty poor. So I would start off with the 91oct map and make sure that logs look good. If they show knock, I would even consider trying a lower octane 91oct fuel not from Petro.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
flippy (08-15-2014)
Old 08-15-2014, 03:23 PM   #3
fenton
I run Shiv's Map for phantom supercharger on Husky 94 and i have NEVER seen knock under load.
Occasionally you get .6 of correction on tip in but i think everyone gets that.
Usually it runs about 27 degrees of timing under boost and everything is A-OK.
http://www.datazap.me/u/fenton108/te...6262&mark=6222
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
flippy (08-15-2014)
Old 08-15-2014, 03:29 PM   #4
jvincent
jvincent's Avatar
I'm rocking the 91 map and pretty much always use Esso.
Runs nice and smooth, and mo' powah for sure.
The Following User Says Thank You to jvincent For This Useful Post:
flippy (08-15-2014)
Old 08-15-2014, 07:17 PM   #5
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I have run petro 94 exclusively in my car for 2 years, no issues. Currently on the 93oct 2.0 map with no knock, never reduced timing and the fuel trims hardly move.
- AdrianG
AdrianG is offline   Reply With Quote
The Following 2 Users Say Thank You to AdrianG For This Useful Post:
BolognaWalrus (08-19-2014), flippy (08-16-2014)
Old 08-15-2014, 07:29 PM   #6
Fareast auto part
Fareast auto part's Avatar
Drives: 2013 Toyota 86
If e85 is 104 octane and Petro is 91 octane can you blend the two (say 75% 91 and 25% e85) to make 95 octane gas ? Would this work and be safe (a/r ratio is different for e85) ? If it worked this would work out to be cheaper then buying Chevron 94 .
Fareast auto part is offline   Reply With Quote
Old 08-15-2014, 07:48 PM   #7
wparsons
wparsons's Avatar
Funny, I've found (based on IAM) that Shell 91 (on a 91 octane tune) is WAY more knock prone than Petro 94 (on a 93 octane tune).
My IAM was constantly down to like 0.5 from midrange knock on a 91 tune, but stays pegged at 1 with a 93 tune.
Some logs, mostly mixed driving to probe for midrange knock.
http://www.datazap.me/u/wparsons/aug...d?log=0&data=1
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
drewbot (07-24-2015), flippy (08-16-2014)
Old 08-15-2014, 10:34 PM   #8
AdrianG
@wparsons that's funny, I was going to mention you in my post as we're in the same area, but your IAM is always dropping on 91 and mine is rock solid on 94
- AdrianG
Old 08-16-2014, 07:42 AM   #9
dodouble
Drives: 2013 frs
so yay or nay on 93 2.0 tune with canada petro 94
dodouble is offline   Reply With Quote
Old 08-16-2014, 08:44 AM   #10
wparsons
wparsons's Avatar
I feel more confident in how it runs (based on logs) on the 93 octane tune with petro 94 than on the 91 octane tune with shell 91. So much so that I'll take the slightly worse mileage (I've always had slightly better mileage on ethanol free 91 than petro 94) and constant crickets.
91 logs:
http://www.datazap.me/u/wparsons/jul...og=0&data=1-12
http://www.datazap.me/u/wparsons/apr...log=0&data=1-8
Compare those to the 94 logs I posted above, I could never keep the IAM at 1 on 91 tunes.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Old 08-16-2014, 10:38 AM   #11
frsqc
Drives: raven FRS
anybody running stage 2 UEL 93 on 94 petro?
RAVEN FRS 2013 - TRD air filter - Nameless OP/DP - Greddy EVO3 - STAGE 2 OFT/OFH -
frsqc is offline   Reply With Quote
Old 08-16-2014, 12:53 PM   #12
R2
Here is a log I made the other day with the OFT 2.01 tune (Stage 1 - 93 oct) and a bit of MAF rescaling. This is with Husky 94. This tune seems to be performing well on that gas, not sure if Petro Can would be much different, but I don't have it around here.
http://www.datazap.me/u/r2/aug-14?log=0&data=1
R2 is offline   Reply With Quote
The Following User Says Thank You to R2 For This Useful Post:
flippy (08-16-2014)
Old 08-16-2014, 01:25 PM   #13
wparsons
wparsons's Avatar
Have you logged IAM, FLKC and Knock Correction to see if you're getting any knock at part throttle in the 2500-3500 rpm range? I get a lot of knock in there on shell 91 with a 91 map, but it's fine above 4000rpm at WOT. I found that it's the worst when stuck in traffic.
On the 93 map with petro 94 there's no knock at all.
flickr
Old 08-16-2014, 02:03 PM   #14
SpeedyJay
SpeedyJay's Avatar
Drives: '13 WRB BRZ
Husky 94 has a lot better knock resistance, we have tested it on the dyno at airboys all the Evo X guys use 94 husky with better results then petro 94.
In God We Trust - Hold No Faith That Violates Reason
SpeedyJay is offline   Reply With Quote
The Following User Says Thank You to SpeedyJay For This Useful Post:
flippy (08-16-2014)
FBM Stage 1 Cams w/ Stage 2 Head Results 743HP! FullBlown Forced Induction 119 03-24-2015 10:16 PM
Questions about upgrading the avo stage 1 turbo kit to stage 1.5 and 2 Astroboy Forced Induction 4 03-01-2014 07:29 PM
Drift-Office : AVO Turbo Kit Stage 1 ~ 91 Octane Calibration Drift-Office Forced Induction 30 04-18-2013 02:25 PM
100 octane race gas: 91 octane ratio? GhostofAkina Scion FR-S / Toyota 86 GT86 General Forum 15 02-08-2013 01:23 AM
Stage 1 93 or E85 Octane ECUTek tunes Available in Miami Bill@SiR Engine, Exhaust, Bolt-Ons 0 08-30-2012 03:45 AM
