Old 08-14-2014, 08:10 PM   #141
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by Ubersuber View Post
You will note that Subaru/Toyota are moving the roll stiffness bias of the FRS towards the front axle for 2015. It has been suggested that they employ talented engineers. I'm pretty sure the TRD spring and roll bar kits will both move the roll stiffness bias forwards also.
Because too many people can't drive and have spun them into solid objects. This isn't rocket science from a PR perspective. Toyota did the same thing when they dumbed down the MR2 to protect the stupid from themselves, and Honda did it somewhat with the S2000 also.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
Old 08-14-2014, 08:22 PM   #142
Ubersuber
Drives: BRZ Pearl White
I'm pretty sure that isn't it. There is no suggestion that the BRZ spring rates will be changed though I expect the improved dampers will be added to the BRZ also.
The legal liability issues are adequately covered by the electronic stability aids that cannot be switched off fully (at least not officially) and will reactivate should a driver overstep certain parameters. Also, the electronic stability aids must be consciously and deliberately switched off (5 seconds for the BRZ and longer for some other cars) and this must be repeated every time you restart the car. Nope they got the liability angle covered.
Also, the electronic aids are very capable and should protect most drivers who are not taking these cars to extremes of tire grip, no systems can defeat the determined efforts of a sufficiently incompetent driver.
Subaru/Toyota both claim the changes they are making are to improve the handling of these cars and they hired a racing driver to help them prove it, apparently.
Who are we to speculate that they are doing this wrong?
Granted each to his own driving style, but ALL current F1 cars are driven without any oversteer whenever possible. Anytime an F1 car goes even a tiny bit sideways it is slower. That's worth considering by anyone seeking lower lap times from any car.
Ubersuber is offline
Old 08-14-2014, 08:24 PM   #143
Dipstik-sportech
Dipstik-sportech's Avatar
Can someone please ban this obvious troll please. Thanks.
Dipstik-sportech is offline
The Following 5 Users Say Thank You to Dipstik-sportech For This Useful Post:
BatStig (08-14-2014), CoupedUpSubie (08-14-2014), ftc~brz (08-15-2014), Shagaliscious (08-22-2014), wparsons (08-14-2014)
Old 08-14-2014, 08:30 PM   #144
Calum
That Guy
Drives: 2013 asphalt FRS MT
Calum's guide on how to make the car fix Suberman's inability to drive correctly.
Attend a few HPDE classes.
The only time I've had the back end step out on me is when I get REALLY ham fisted with it. My last project car needed that to get it to rotate, so I was pretty surprised the first time it happened in the FRS. But after I learned to drive it more smoothly I found that oversteer and understeer are available upon request, as long as I choose my corner line and braking point ahead of time.
That's not to say I haven't found ways of improving my ability to drive this car quicker by modifying the suspension. But the mods I've made haven't been for improved grip, but improved driver confidence.
Calum is offline
The Following 5 Users Say Thank You to Calum For This Useful Post:
CSG Mike (08-14-2014), Dave-ROR (08-14-2014), ftc~brz (08-15-2014), sklimo (08-15-2014), wparsons (08-14-2014)
Old 08-14-2014, 08:49 PM   #145
wparsons
wparsons's Avatar
Well, that may be why you are fitting clutch type LSD...
If you aren't adding any power you might not notice that you could be quicker if you did the opposite.
Did you miss the part of the thread about clutch LSD's where CSG said they did the testing with stock suspension and power?
Also, are you seriously suggesting that your theory offers more value on suspension tuning than the vast amount of testing CSG, RCE, etc have done. They don't just try one thing and claim it as gospel, they try MANY setups with data logging to back up their claims on what works and what doesn't.
Setup depends greatly on driver style and preferences. The car you like (based on this thread) is a car I'd HATE to drive. You'd hate any of my cars on the track too.
On the street, it's whatever. I drive like a responsible person on the street normally so oversteer has never been a concern of mine. Your threads remind me of all the S2K idiots who spun cars in intersections because they can't control the throttle. That's another car I made more loose on purpose. :shrug:
He'll never get it. Even on stock tires I never once had mine step out of line unexpectedly.
Understeering cars feel safer at the limit to inexperienced drivers, but are ultimately slower. Neutral biased towards looser is faster, as long as the driver is comfortable behind the wheel.
flickr
wparsons is offline
Old 08-14-2014, 08:51 PM   #146
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by Calum View Post
The only time I've had the back end step out on me is when I get REALLY ham fisted with it. My last project car needed that to get it to rotate, so I was pretty surprised the first time it happened in the FRS. But after I learned to drive it more smoothly I found that oversteer and understeer are available upon request, as long as I choose my corner line and braking point ahead of time. .
I have found my BRZ on stock tires is quite tail happy and I dont have to be "Ham-fisted"with it, just "sporting".
Most people would not even notice the frequent "excursions outside the traction circle" in these cars because the TCS masks it so well.
I have never learned how to recover the BRZ from an oversteer event (intentional or otherwise) as I have in all my other RWD cars because this car wont let it get out with the nannies engaged.
So MOST BRZ/FRS drivers dont KNOW how tail happy these cars really are.
I will honestly state that as a fact.
stugray is offline
Old 08-14-2014, 08:57 PM   #147
Model Citizen
Lacking brains
Drives: frz
Whoever changed the title deserves sainthood.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline
The Following 15 Users Say Thank You to Model Citizen For This Useful Post:
Bobblehead (08-14-2014), Captain Snooze (08-15-2014), CSG Mike (08-14-2014), Dipstik-sportech (08-14-2014), drewbot (08-14-2014), ftc~brz (08-15-2014), husker741 (08-15-2014), jebuwh (08-14-2014), JohnJuan (08-14-2014), jvincent (08-14-2014), Khorne (08-14-2014), Shagaliscious (08-22-2014), sklimo (08-15-2014), stugray (08-14-2014), wparsons (08-15-2014)
Old 08-14-2014, 09:03 PM   #148
CoupedUpSubie
Drives: 2013 BRZ Limited
BRZ on stock tires with TCS off will result in the car going extremely tail happy only if one is taking off quick and cranking the wheel or the tires are overheated resulting in highly reduced traction.
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears
1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust
1993 Honda CB750 Nighthawk
CoupedUpSubie is offline
The Following User Says Thank You to CoupedUpSubie For This Useful Post:
Old 08-14-2014, 09:14 PM   #149
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've found the TCS/VSC to be overly sensitive. My first track outing I left it in sport mode and it came on so often I was actually concerned. I then drove it with everything off and determined the car was too pushy and needed to be looser. :shrug:
And I know how tail happy they are: [ame="https://www.youtube.com/watch?v=1m_Iy6gTPVg"]Oops in turn 1 at Sebring. Subaru BRZ / Chin Motorsports 4-13-13 - YouTube[/ame]
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
The Following 4 Users Say Thank You to Dave-ROR For This Useful Post:
CSG Mike (08-14-2014), gramicci101 (08-15-2014), stugray (08-14-2014), wparsons (08-15-2014)
Old 08-14-2014, 09:16 PM   #150
CSG Mike
CSG Mike's Avatar
Slowly approaching the edge of the traction control always results in understeer with the car... if you get the tail out with a stock car, you're using large weight transfers, whether you're aware of it or not.
CSG Mike is offline
Dave-ROR (08-14-2014), wparsons (08-15-2014)
Old 08-14-2014, 09:20 PM   #151
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
It was probably some piece of shit vendor protecting moderator. Those guys are ****heads.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Dave-ROR is offline
The Following 10 Users Say Thank You to Dave-ROR For This Useful Post:
Captain Snooze (08-15-2014), Createddeleted (08-14-2014), ftc~brz (08-15-2014), husker741 (08-15-2014), jebuwh (08-14-2014), JohnJuan (08-14-2014), Khorne (08-14-2014), Shagaliscious (08-22-2014), sklimo (08-15-2014), wparsons (08-15-2014)
Old 08-14-2014, 09:28 PM   #152
CoupedUpSubie
As for the whole a bump stop is not a spring, that is incorrect.
A spring:
a resilient device, typically a helical metal coil, that can be pressed or pulled but returns to its former shape when released, used chiefly to exert constant tension or absorb movement
It is typically a helical metal coil, but does not have to be. Anything which has a spring constant is classified as a spring.
I say this with actual knowledge and the education to support this stance.
@Ubersuber we would love to know where you extensive knowledge comes from.
Old 08-14-2014, 11:52 PM   #153
litemup
Drives: around
Mike, a question from the noob section: I've noticed this as well but was quickly trounced in another thread for expressing appreciation of the FRS' "neutrality." (frs vs brz blah blah...)
On long sweepers where I would like to add a little throttle, I can't because it just exacerbates the condition.
Taking the most incremental approach, would it be worth the effort trying to manage this by tweaking tire pressure? I feel a skid-pad session coming this weekend.
litemup is offline
Old 08-15-2014, 12:21 AM   #154
s2d4
s2d4's Avatar
Hahah, the irony.
Although I still don't agree with you that people doing favours for a 6 pack or free dinner needs to pay for vendor fees or vendors lying about designing their turbo kits when it's a knockoff should be immune from people not happy with such business ethics.
However, let's agree to disagree on that front.
s2d4 is offline
225 width perf snow tires, 7thgear haz flair, i'm afraid of the snow, lawyers can't drive, magical suspension expert, my first period, überstupid
How to do E85 correctly? Anthony Engine, Exhaust, Transmission 95 12-11-2017 04:06 PM
Perrin 3" CBE - did I install correctly? 1Cor10:23 Engine, Exhaust, Transmission 14 12-08-2014 12:29 PM
Boost gauge not reading correctly Pneub Forced Induction 11 10-30-2013 12:39 PM
Drive Away prices on Toyota Website. Make sure you are not getting Ripped Off! Aventador87 AUSTRALIA 8 06-17-2012 07:35 AM
Toyota 86 first drive review (Car Guide) a6ela Scion FR-S / Toyota 86 GT86 General Forum 22 03-14-2012 12:34 PM
