#127 | |
Drives: 2013 GBS BRZ Limited
The only "bump stops" I am familiar with are firm and definitely "stop" travel when they are reached (like a turnip :-) So these are more like "bump squish(es)"?
#128 | |
That is unsprung weight so you get a double benefit. I crack up at the track when I see someone who spends thousands shedding a couple of pounds from their car, but can barely squeeze into an X-Large racing suit.... |
#129 |
#130 |
Because compromise ®
Drives: Red Herring
Well, depending on one's economic view it is not free. There was the initial outlay of buying the raw materials. I also think it's a pretty (not literally) good mod even if you aren't broke.
| The Following User Says Thank You to Captain Snooze For This Useful Post: | Shagaliscious (08-22-2014) |
#131 | |
Drives: BRZ Pearl White
Just put one in an ordinary wood vice and you will find that the bump stop becomes functionally incompressible once the waisted segments are in full contact with the bulged sections, as you would expect. They most definitely limit suspension travel and it would be pointless to include them if they did not, their primary function is to protect the shock absorber from bottoming out, secondarily they prevent the spring or suspension members from internal contact with themselves or the car body. In the distant past this was their only function. If you have the physique of a gorilla, and possibly a matching intellect, you may find it easier than I did to gauge the compressibility of these bump stops. I am sceptical that a normal person can significantly compress these bump stops by hand. The internally contradictory posts suggesting both that these bump stops are easily compressed and that cutting a segment out might adversely affect handling are illustrative of the inaccuracy of many of the posts in this thread. To make a chassis easier to drift without substantially increasing torque at the rear tires one would increase roll stiffness at the rear of the car. To initiate a drift more easily one might also include additional rear suspension jacking (the infamous early 911 tendency as well as the Corvair and pre mark IV Triumph Spitfires). Fitting harder bump stops or longer bump stops, or both, would also make the chassis easier to provoke into a drift. The best way is still to add power. Reversing these changes and going the other direction would make the chassis more stable and return the bias towards understeer. |
#132 |
You should ensure you do so outside the vehicle also or the sprung weight of the entire package remains the same, even if your dump bounces.
#133 | |
Try a set of these: http://www.thewheeldeal.com.au/produ...&reviews_id=16 |
#134 | |
I figured IF the engineers were tasked with "making the car easier to drift" that they might have done it by controlling the roll abruptly using overly tall bump stops. IF that were true, then your suggestion of cutting them down would make sense to make the car less likely to drift (be stickier) |
#135 | |
Custom User Title
Drives: Asphalt FR-S MT
#136 | |
Site Moderator
Drives: Stuff
I've love to see Suberman drive my FWD track car.. if he thinks these cars are prone to bad oversteer behavior...
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#137 | |
It is painfully obvious (if only because they said so) that Subaru/Toyota spec'd this car to be able to drift, albeit modestly and with the electronics deactivated, at least only as far as the car lets you. In fact if you really try or one is really incompetent, the electronic nannies will step back in even if you switch them off, hence all the talk about the "pedal dance". Not only that but if this emergency reactivation of the electronics is activated the car will not let you switch off the assists until you park, shut off the car and restart. To make a modern car driftable with even half assed modern tires (which the Michelin Primacy's are) and only 151 lb ft of torque is quite an achievement. I found the ride unacceptably hard from the rear axle. I found the tendency to drift without sufficient provocation tiresome. I prefer a car that goes where it is pointed. I was very surprised that merely cutting the rear bump stops could affect the rear spring rates as much as it obviously has. Adding the Bilsteins was just a better idea yet, but I've found in the past Bilstein does a very good job of designing an upgraded shock which works well with stock spring rates, in cases where the OEM went a bit too cheap on this very important suspension component as Subaru/Toyota did on the launch version of this car. Bilstein are a well known OEM supplier, a cut above the run of the mill Sachs, though Sachs is perfectly capable of producing very good spec shocks and I understand Subaru/Toyota have gone to Sachs in an effort to improve the handling of these cars. I think either Sachs or more likely Bilstein has been called in to fix another Toyota product line: the latest Lexus IS 350 (the GS series is the same) and both the F Sport and the IS F benefitted from improved shocks. These are branded Toyota but I'm pretty sure they are built for Toyota by Bilstein. The irony associated with all the puerile attacks on my posts in this section arises from the fact that everyone who modifies these cars to make them more effective for the track moves the roll stiffness bias towards the front axle. The more power you add the more you must move the roll stiffness forwards. Everybody knows this, well at least everybody that understands how suspension works. I just achieved the same effect without increasing the already quite stiff front axle spring rates. |
#138 | |
Site Moderator
Drives: Stuff
CSG and I have both moved ours backwards.. but whatevs....
-Dave
#139 |
Well, that may be why you are fitting clutch type LSD...
If you aren't adding any power you might not notice that you could be quicker if you did the opposite. You will note that Subaru/Toyota are moving the roll stiffness bias of the FRS towards the front axle for 2015. It has been suggested that they employ talented engineers. I'm pretty sure the TRD spring and roll bar kits will both move the roll stiffness bias forwards also. |
#140 | |
Site Moderator
Drives: Stuff
I am? I haven't even driven the BRZ more than 50 feet in the last 2 or 3 months but I am putting a clutch type LSD in it? Setup depends greatly on driver style and preferences. The car you like (based on this thread) is a car I'd HATE to drive. You'd hate any of my cars on the track too. On the street, it's whatever. I drive like a responsible person on the street normally so oversteer has never been a concern of mine. Your threads remind me of all the S2K idiots who spun cars in intersections because they can't control the throttle. That's another car I made more loose on purpose. :shrug:
-Dave
| Tags |
| 225 width perf snow tires, 7thgear haz flair, i'm afraid of the snow, lawyers can't drive, magical suspension expert, my first period, überstupid |
| How to do E85 correctly? | Anthony | Engine, Exhaust, Transmission | 95 | 12-11-2017 04:06 PM |
| Perrin 3" CBE - did I install correctly? | 1Cor10:23 | Engine, Exhaust, Transmission | 14 | 12-08-2014 12:29 PM |
| Boost gauge not reading correctly | Pneub | Forced Induction | 11 | 10-30-2013 12:39 PM |
| Drive Away prices on Toyota Website. Make sure you are not getting Ripped Off! | Aventador87 | AUSTRALIA | 8 | 06-17-2012 07:35 AM |
| Toyota 86 first drive review (Car Guide) | a6ela | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-14-2012 12:34 PM |
