Northern California NorCal
Old 08-07-2014, 04:46 PM   #589
orthojoe
I'm down to come up to norcal if there's enough interest.
Still waiting for that magical 2:04 lap through thill in a stock setup 86....
2013 Subaru BRZ
orthojoe is offline   Reply With Quote
Old 08-07-2014, 05:02 PM   #590
acx23
Drives: 2013 FRS (Silver)
Easy. r6 with Martin or Andrie behind the wheel :p
acx23 is offline   Reply With Quote
Old 08-09-2014, 03:23 AM   #591
PMok
Codename: Stitch
PMok's Avatar
I finally got around to reviewing the logging I did in the 2nd session of the day last Saturday... in a nutshell yeah I need an oil cooler if I am to continue driving like this. Oil temps peaked at 276F that session, and keep in mind that was in the cooler morning session.
http://www.datazap.me/u/pmok/thunder...&data=1-2-5-10
The Following 4 Users Say Thank You to PMok For This Useful Post:
EAGLE5 (08-09-2014), mkivsoopra (08-09-2014), MyRx (08-09-2014), unsurety (08-09-2014)
Old 08-09-2014, 03:41 AM   #592
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Wow. I wonder how hot mine gets on Mines Rd. runs. I wonder why they didn't try to combat this more from the factory considering they know what people are going to be doing with these cars.
Sigh. Even more reason for me to order the Perrin oil cooler.
Originally Posted by humfrz
I'm old and lazy
Old 08-09-2014, 12:21 PM   #593
MyRx
MyRx's Avatar
Easy. They weren't expecting so many talented individuals to push an OEM NA.
They did however added a couple perks by having an easy to work with front end, front corner pockets, and ample space within the bumper and beam to cool however you like. So yea cool away.
Old 08-09-2014, 01:01 PM   #594
PMok
Codename: Stitch
PMok's Avatar
Several of us have used Mines as our testing grounds
You don't go WOT nearly as much on a road like Mines as you would on track for sure. So I doubt you would see such high temps on the street/canyon driving.
The general consensus is: street use only, oil cooler is recommended but not necessary. But if you track, seriously consider getting one. If you are FI and you track, absolutely necessary.
Old 08-09-2014, 01:04 PM   #595
mkivsoopra
I saw 265F oil temps on Mines after 5 mins of spirited driving WITH an oil cooler. I'm FI though.
mkivsoopra is offline   Reply With Quote
The Following 2 Users Say Thank You to mkivsoopra For This Useful Post:
PMok (08-09-2014), Xerious (08-09-2014)
Old 08-09-2014, 01:10 PM   #596
Xerious
Speed Chaser Thrill Seekr
Xerious's Avatar
Drives: 2014 Asphalt Monogram FR-S 6MT
I got no more than 220F on my FI with an oil cooler. It wasn't a very hot day though since we hit it early in the morning.
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint
My Build
Xerious is offline   Reply With Quote
The Following User Says Thank You to Xerious For This Useful Post:
PMok (08-09-2014)
Old 08-09-2014, 02:05 PM   #597
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I considered the Fullblown oil pan at one point. It has an extra quart oil capacity, which they say helps with cooling, and cooling fins on the bottom of the pan as well. I don't want to prolong cold start oil warmup... though I know certain coolers have a thermostat.
I really would like to avoid taking off the bumper cause of the tabs breaking. A couple of you guys mentioned a DIY oil cooler that didn't require taking off the front bumper, how did you guys find that? It was the one that bisects one of the radiator hoses. @PMok @RehabJeff86 @mkivsoopra
I didn't run any logs with my OFT. Would have been a good idea though, given that I had to switch to 91 on Sunday. But I didn't feel like the ECU was pulling timing. I plan on staying N/A with no more than 5-6 track days a year and I normally run E85.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
The Following User Says Thank You to unsurety For This Useful Post:
RehabJeff86 (08-09-2014)
Old 08-09-2014, 02:28 PM   #598
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
It was custom made by mkivsoopra, he made two
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
Old 08-09-2014, 03:32 PM   #599
mkivsoopra
Haha sw20kosh and I just followed a DIY thread
Old 08-09-2014, 05:53 PM   #600
acx23
Technically speaking, oil coolers that uses the coolant is not as effective as the normal air cooling oil coolers. Because the air temp will always be a lot lower than the coolant that's cooling the oil.
I did a DIY 16 row oil cooler so I've pull my bumpers off a couple of times. I didn't break any tabs and it was my first time taking off any bumper. I did find putting the bumper back harder and lots of patience than pulling it off.
Old 08-09-2014, 06:21 PM   #601
BRZChix
Drives: Subaru BRZ 2013
its almost unavoidable to take off ur front bumper. So consider u might have to take it out at least once. the tabs breaking only happens after x amount of time taking the bumper off n put them back on.
most of our fellow 86s "spirited" drivers told me to plan all the stuff u need to do to ur car that required taking off the front bumper altogether... we are on the same "never taken our front bumper off" boat
If i remember correctly, jsimon was on e85 and his oil temp still reads at 265
BRZChix is offline   Reply With Quote
Old 08-09-2014, 06:22 PM   #602
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
I considered that. Oil temperature isn't a huge concern for me. I know the oil will last longer with a cooler, and with stock these cars do run hot. But I don't quite understand the threshold where oil stars to shear, or when it will harm the engine, or seriously degrade high quality synthetic.
The temperature readout 121 F said on saturday @ T Hill. I am a novice, but I didn't encounter problems with power. I popped my hood after every session, and there was at least 50 minutes after every session to cool down.
I was more concerned with the air cooled oil coolers because the temperatures actually read too low. I don't know if the oil will get hot enough to evaporate moisture during winter.
I'm only using Redline or Amsoil 5w-20 and change @ 3.5k (E85)
2014 86CUP #2 - Willlow Springs International Raceway - Feb 16, 2014 CSG Mike Tracking / Autocross / HPDE / Drifting 34 03-09-2014 01:41 AM
2014 86CUP #2 - Willlow Springs International Raceway - Feb 16, 2014 CSG Mike Southern California 14 02-17-2014 04:52 PM
2014 86CUP #1 - Streets of Willow Springs - Jan 18, 2014 CSG Mike Tracking / Autocross / HPDE / Drifting 21 01-25-2014 10:58 PM
2014 86CUP #1 - Streets of Willow Springs - Jan 18, 2014 CSG Mike Southern California 103 01-24-2014 12:07 PM
Thunderhill on March 2nd (sat) NCRC sw20kosh Northern California 40 03-04-2013 05:10 PM
