Southern California SoCal
Old 01-22-2014, 01:01 PM   #1
2014 86CUP #2 - Willlow Springs International Raceway - Feb 16, 2014
Join the 86 CUP Facebook group! https://www.facebook.com/groups/1444342282448992/
Original rules discussion here: http://www.ft86club.com/forums/showthread.php?t=52982
Current standings here: http://www.ft86club.com/forums/showthread.php?t=56100
*use coupon code "willow25" at checkout to register for $90*
All new 86CUP drivers can get a free session of coaching with Mike (normally $75), first come first serve!
*Only official timing by eXtreme Speed will be accepted toward the results
**Event format will be FTD (Fast time of the day) between sessions 1-3
***You *must* fill out an entry form at the track to qualify for any prizes! Please ask @CSG Mike, @mav1178, or @ImperiousRex if you need a form!
**** Instructors will be able to take you and/or your guests for a ride around the track.
Feel free to come join, just to hang out and watch fellow enthusiasts drive at the track!
As featured in Gran Turismo 6
[ame="http://www.youtube.com/watch?v=-ze7RGPSY70"]Gran Turismo 6 Launch at Willow Springs Raceway - YouTube[/ame]
Fast lap at WSIR, featuring the @ImperiousRex BRZ:
[ame="http://www.youtube.com/watch?v=XU4Sa3RCCV4"]Willow Springs International Raceway BRZ/FRS/GT86 lap record 1:30.778 - YouTube[/ame]
Old 01-22-2014, 04:35 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
As posted in other thread:
For those of you wanting to go to this event, all I can say is:
Brake fluid and better-than-stock pads are a must if you want to drive more than 2-3 laps at a time.
-alex
The Following 3 Users Say Thank You to mav1178 For This Useful Post:
jflogerzi (01-23-2014), juliog (01-22-2014), WillRacer1jz (01-31-2014)
Old 01-28-2014, 05:54 PM   #3
Bizzump
Old 01-29-2014, 01:04 AM   #4
retrosmiths
Drives: Scion FR-S Whiteout
Got my Project Mu brake pads and fluid from CSG. Prepping my car before the track day!
@CSG Mike, some questions for you:
What tire pressure (cold) would you recommend for Michelin PSS on stock wheels?
Does a front splitter actually helps?
What do you think of 245/40/17 on a 17x8 for daily/track use? Which tires would you recommend?
Thanks!
2013 Scion FR-S
retrosmiths is offline   Reply With Quote
The Following User Says Thank You to retrosmiths For This Useful Post:
CSG Mike (01-29-2014)
Old 01-29-2014, 04:24 AM   #5
Sterz
Great White
Drives: 2013 Whiteout FRS
See you guys there! It will be my first track day on my FBM Kit, FBM radiator, and FBM Oil Cooler. Should be interesting though, I put down my first sub 1:30 time at Streets last time I went with just springs and sticky 245's and I was oversteering all over the place with stock motor
Sterz' Great White 86
http://www.ft86club.com/forums/showthread.php?t=54533
Invidia Q300 Catback | Invidia Catless Frontpipe | Invidia Overpipe
Sterz is offline   Reply With Quote
The Following User Says Thank You to Sterz For This Useful Post:
Old 01-29-2014, 11:25 AM   #6
Would you mind allowing us to collect some data from your car? We'd like to see how the FBM turbo does on track.
Old 01-29-2014, 11:27 AM   #7
Thanks!
Front splitters are absolutely beneficial, but if you increase front grip without increasing rear, you'll get a looser car as you get to higher speeds.
245/40/17 on a 8" is "in spec", but on the narrow end for the rim width. However, it'll be great for both DD and track use. You'll have more grip than a narrower tire, but slightly less steering feedback.
I can't really recommend a cold pressure, but 30psi will be a good starting point. Check your pressures IMMEDIATELY after you come off track every session, or if it feels loose, pull into the hot pit and check. You generally want to be between 36 and 38 hot, although exceptions exist.
retrosmiths (01-29-2014), WillRacer1jz (01-31-2014)
Old 01-29-2014, 11:34 AM   #8
retrosmiths
How do you increase rear grip if using a front splitter?
Would you suggest 235 on a 8" or should I go for a bit wider wheels for 245?
2013 Scion FR-S
Old 01-29-2014, 11:48 AM   #9
Rear aero, like a wing or diffuser.
Most people don't like wings for daily driving, but something like a Voltex or APR can be taken off fairly easily (under 2 minutes).
Old 01-29-2014, 12:41 PM   #10
Sterz
Great White
Not at all, I will help you guys out in any way that I can. Let me know.
Anthonytpt (01-30-2014)
Old 01-29-2014, 01:12 PM   #11
We just want to track some temps and timing advance.
I can take you for some laps in your car if you'd like as well.
Old 01-30-2014, 05:10 PM   #12
Sterz
Great White
Sounds like a deal!
CSG Mike (01-30-2014)
Old 02-04-2014, 09:31 PM   #13
Old 02-17-2014, 02:08 PM   #14
ImperiousRex
Track Junkie
ImperiousRex's Avatar
Drives: 2013 Subaru BRZ Limited, 2005 S2000
It was another beautiful day at Willow Springs but this time at the big track! Temps ranged from 55°F in the morning to about 75°F in the afternoon with a clear sky and some heavy crosswinds.
We had several returning competitors as well as handful of new folks and almost everyone walked home with a plaque to commerate their finishes
Thanks again to everyone who came out to compete and we hope you had a good time! @retrosmiths @deange @JDKane527 @juliog
Also @juliog was kind enough to snap a few pics from the event!
As always everyone is welcome to come out to these events whether it's your first time on track or if you're a grizzled veteran! See you next week at Buttonwillow!
ImperiousRex is offline   Reply With Quote
The Following User Says Thank You to ImperiousRex For This Useful Post:
retrosmiths (02-17-2014)
2014 86CUP #2 - Willlow Springs International Raceway - Feb 16, 2014 CSG Mike Tracking / Autocross / HPDE / Drifting 34 03-09-2014 01:41 AM
2014 86CUP #1 - Streets of Willow Springs - Jan 18, 2014 CSG Mike Tracking / Autocross / HPDE / Drifting 21 01-25-2014 10:58 PM
2014 86CUP #1 - Streets of Willow Springs - Jan 18, 2014 CSG Mike Southern California 103 01-24-2014 12:07 PM
Willow Springs International Raceway BRZ/FRS lap record (new track in Gran Turismo 6) CSG Mike Tracking / Autocross / HPDE / Drifting 13 10-15-2013 08:31 PM
Willow Springs International Raceway BRZ/FRS lap record (new track in Gran Turismo 6) CSG Mike BRZ Photos, Videos, Wallpapers, Gallery Forum 0 10-14-2013 12:17 PM
