Old 08-03-2014, 11:52 AM   #1
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Greddy Magnatic Oil Plug with OEM Washer
hello everyone. when i did my oil change, i changed my oem oil bolt to Greddy one and used washer that came with. i am going to do my next oil change soon and wondering using OEM washer is fine with Greddy bolt.
I am trying to avoid possible leak here. anyone with Greddy oil bolt, little help?
Old 08-03-2014, 11:57 AM   #2
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Should have no issue
Kuri is offline   Reply With Quote
The Following User Says Thank You to Kuri For This Useful Post:
zc06_kisstherain (08-03-2014)
Old 08-03-2014, 06:41 PM   #3
JB86'd
JB86'd's Avatar
Drives: JAWS
I use an OEM washer with the Greddy magnetic bolt. Holding fine so far
JB86'd is offline   Reply With Quote
The Following User Says Thank You to JB86'd For This Useful Post:
Old 08-03-2014, 08:13 PM   #4
zc06_kisstherain
Drives: SWP BRZ
Thanks. I heard someone had issue with oem one. I just wanted make sure.
Old 08-04-2014, 04:26 PM   #5
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
I use the OEM one as well. No issues to report
fantah is offline   Reply With Quote
The Following User Says Thank You to fantah For This Useful Post:
zc06_kisstherain (08-06-2014)
Old 08-04-2014, 04:57 PM   #6
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Mine leaked with the one the plug came with, its been fine with oem washers
Jrdad is offline   Reply With Quote
The Following 2 Users Say Thank You to Jrdad For This Useful Post:
brz408 (08-10-2014), zc06_kisstherain (08-06-2014)
Old 08-06-2014, 11:25 AM   #7
zc06_kisstherain
Drives: SWP BRZ
Good to hear!
thanks
Old 08-15-2014, 03:40 PM   #8
zc06_kisstherain
Drives: SWP BRZ
little late but i changed my oil last saturday
because of that magnetic bolt, when i unbolt, it stuck at pan!!! and oil splashed to group not to oil drain container! haha.
anyway, there is no weak as metnioned after changing oil.
Beware || oil drain plug washer (when changing your oil) mav1178 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 11-14-2021 07:07 PM
Greddy Oil Drain Plug - Leaking Pokeguyjai Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 09-25-2016 05:16 PM
Washer for oil drain plug missing? Kind of urgent. qqzj Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 02-07-2014 02:43 PM
GReddy Magnetic Drain Plug BRZ/FRS at Redline360 Redline360 Engine, Exhaust, Bolt-Ons 2 01-05-2013 11:19 PM
Engine oil drain plug washer BMWDavid Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 06-28-2012 12:28 PM
