Old 08-04-2014, 12:28 PM   #323
Tromatic
Driving with the latest version is pushing me hard towards the OFH and then a Phantom ESC.
Old 08-04-2014, 12:32 PM   #324
brzaapi
CAR-AHOLIC
brzaapi's Avatar
Drives: 2018 BRZ Ts - CWP
Originally Posted by Shiv@Openflash View Post
Edit (8/4/14): v2.02 just released. As noted in the read me file, the only change is that ZA1JD00C (2015 USDM 6MT) OTS Maps/XML support was added to download folder.
More 2015 ROM support coming soon....
Its great to hear that the 2015 maps are ready to go. I have been waiting eagerly. I cant wait for the Cayman 987.2 OFT to be ready.
Bad thing is I still got the BRZ on jacks since I was unable to get a detent bolt back into my tranny case while installing some MTEC springs. That bolt kicked my tail for almost 3 hours before the heat took it out of me and I called it a day. The bolt keeps trying to crossthread, but there isn't any real damage yet... so I assume I will be able to get it.
Then a reflash and E85 here I come. Can't wait for the my OFH to come in. Thanks Shiv.
Track Toy - 2018 BRZ Ts - CWP
Daily: Audi TT RS
DD/4WD - Colorado ZR2 Bison - Mallett Supercharger
brzaapi is offline   Reply With Quote
Old 08-04-2014, 03:32 PM   #325
sinned706
Drives: White BRZ Limited
i can't seem to get 2.2 XML's to load with 2.2 maps on Romraider. Doesn't seem to be working, but i can get 2.0 XML's to load with 2.0 maps.
sinned706 is offline   Reply With Quote
Old 08-04-2014, 04:52 PM   #326
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Been driving around with the STG1 2.01. I'm not sure if it just my imagination or the low rpm, partial throttle seems a whole lot more peppier. Feels very strong while just putting along with partial throttle.
The Following 2 Users Say Thank You to solidONE For This Useful Post:
JB86'd (08-04-2014), xxBrun0xx (08-04-2014)
Old 08-05-2014, 01:00 AM   #327
vynervt
Drives: GT-86
Originally Posted by ML View Post
what is the difference between B01c, and D00c technically?
There is Transient Ignition Retard different between B01C and D00C. Will this a good improve from Manufacturer?
Others map:
Cranking Fuel Injector Pulse Width F(ECT)
Misfire Count MAP Threshold A & B
vynervt is offline   Reply With Quote
The Following User Says Thank You to vynervt For This Useful Post:
ML (08-05-2014)
Old 08-05-2014, 02:50 AM   #328
troek
troek's Avatar
Drives: 2012 Toyota 86
I put 15 grand in parts on my car, now i need overnight roms for japan. Otherwise i wont decimate all.
troek is offline   Reply With Quote
Old 08-05-2014, 03:11 AM   #329
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
You'r enot imagining it. The revised MAF scaling is the biggest contributor to the partial throttle response/torque. Glad you like it
Shiv@Openflash is offline   Reply With Quote
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post:
flippy (08-15-2014), solidONE (08-05-2014)
Old 08-05-2014, 03:44 AM   #330
steve99
Drives: FT86
If you rearly keen you could do you own rom. compare a V1.5 C series with V2 C series then Copy all table changes to your series ROM then send to shiv to save him some work
Old 08-05-2014, 05:35 AM   #331
troek
troek's Avatar
Thats not a bad idea. Sounds simple, almost too simple, lol. Im out of town till next week, ill have to take a look when i get home. @Shiv@Openflash , thoughts?
Old 08-05-2014, 06:23 AM   #332
Kodename47
Kodename47's Avatar
Drives: UK GT86
Others map:
That transient table doesn't look right, mostly positive values which would be adding timing in those areas. Perhaps the base value is off?
Might be worth starting a new thread with the D00 ROM changes and post in full That way others will be able to make use of the changes now.
.: Stealth 86 :.
Kodename 47 DJ:
steve99 (08-05-2014)
Old 08-05-2014, 07:11 AM   #333
steve99
Drives: FT86
Yep think you called it looks like it off by + 20, subtract 20 from values in D00 and it pterry much same as before
Old 08-05-2014, 10:39 AM   #334
vynervt
Drives: GT-86
@steve99, You are right is about 20. I have compare the conversion table. As show in the photo i attached.
On LHS is ROM B01C & RHS is ROM D00.
Old 08-05-2014, 10:55 AM   #335
steve99
Drives: FT86
Yes looks like Definition needs fix will email @Shiv@Openflash
what do the other changed tables look like ?
Old 08-05-2014, 11:40 AM   #336
makinen
makinen's Avatar
Drives: Toyota 86
You can do it.
Already done with BPB beta and 2.0 beta.
Much better than 1.5x.
makinen is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
