Old 07-29-2014, 03:10 PM   #6861
Winjr
Drives: 2013 Subaru BRZ Premium
Originally Posted by TM View Post
I must say, I am very impressed by the way Rob stands behind his product!
I think we're all aware of the level of support that some aftermarket vendors provide for their product (which is to say, hardly any) - Rob has positioned himself as the polar opposite.
If the intent is to build a brand with staying power, Rob has taken the right path.
Winjr is offline   Reply With Quote
The Following 4 Users Say Thank You to Winjr For This Useful Post:
DAEMANO (07-29-2014), raven1231 (07-29-2014), Sojhinn (07-29-2014), WRB5titch (07-29-2014)
Old 07-29-2014, 04:04 PM   #6862
bfrank1972
Drives: 2013 FR-S Argento
Originally Posted by Boofneenee View Post
These episodes of faulty product are discouraging just a week away from possibly purchasing a used phantom..... is their a warranty and will it transfer over to the new owner?
For f's sake, does it take you this long to decide on everything? Just buy the damned thing!!
The Following 6 Users Say Thank You to bfrank1972 For This Useful Post:
Boofneenee (07-29-2014), DAEMANO (07-29-2014), enwave (07-29-2014), raven1231 (07-29-2014), Sojhinn (07-29-2014), WRB5titch (07-29-2014)
Old 07-29-2014, 04:36 PM   #6863
Target70
Target70's Avatar
Drives: 2013 Asphalt 6spd
Originally Posted by Gary in NJ View Post
...The only way to weed-out defects is to conduct timely and costly dynamic heat cycle testing (-40/70C). These chambers cost $50k for a small chamber, plus the custom equipment to run the test.
I'm sitting 100' away from two of them right now.. anyone want to send me a free esc kit to test?
I can tell you from experience that while the sound-tube hole in the firewall is convenient, its not the best location for running wires. You must ensure that the harness does not sag at all at the engine side of the outlet. Best practice is to use silicone to fill the hole (to ensure fumes do not enter the cabin and that the harness is secure) and use zip-ties to make sure that the harness is away from the exhaust manifold.
If the sound tube hole is not optimal, Is there enough slack to run the harness through the firewall beside the ecu harness? Due to my current setup, it would be very easy for me. And it would keep the harness away from the exhaust/heat.
Phantom ESC, OFH, OFT, K&N Drop in
Target70 is offline   Reply With Quote
Old 07-29-2014, 04:44 PM   #6864
fenton
I have mine on that side but it doesn't look as nice.
fenton is offline   Reply With Quote
The Following User Says Thank You to fenton For This Useful Post:
Target70 (07-29-2014)
Old 07-29-2014, 06:29 PM   #6865
l0aded
Addicted
l0aded's Avatar
Drives: 2013 Asphalt FR-S 6MT
July's over. Hopefully soon =). Will people on the list be notified by forum PM? Don't want to miss my chance.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
l0aded is offline   Reply With Quote
Old 07-29-2014, 06:29 PM   #6866
DAEMANO
Time Traveller
You need to feel this thing on e85. Legendary.
The Following 2 Users Say Thank You to DAEMANO For This Useful Post:
l0aded (07-29-2014), WRB5titch (07-29-2014)
Old 07-29-2014, 06:52 PM   #6867
Robftss
Drives: VW
Originally Posted by Robftss View Post
Thks Fenton and all the new interested people.
I will be revising the installl manual, after ~30 kits it looks like step by step, circles/arrows, and check boxes are required. I may tag wires and reference them to a # operation, torque specs as well... since 'tighten' is to subjective. I need to evaluate one re-charge board failure and a control board failure. This is ALL new stuff and is primarily a development product not a mass produced product... it can't be... there is 'more' potential here. I'm excited
Rob.
Still working on details.
Regarding the re-charge board that stopped working: a lose retainer clip shifted and made contact with the circuit board. Thanks @shif7i7down for returning the controller.
Robftss is offline   Reply With Quote
The Following 6 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (07-29-2014), enwave (07-29-2014), Gums (07-29-2014), nlowell (07-29-2014), Sojhinn (07-30-2014), WRB5titch (07-29-2014)
Old 07-29-2014, 10:55 PM   #6868
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
My poor AT is thirsty for corn juice. I'm tempted to try and do map comparisons and try to put together my own -- I might actually do this and then run it by Shiv to see if it seems about right.
The thirst is real!
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
DAEMANO (07-30-2014)
Old 07-29-2014, 11:31 PM   #6869
fenton
The thirst is real!
I'm sure he us working on getting it out soon? Have you asked him if he needs any help testing anything?
Old 07-30-2014, 10:43 AM   #6870
shif7i7down
Erected Member
Drives: frs
Yup no problem, but i should be the one thanking you instead. Your mannerisms and business ethics are top notch. Keepup the great work and hope to see more add-ons in the future.
Btw, i call dibs on being in the list for the first batch of any and all New mods that may be available for this system in the future.
DIBS,
shif7i7down is offline   Reply With Quote
Old 07-30-2014, 02:53 PM   #6871
Winjr
DAEMANO, e85 is really that much better? I mean, I've seen the dynos so I know the numbers. Let me put it this way ...
Is e85 + ESC even just close to a butt dyno improvement over ESC alone, as was stock + tune over stock. When I got the tune I thought "wow, this is fabulous".
Should I expect no ill effects with the direct injectors? Would e85 actually be kinder to the DI's? I only mentioned this due to some paranoia over DI issues, having already needed to replace #1 and #3 because they got extremely gunked up for reasons still unknown, though I now suspect it was the gas station where I was regularly fueling.
I've got an unlimited supply of e85 just a few miles away and I'm contemplating a flex fuel kit as well.
Old 07-30-2014, 03:08 PM   #6872
raven1231
DIBS,
Well in that case. I want dibs also lol
Old 07-30-2014, 03:30 PM   #6873
GerryL
Drives: White BRZ
What is the flex fuel kit? Is that something available from Subaru?
GerryL is offline   Reply With Quote
Old 07-30-2014, 03:51 PM   #6874
enwave
enwave's Avatar
Not available from Subaru. It's basically a sensor that will read the ethanol content of your fuel and allow an Ecutek tune to adjust to match the ethanol content of your fuel. Shiv's tune is good from E60 up, so flex fuel isn't necessary for most people, but it can be really convenient that you don't have to drain tanks to switch fuels, etc. It is also nice in case you get a particularly bad blend of E85 from a shady station, etc. just safer all around.
I have been using Shiv's E85 OTS in the past and loved it and plan on using his tune again when it is available for ESC 6AT. No flex fuel hardware sensor required for it, but it's wise to check your logs after filling to make sure the station didn't give you something wacky.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
