| Software Tuning Discuss all software tuning topics. |
#253 | |
Drives: 2015 WRX
It just has the beta designation mostly because its only available for the USDM market atm and will lose the beta designation once he starts releasing it to the various other International CalIDs. At least that's what I've noticed from the past map releases. |
#254 | |
Drives: Raven Scion FR-S
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#255 | |
Drives: 2015 WRX
#256 |
Drives: 2013 Scion FR-S Raven
True True
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#257 | |
Drives: 13 FR-S: Raven
Just flashed 2.01 EL E85 today and have not had any issues after about 30 miles. The 1.59 E85 map is the first I used and the relearn process for that was far overdone. Today I let her idle until my coolant temp was about 190 (5m maybe) and drove approximately 2 miles before a WRX turbo (non STI) kept messing with me. Not only did I abandon my relearn, but managed to pull away nicely on him too. It only took a few min for dead pedal to pass (Key on Ign off procedure after tune). Also, STF/LTF balanced quickly. Honestly, it seemed to be much smoother than the last tune in all areas. Even the writing time seemed faster. For me, there is a noticeable difference between both E85 EL tunes and I have a stock manifold. Hope to get in some runs soon at ICC. Anyone close to Omaha should come out! Its no 86Fest, but we have tons of E85! They don't call us Corn Huskers for nothing
#258 | |
Drives: 2013 Asphalt 6spd
Phantom ESC, OFH, OFT, K&N Drop in
#259 |
Flash back to stock before taking it in or tell them not to touch it because it is tuned.
#260 |
Drives: '18 STi
For some reason when I press the recalculate button on the purchase menu, it says that I still have to pay $19 for the shipping fee. So much for free shipping?
#261 | |
Drives: FT86
The main reason to flash back to stock is so you could then erase oft and download the updated dealer tune as your stock tune in the protected slot in the oft. So if you ever sold your oft or car you would be able to flash back the latest rom calibration instead of the outdated one your car came with. The oft tunes are based on the later rom calid so its all ok from that angle currently B01C for usa/canada |
#262 | |
Drives: 2014 Scion FR-S
Sent from my GT-N5110 using Tapatalk |
#263 |
Drives: FT86
To umarry just flash back your stock tune to oft then you need to connect oft to pc running ofm with internet connection and use the erase function in open flash manager then your umarried.
If you jist flash back to stock it not unmarried but you ready to unamrry if dealer reflashes tune to you car. either the dealer will tell you of you can connect oft and use diagnostics to read your calid to see if its changed. If you have already flashed to stock then do full erase with ofm and marry up to new calid. If no change just flash your tune back. But if you dont flash to stock before dealer reflashes your stuck with your old rom in the oft |
#264 | |
*edit: ok thanks steve, that's what I was afraid of. It still might be a remote possibility, but too costly of one to chance it. I may have to look into one of those mini cats that screws into the o2 port.
#265 |
Flashed the Stage 2 EL E85 and went for a drive. Feels like there has been a real improvement below 4k. The induction noise is still there (for me, anyway) but it sure does sound more refined. The torque dip is still there, but is even less noticable, and once above five k it's not shy about heading for redline. Nice work!
#266 | |
Drives: JAWS
| OpenFlash Tablet v1.42b maps now available | Shiv@Openflash | Software Tuning | 159 | 09-13-2016 12:29 AM |
| Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download | Shiv@Openflash | Software Tuning | 354 | 02-08-2015 05:23 PM |
| OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted | Shiv@Openflash | Software Tuning | 142 | 07-22-2014 10:21 PM |
| Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) | Shiv@Openflash | Software Tuning | 255 | 02-15-2014 04:43 AM |
| OpenFlash Tablet Stage 1 v1.2 maps available for download | Shiv@Openflash | Software Tuning | 31 | 10-31-2013 08:45 PM |
