Old 07-29-2014, 01:52 PM   #239
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by Scavanger View Post
Not sure if it's just me or what, but after updating to the newer version my car seems slower and I am making less hp by about 10 I was sitting around 190 and now I'm not even making 180 to the wheels and I have a full exhaust and intake just so y'all know
That's surprising. But it's possible the old Stage 1 map had MAF scaling that was more suitable for your intake. The new v2.0 are certainly better for cars with stock air boxes.
Shiv@Openflash is offline   Reply With Quote
The Following 4 Users Say Thank You to Shiv@Openflash For This Useful Post:
CamryDS (07-30-2014), CaptainSlow (07-29-2014), DC2R (07-29-2014), flippy (08-15-2014)
Old 07-29-2014, 02:58 PM   #240
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Originally Posted by Kodename47 View Post
Can you not open 2 ROMs in Romraider? I'm sure you can, and be able to compare them. Then it's just a case of copy and paste. I'll have a play in a bit.
They use different XML templates, the old rom and the 2.01. Rom raider can only read one type of XML at a time, so if u loaded the new XML for the 2.01 all the older roms will not read correctly
Old 07-29-2014, 04:38 PM   #241
Garrett@Openflash
Garrett@Openflash's Avatar
Drives: S2K AP2
Hey all-
Glad you guys are enjoying the OTS 2.0 beta release, and we appreciate all the feedback we have received. Don't forget we are offering FREE SHIPPING on all domestic OFT orders for THIS WEEK ONLY
Garrett@Openflash is offline   Reply With Quote
The Following 3 Users Say Thank You to Garrett@Openflash For This Useful Post:
akahenry (07-29-2014), CamryDS (07-29-2014), lucid215 (07-30-2014)
Old 07-29-2014, 05:28 PM   #242
Vmax911
Drives: WRB BRZ
Didn't see the answer to this in the thread, maybe I missed it.
There are specific .bin files for E85, 93, and 91 octane. However, there is also a .bin file with no specific fuel requirement. What tune is that for?
Vmax911 is offline   Reply With Quote
Old 07-29-2014, 05:40 PM   #243
Scavanger
Avid searcher of things
Scavanger's Avatar
Drives: Scion Fr-s 10 series
I installed the tune on Friday to give it sometime to settle in, should be fine by now
Scavanger is offline   Reply With Quote
The Following User Says Thank You to Scavanger For This Useful Post:
fstlane (07-29-2014)
Old 07-29-2014, 05:41 PM   #244
Scavanger
Scavanger's Avatar
Is there any way it didn't upgrade to the correct 2.0 maps and is going off of something else? Is there anyway to check what maps are loaded on my oft?
Old 07-29-2014, 05:57 PM   #245
Kodename47
Kodename47's Avatar
Drives: UK GT86
You can load more than one definition file into Romraider which should mean that you can open multiple ROMs. So long as you have the correct definition file to open both the old file and new you're golden. The definition files should work on any corresponding ROM, it depends if Shiv has used the B01 file and just renamed it as to whether it will work correctly.
I'll see if I can get a 1.59 and 2.01 map open. What's your stock ID out of interest?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-29-2014, 06:00 PM   #246
solidONE
solidONE's Avatar
Originally Posted by ML View Post
I'm still seeing high 11's in AFR after moving the scale. but no, it let me open the new tune with the old xml i was using, so I opened the old tune, and the new, and just copy and pasted the tables. After that I opened it with the new xml, and adjusted LC and FFS.
The 2.01 rom does not read correctly although it does open with the old xml definition. You've loaded this to your car and it still runs fine?
This is what the 2.01 primary fueling table looks like opened with the old XML on the right vs my modified 1.59.
Old 07-29-2014, 06:02 PM   #247
solidONE
solidONE's Avatar
Romraider will only use one xml even if you've loaded multiple xml. look above. My stock calibration is A01C
Old 07-29-2014, 06:40 PM   #248
jprice130
AutoX Nut
Drives: 2020 Toyota Supra
Have you tried having RomRaider reference two different XML files for different CAL ids in the "ECU Definition Manager" and then open two different tunes with those CAL ids?
For instance, you could setup a reference to the old XML for A01C and then reference the new XML for B01C in the ECU Definition Manager. As you know, Shiv has the same tune for all the CAL ids, so with this setup, you should be able to open an old tune for A01C and compare it to a new B01C tune. I'm pretty sure RomRaider will associate the right XML def to the different tunes when you open up tunes for different CAL ids.
I was having the same problem as you comparing the tunes because I was trying to compare an old A01C tune to a new A01C tune. All the table values on the old A01C tune looked funky because I was referencing the new A01C XML.
jprice130 is offline   Reply With Quote
Old 07-29-2014, 07:03 PM   #249
solidONE
solidONE's Avatar
I actually have both of the XML loaded into romraider, but with the older version first on the list. The result was wat u see in the screenshot above. Maybe there is something else I need to do?
Old 07-29-2014, 07:08 PM   #250
Danklvr
Danklvr's Avatar
Drives: 2014 FR-S 6MT Argento
Send a message via AIM to Danklvr
put the new xml first on the list, the older xml below. then open the new tune file first - 2.01. then lastly open the old tune file, it will appear below the new tune file that opens up in romraider.
thats what i do, if I'm way wrong someone please let me know. I haven't had any problems moving some of my custom settings (copy / paste from one table to another) from 1.55 to 2.01 OTS tune file.
How ya gonna keep 'em down on the farm once they've seen Karl Hungus?
Danklvr is offline   Reply With Quote
The Following 2 Users Say Thank You to Danklvr For This Useful Post:
jprice130 (07-29-2014), solidONE (07-30-2014)
Old 07-29-2014, 07:24 PM   #251
jprice130
AutoX Nut
Actually, you know what may be simpler than what I originally suggested? Keep the older XML first on the list, then open the old tune. Then go back to the ECU Definition Manager and move the new XML to the top of the list and save. Then open the new tune. I just tested this in RomRaider and was able to open an old and new Stg1 A01C tune and compare all the table values with no problem.
Edit: Danklvr already kind of suggested this. Thanks!
The Following 2 Users Say Thank You to jprice130 For This Useful Post:
Danklvr (07-29-2014), solidONE (07-30-2014)
Old 07-29-2014, 07:33 PM   #252
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Exclamation
Hey Shiv when should we be expecting the Non Beta 2.01 tune ? and what differences do you think you'll be making to it?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
OpenFlash Tablet v1.42b maps now available Shiv@Openflash Software Tuning 159 09-13-2016 01:29 AM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 06:23 PM
OpenFlash Tablet: v1.60 OTS Maps (beta)-- USDM testers wanted Shiv@Openflash Software Tuning 142 07-22-2014 11:21 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 05:43 AM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 09:45 PM
