Old 07-17-2014, 10:36 PM   #29
Hawk77FT
Drives: GTS 86
Does anyone can recommend where I can get this from? And parts list?
Hawk77FT is offline   Reply With Quote
Old 07-18-2014, 04:55 PM   #30
zoth
zoth's Avatar
Drives: 2013 BRZ Premium Dark Gray Metallic
Now this I like
• Laminova Heat Exchanger Core
• Fully CNC machined, 6061-T6 Aluminum
• Anodized for corrosion protection
• Sealed with Buna-N and Viton o-rings
• Overall Dimensions: 2 3⁄16" x 8 5⁄8"
$345
KraftWerks SuperCharger C30=HB-Waterless Coolant-(Mishi)Racing Thermostat & Oil Can
Tomei EL-PLM Overpipe-HKS Dual Resonated Front Pipe-Invidia N1
DR31 18x9+38 Square w/ 255/40r18 PT-722, TRD Quickshifter, ACT Streetlite Kit
Moto-East Flex-Fuel Kit (Almost running 100% E85 all the time)
DW 700 cc Injectors-Tune by (Moto-East)-KW Oil Cooler
zoth is offline   Reply With Quote
Old 07-19-2014, 12:59 AM   #31
wootwoot
Drives: FRS
I think it is too long.... The one used by the OP is 7" plus fittings....
Old 07-19-2014, 11:22 PM   #32
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Originally Posted by zoth View Post
Now this I like
$345
Where did you find this? Also any documentation on how the oil flows through the core? I found this which is MUCH better than the standard mocal cooler.
Standard:
Offset $9 more
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 07-20-2014, 04:43 AM   #33
zoth
zoth's Avatar
Standard:
Offset $9 more
I contacted the manufacturer, hoping they will get back to me soon. I will keep you guys posted.
That including the fittings, so should be the same.
Old 07-20-2014, 11:11 PM   #34
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
I wonder if there's a way to use this with the OEM Forester oil cooler (sandwich plate)
glamcem is offline   Reply With Quote
Old 07-21-2014, 11:43 AM   #35
zoth
zoth's Avatar
I don't think so, cause the only in and out of the OEM is water no oil. 2nd sandwich for the oil maybe.
Sent from my SM-N900T using Tapatalk
The Following User Says Thank You to zoth For This Useful Post:
glamcem (07-21-2014)
Old 07-27-2014, 02:26 AM   #36
sw20kosh
Drives: 2013 Black FR-S
FYI Unfortunately this doesn't work on a turbocharged setup.
Old 07-27-2014, 02:40 AM   #37
mkivsoopra
I installed this same setup in my BRZ last weekend.
Preface:
The car has the PTuning turbo kit and a Koyo radiator. I've been tracking the car and am looking for a solution to keep my oil temps down. I've seen 300ºF oil temps and 240ºF water temps at the track when running with no oil cooler.
The good:
When cruising with ambient temps in the 70s, water temp remained between 189º-195ºF and oil temp around 195º-200º. This was much better than the 215º+ I saw from just cruising without the oil cooler. On warmer days, oil temps while cruising could be in the 225º+ range with no oil cooler.
The bad:
The moment I get on the throttle and build boost, the oil temps would shoot upwards, just like before. While cruising with the oil temps at 200º and getting on the throttle, I would see the oil temps shoot up to 220º+. With spirited driving in the mountains, I would easily see sustained 235º oil temp along with 212º water temp.
The ugly:
Today, with ambient temps in the 95º-100º, I did some testing in the mountains. I kept it in 2nd gear to keep the revs high and was on and off the boost, but never WOT (not trying to fall off any cliffs). Within 5 minutes of this type of thrashing, the oil temp went from 235º to 260º+. Water temps started to rise along with it as well.
Unfortunately, it doesn't seem like this unit has the capacity to handle the heat generated from a turbo car.
mkivsoopra is offline   Reply With Quote
The Following 6 Users Say Thank You to mkivsoopra For This Useful Post:
DAEMANO (12-09-2014), MyRx (07-27-2014), rb6freak (08-19-2014), sw20kosh (07-27-2014), ThisGuy919 (07-27-2014), unsurety (08-09-2014)
Old 07-27-2014, 08:56 AM   #38
Model Citizen
Lacking brains
Drives: frz
One thing i have found with my oem sandwich plate cooler implementation is running the heat (on max, vents pointed out the window) helps with lowering the oil temps ssince you are removing heat from the system.
It isnt a huge difference, but its evident on my scangauge dueing a track session and while cooling down in paddock.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
unsurety (09-08-2014)
Old 07-27-2014, 12:43 PM   #39
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
@mkivsoopra
PTuning announced its Laminova cooler for pre-order with delivery the end of July 2014.
Link to catalogue page
http://www.ptuning.com/subdir/itemde...&ModelDesc=BRZ
Difficult to determine, but kit appears to use the middle-sized Mocal heat exchanger.
Brzzee is offline   Reply With Quote
The Following User Says Thank You to Brzzee For This Useful Post:
mkivsoopra (07-27-2014)
Old 07-27-2014, 01:24 PM   #40
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
The heat has to go somewhere. With just the laminova system, the heat goes into the water, but the engine's overall cooling capacity is not increased at all. Since the system also doesn't add a significant amount of oil, you also don't increase the capacity to absorb heat. This system would make more sense when coupled with a bigger radiator and some method of increasing the oil volume, like a larger oil pan or in-line oil tank. The oil to air radiators combine cooling and oil volume in one package, but they take up space. There's also the integrated oil and water radiators like what Robispec sells. Those are elegant, but they take up space where some FI kits want room. Hours of fun!
The Following 2 Users Say Thank You to EAGLE5 For This Useful Post:
afx (03-24-2015), rb6freak (08-19-2014)
Old 07-27-2014, 05:31 PM   #41
mkivsoopra
@jsimon7777, I have a Koyo radiator with added foam and ducting to direct the flow of air to the radiator (and also a big intercooler in the path ). I'll be trying an air-to-oil cooler next.
Old 07-27-2014, 05:58 PM   #42
EAGLE5
Dismember
EAGLE5's Avatar
How much HP are you running? How about adding a bigger oil pan too? You just need bigger everything! May be some ducting so all the coolers aren't in the same path. You could keep the laminova for quick warm up and not worrying about overcooling the coil. It's not like running a constant 6krpm in 2nd gear is a normal way of driving. Not much air going through the coolers, but a lot of heat being generated.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Intake and water encity5 Engine, Exhaust, Transmission 5 07-23-2013 12:49 PM
Water Spots norcal_brz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-16-2013 01:06 AM
Water by the Bridge Panda Grahams Southeast 5 03-20-2013 08:50 AM
Water in trunk Spencer BRZ First-Gen (2012+) — General Topics 14 03-15-2013 10:17 PM
