Old 07-17-2014, 05:11 AM   #1
Boba_kz
Oil and water cooling
So, lets discuss about oil and water temperate issue.
Your
1) Cooling modification
2) City cruising water/oil temperature
3) Track water/oil temperature
Here is main:
1) FBM shroud with Spal fans, Koyo radiator, FBM oil cooler, additional hood and bumper ventilation
2) 205F/217F
3) 219F/246F
Boba_kz is offline   Reply With Quote
Old 07-17-2014, 04:02 PM   #2
Sleepless
Drives: 2016 FR-S
Stock BRZ engine and exhaust
1) Perrin oil cooler
2) City Water: 190F Oil: 190F
3) Track Water: 212F Oil: 235F Ambient: 90F
Sleepless is offline   Reply With Quote
Old 07-17-2014, 04:48 PM   #3
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Mine is the same as sleepless
8 quart oil pan, amsoil dominator, cowl rubber seal removed, plastic removed from cowl area of hood.
Old 07-17-2014, 07:11 PM   #4
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
1. Perrin Oil Cooler
2. City: Water 190 F, Oil 170 F (winter) 190 F (Summer)
3. Track (65 F ambient): Water 212 F, Oil 214 F
Bonus track data from the same day from a BRZ with no cooling mods running the same data collection utility and running the same pace:
Water 212, Oil 276
Decay107 is offline   Reply With Quote
Old 07-17-2014, 07:41 PM   #5
brn12345
brn12345's Avatar
1. None
2. 195f/205f
3. Didn't log water / 290f oil
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 07-17-2014, 10:27 PM   #6
troek
troek's Avatar
Drives: 2012 Toyota 86
cusco oil cooler
city 190 water, 200 oil
track 212 water, 230-250 oil.
troek is offline   Reply With Quote
Old 06-18-2017, 04:20 PM   #7
Bfranklyn86
Drives: GT86 Harrop S/C
Originally Posted by troek View Post
cusco oil cooler
Have you (or anyone else) had any issue with low oil pressures with the cusco oil cooler?
Bfranklyn86 is offline   Reply With Quote
Old 06-18-2017, 06:27 PM   #8
lazyluka
Drives: GT86
0) NA - Factory tune
1) Cusco Oil Cooler
2) - No data -
3) 201 F / 255 F (Converted from C) 15min session
Bonus: I managed to get the temps up to 208 F / 266 F on a 30 minute session.
I am only just installing an oil pressure gauge. Why would there be an issue with oil pressure when there are no long lines to run?
While I don't have hard facts we do have a really looooong right-hand sweeper on one of our tracks which normally causes issues with oiling. I've had no issues.
lazyluka is offline   Reply With Quote
Old 06-18-2017, 07:31 PM   #9
redlined600
redlined600's Avatar
Drives: Fr-s
0: na w/tune
1: stock rad, custom OC 13 row core.
2: ???
3: max 200ish water / 230 oil.
redlined600 is offline   Reply With Quote
Old 06-18-2017, 08:38 PM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
NA with tune
removed the rubber seals around hood
grill delete
My drive to work is mostly highway and the oil temp would always get hot ont he highway- I have seen it get up to 220 F cruising on a hot doing 80 MPH. But once I did the grill delete I was surprised to see my oil temps consistently 5-10F cooler. It hasn't gotten over 210 yet and that was normal before. I don't really get it and I wasn't expecting it. My IAT is down a few degrees and I expected that but the oil temp thing was a surprise.
guybo is offline   Reply With Quote
Old 06-19-2017, 03:10 AM   #11
Bfranklyn86
1) Cusco Oil Cooler
2) - No data -
There is some talk about the heat exchangers in the cusco oil cooler (and maybe the standard OEM Subaru coolers) being a little bit restrictive for oil flow vs no cooler or the standard oil-air coolers. Not sure if there's any truth in it, and it's good to hear your experience, thanks.
Old 06-19-2017, 11:29 AM   #12
Azzudien
Drives: 2017 Series Yellow BRZ
So correct me if I am wrong, I was under the impression oil temps below 212F are not a good thing because you are not vaporizing water that is coming in through fuel system?
I see some above that are below that threshold. Ideally I thought oil temperatures should be in the 230-260 range???
Azzudien is offline   Reply With Quote
Old 06-19-2017, 05:12 PM   #13
Bfranklyn86
Ideally it should be, and coolers like the cusco help warm the oil up to temperature more quickly on engine start. However my oil gets up to 260 on track (on a warm day, even with short sessions) and this is right at the top of the safe limit - my tune limits the engine to 5k rpm if it goes above this, so I need a cooler to keep it just below this.
Old 08-08-2017, 03:58 AM   #14
troek
troek's Avatar
Sorry, just now seeing this, I did not have a pressure gauge installed unfortunately.
Brake cooling Model Citizen Suspension | Chassis | Brakes -- Sponsored by 949 Racing 115 08-28-2018 11:28 PM
BRZ Fog delete for air duct/cooling BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 9 01-31-2014 12:46 PM
Cusco Supecharger kit with water cooling Thongpocket Forced Induction 1 09-23-2013 12:54 PM
brakes and cooling DRACHENV6 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-11-2013 10:34 AM
TF Brake Duct Cooling Kit Touge Factory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 33 02-19-2013 06:04 PM
