Old 07-17-2014, 12:56 AM   #113
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by jflogerzi View Post
230 WHP? What about TQ?
~225whp and ~200lbft. Still tuning. But nice broad tq curve. Still running the stock front pipe, cat and exhaust. Only other mod besides the ESC is the OFH. This is different to the old E85 dyno results we had on my car when it was equipped with a front pipe, test-pipe and exhaust (LOUD!)
Shiv
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-17-2014)
Old 07-17-2014, 12:57 AM   #114
jflogerzi
jflogerzi's Avatar
Shiv
So with a full 2.5 inch exhaust, maybe an additional 5-10WHP and TQ might be possible?
Old 07-17-2014, 02:56 AM   #115
Shiv@Openflash
Drives: 2013 FRS
Maybe 5-10lbft more torque. But probably much in the way of WHP gains (maybe 5whp all other things equal) since that is more of a compressor limitation than anything else.
Old 07-17-2014, 03:07 AM   #116
Shiv@Openflash
Drives: 2013 FRS
E85 OTS Map dyno testing
Hi guys,
Spent several hours on the dyno this evening putting together a nice safe and drivable E85 map for the ESC 1.5+OFH. Worked out quite well. Test car only has Phantom ESC, OpenFlash Header and, of course, OpenFlash Tablet. Stock airbox, stock filter, stock front pipe, stock exhaust.
I'm happy with the nice flat torque curve as well as a lack of power roll-off up top. Makes for a very quick and responsive car. Still quite conservative and safe with AFR hitting mid to high 11s by peak hp (~7000rpm). Running leaner will give another few hp but it will sacrifice some safety margin that is necessary to have due to variances in cars, fuel, conditions
I'll drive our car around a bit more for testing purposes. Then I'll the tune out to those who want to test
Cheers,
Shiv
The Following 9 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (07-17-2014), MagicBobert (07-17-2014), raven1231 (07-17-2014), Robftss (07-17-2014), Sojhinn (07-17-2014), Target70 (07-17-2014), TM (07-17-2014), WNDSRFR (07-17-2014), WRB5titch (07-17-2014)
Old 07-17-2014, 03:29 AM   #117
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Hi guys,
Cheers,
Shiv
Thanks again shiv!
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Old 07-17-2014, 05:04 AM   #118
DAEMANO
Time Traveller
Hi guys,
Cheers,
Shiv
The Following 3 Users Say Thank You to DAEMANO For This Useful Post:
raven1231 (07-17-2014), Sojhinn (07-17-2014), WRB5titch (07-17-2014)
Old 07-17-2014, 08:04 AM   #119
raven1231
Originally Posted by DAEMANO View Post
This ! I have been only been putting in a couple gallons of 93 each fill up anticipating this
Old 07-17-2014, 08:14 AM   #120
jflogerzi
jflogerzi's Avatar
Originally Posted by Sojhinn View Post
Thanks again shiv!
That curve looks good. nice and flat and smooth. Hey shiv would you mind in the next few days adding a standard E85 car without ESC? Would love to see the differences
@Shiv@Openflash
Old 07-17-2014, 08:41 AM   #121
raven1231
makes me wonder what the tq300 on E85 with the 1.5con and full exhaust would have done ?
Old 07-17-2014, 10:40 AM   #122
shif7i7down
Erected Member
Drives: frs
Hoping that you'll release it before the weekend so i can have the whole weekend to test it out
shif7i7down is offline   Reply With Quote
The Following User Says Thank You to shif7i7down For This Useful Post:
Old 07-17-2014, 10:52 AM   #123
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
I don't think I would ever run E85 all the time because of the reduced mileage (and because it's at least an hour to the nearest station)... but with those numbers I'd sure as heck flash the ROM and try it out!
Looks very good. Thanks for the work, Shiv.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 07-17-2014, 10:58 AM   #124
robwbright
With these new v2.0 OTS ESC maps, Launch Control RPM is set to 5500RPM.
A couple questions - please bear with my ignorance.
I understand the flat foot shifting. How does the launch control work in the tune (both technically and practically speaking)? Why at 5500 rpm as opposed to 4500... or 6500?
Thanks.
I think I'm going to flash to the 2.0 now.
2006 Saab 9-3 2.0t
Old 07-17-2014, 11:00 AM   #125
raven1231
Once you go corn you never go back
enwave (07-17-2014)
Old 07-17-2014, 11:01 AM   #126
raven1231
Same here
Phantom TQ250 Dyno FBO (Dual Battery Pack) Shiv@Openflash Forced Induction 23 04-29-2014 02:40 AM
Clutch dump at 5000 RPM? fasteddy BRZ First-Gen (2012+) — General Topics 20 08-22-2013 01:55 PM
External dump and under tray? mrk1 Forced Induction 5 07-30-2013 09:43 AM
Photo dump. CanibeatNoel FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 07-17-2013 02:47 AM
Ricepuddin Picture Dump Ricepuddin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 15 12-03-2012 12:18 AM
